![Mini Slide Switches feature 2.54 mm pitches Mini Slide Switches feature 2.54 mm pitches](https://www.electronics-lab.com/wp-content/uploads/2021/05/CUI-Devices-MSS-1025xx-large.jpg)
CUI Devices’ mini slide switches feature 2.54 mm pitches, SPDT circuits, and on-on switch functions
CUI Devices’ mini slide switches are housed in packages as small as 10 mm x 2.5 mm x 5.9 mm. They are well suited for a variety of space-constrained consumer electronics, industrial control, and test equipment applications. Featuring 2.54 mm pitches, SPDT circuits, and on-on switch functions, these slide switches further offer gull wing or PC pin terminations, raised or flat actuator levels, and surface mount or through-hole mounting styles with vertical or horizontal orientations. The models also carry rated currents of 300 mA or 500 mA, rated voltages of 12 VDC or 24 VDC, and operating temperatures from -40°C up to +85°C.
- Packages as small as 10 mm x 2.5 mm x 5.9 mm
- 2.54 mm pitches
- SPDT circuits
- Operating temperature range: -40°C to +85°C
- On-on switch functions
- Gull wing or PC pin terminations
- SMT or through-hole mounting styles
- Raised or flat actuator levels
more information: https://www.cuidevices.com/catalog/switches/slide-switches
