Milk-V DuoModule 01 is A Sophgo SG2000 SoC Powered Evolution board with 8051 Core and Linux Support
1.077
Milk-V has recently announced DuoModule 01 a Sophgo SG2000 Evaluation Board for developing and prototyping solutions using the SG2000 SoC. It has various interfaces like USB, MIPI CSI, and DSI for cameras and displays, Ethernet, and Wi-Fi/Bluetooth for connectivity. The Sophgo SG2000 is a feature-rich SoC with RISC-V or Cortex-A53 processor, and an 8051 core for low-power tasks. Additionally, it includes a TPU for AI applications. These features make this device useful for applications including embedded systems, IoT devices, AI edge computing, robotics, and multimedia projects due to its flexible processor options, diverse interfaces, and AI capabilities.
Previously we have seen Milk-V introduce various development boards built around the SG2000 SoC including the Milk-V Duo S, the Milk-V Megrez, and more feel free to check those out if you are looking for similar products built around the Sophgo SG2000 SoC.
Sophgo SG2000 dev board
Sophgo SG2000 dev board(DuoModule 01) Specifications
  • SoC:
    • SG2000 dual-core RISC-V processor with:
      • Dual C906 RV64 cores (1 GHz and 700 MHz)
      • ARM Cortex-A53 core (1 GHz, selectable via pin)
      • 8051 6KB MCU
      • 0.5 TOPS (Int8) TPU
      • 5M @ 30FPS ISP
  • System Memory: 512MB DDR3 RAM
  • Storage:
    • 1x microSD card slot
    • 1x 8GB eMMC flash
  • Video Output: 1x 39-pin FPC connector (MIPI DSI 4-lane)
  • Camera Input:
    • 1x 16-pin FPC connector (MIPI CSI 2-lane)
    • 1x 15-pin FPC connector (MIPI CSI 2-lane)
  • Audio:
    • 1x 3.5mm audio jack (output)
    • 2x 2-pin header for microphone input
  • Connectivity:
    • 2x 100Mbps Ethernet ports (RJ45)
    • Wi-Fi 6 and Bluetooth 5.4
  • USB:
    • 1x USB Type-C port (power and data)
    • 4x USB 2.0 Type-A host ports
  • Expansion:
    • Up to 19x GPIO pins (via header)
  • Misc:
    • 1x BOOT switch
    • 1x Recovery key
    • 1x RST key
  • Power Supply: 5V/1A via USB Type-C
  • Dimensions: 100 x 75 mm
The device supports up to 19 GPIO pins and includes interfaces like I2C, SPI, UART, PWM, and ADC. According to the product page, it is also compatible with Buildroot and RT-Thread. More technical documentation can be found on the Milk-V DuoModule 01 EvalBoard Wiki pages.
The Milk-V DuoModule 01 (Sophgo SG2000 dev board) Evaluation Board is currently available for pre-order at $41.00. Shipping is anticipated to commence in August 2024, and there’s a limit of 2 units per customer for pre-orders.
About Debashis Das
view all posts by das
