Microchip’s MCP9700 and MCP9701 low-power linear active thermistor ICs provide a low-cost solution
Microchip’s low-power MCP9700, MCP9700A, MCP9700B, MCP9701, and MCP9701A analog temperature sensors with linear active thermistor integrated circuit (IC) convert temperature to analog voltage. These sensors have accuracy of ±1°C from +20°C to +70°C (MCP9700B), ±2°C from 0°C to +70°C (MCP9700A and MCP9701A), and ±4°C from 0°C to +70°C (MCP9700 and MCP9701) and consume 6 µA (typical) of operating current. These sensors provide a low-cost solution for applications requiring relative temperature change measurement.
- Available packages:
- SC70-5, SOT-23-3, and TO-92-3 (not available with the MCP9700B)
- Wide temperature measurement range:
- -40°C to +125°C (extended temperature)
- -40°C to +150°C (high temperature)
- Accuracy:
- ±1°C (max.), +20°C to +70°C (MCP9700B)
- ±2°C (max.), 0°C to +70°C (MCP9700A and MCP9701A)
- ±4°C (max.), 0°C to +70°C (MCP9700 and MCP9701)
- Tiny analog temperature sensor
- Optimized for analog-to-digital converters (ADCs):
- 10 mV/°C (typical) (MCP9700, MCP9700A, and MCP9700B)
- 19.5 mV/°C (typical) (MCP9701 and MCP9701A)
- Wide operating voltage range:
- VDD = 2.3 V to 5.5 V (MCP9700, MCP9700A, and MCP9700B)
- VDD = 3.1 V to 5.5 V (MCP9701 and MCP9701A)
- Low operating current of 6 µA (typical)
- Optimized to drive large capacitive loads
more information: https://www.microchip.com/en-us/product/MCP9700A
Login
