![Microflex MCUs Features ESP32 S3, S2, C3, C6, and RPi RP2040 In compact Size Microflex MCUs Features ESP32 S3, S2, C3, C6, and RPi RP2040 In compact Size](https://www.electronics-lab.com/wp-content/uploads/2023/12/Microflex-MCU-ESP32-RP2040.jpg)
SB Components, a renowned manufacturer in embedded technology, has unveiled the Microflex MCU development boards. These compact boards feature five different microcontrollers: ESP32-S3, ESP32-S2, ESP32-C3, ESP32-C6, and Raspberry Pi Pico RP2040. Applications include sensor networks, handheld devices, smart home systems, IoT solutions, and wearable technologies.
All the boards in this series share the same footprint and pinout and they support standard protocols like SPI, I2C, I2S (except for the Micro-RP model), UART, and 12-bit ADCs. The Micro-S2 is unique in its class, featuring 2x 13-bit SAR ADCs and a dual 8-bit DAC.
You can program the ESP32-series boards using ESP-IDF, MicroPython, or Arduino IDE. The Raspberry Pi RP2040 (Micro-RP) board is compatible with Raspberry Pi’s MicroPython and C/C++ SDKs and it also works with Arduino IDE.
The MicroFlex MCU series, includes a 170-pin breadboard, a 1.3” LCD, programmable LEDs and buttons, a buzzer, a potentiometer, and extra power supply pins. It’s designed to offer a complete platform for technical experiments and prototyping.
Key Features of MicroFlex MCU Series and Development Kits:
- ESP32 C6 MCU Development Board:
- Supports Wi-Fi 6, Bluetooth® 5, Zigbee, and Thread.
- Ultra-low-power SoC with RISC-V single-core microprocessor.
- 2.4 GHz Wi-Fi 6 (802.11ax), Bluetooth® 5 (LE).
- Onboard RGB LED, BOOT & RESET BUTTON.
- ESP32 S3 MCU Development Board:
- 2.4 GHz Wi-Fi + Bluetooth® LE SoC.
- High-performance dual-core microprocessor (Xtensa® 32-bit LX7).
- Onboard RGB LED, BOOT & RESET BUTTON, GPIOs BREAKOUT, TYPE C INTERFACE.
- ESP32 S2 MCU Development Board:
- Xtensa® SingleCore 32-bit LX7 Microprocessor.
- IEEE 802.11b/g/n (2.4 GHz WiFi).
- ESP32 C3 MCU Development Board:
- Ultra-Low-Power SoC with RISC-V Single-Core CPU.
- 2.4 GHz Wi-Fi (802.11 b/g/n) and Bluetooth® 5 (LE).
- Pico RP2040 MCU Development Board:
- Microcontroller chip designed by Raspberry Pi.
- Symmetric dual-core processor complex.
- Onboard RGB LED, BOOT BUTTON, PROGRAMMABLE BUTTON, TYPE C INTERFACE.
- Micro Development Kit:
- 170 pins breadboard onboard.
- 1.3” LCD.
- 4 Programmable LEDs and buttons.
- Onboard Buzzer, Potentiometer.
- Additional Power supply Breakout pins (3.3V & 5V).
- Male/Female GPIO header for Micro Controller Series board functionality.
- Applications:
- Educational Projects, DIY Electronics, Embedded Systems.
- Sensor Networks, Battery-Efficient Devices, Wireless Sensor Nodes.
- Portable Gadgets, Advanced Robotics, Smart Home Devices.
- IoT Solutions, Wearables.
As of now, the MicroFlex MCU series has raised over $7,000. The pricing starts at about $6 for the RP2040 board, around $9 for the ESP32 S3 board, approximately $20 for the standalone Micro Development Kit, and close to $58 for the Micro Development Combo Kit. You can find more details on their Kickstarter product page.
