Minisforum UM760 Slim: Compact Mini PC with Ryzen 5, 96GB DDR5, and 8K Display Support
1.117
Minisforum has introduced the UM760 Slim mini PC, built with the AMD Ryzen 5 7640HS processor and AMD Radeon 760M GPU for efficient performance in various computing tasks. It supports up to 96GB of DDR5 memory through dual SO-DIMM slots and includes two M.2 PCIe 4.0 SSD slots for high-speed storage expansion. The device is suitable for general computing, media streaming, and light gaming.
The UM760 Slim provides multiple video output options, including HDMI 2.1, DisplayPort 1.4, and USB4, allowing up to three 4K displays or a single 8K display. It features USB3.2 Gen2 Type-A, USB2.0, and a USB4 port with 100W power delivery. The system also has an M.2 2230 slot for Wi-Fi modules and a 2.5GbE LAN port for wired networking, making it ideal for multi-monitor setups and high-resolution output.
Previously, we covered other mini PCs like the Beelink EQi12, GENESYSM-ADN6, OneXPlayer M1, ASUS Chromebox 5a, and more. Feel free to check them out if you’re interested in those products.
Minisforum UM760 Slim mini PC specifications:
  • Processor: Hexa-core AMD Ryzen 5 7640HS up to 5 GHz; 6MB L2 cache, 16MB L3 cache, 12 threads; TDP: 54W
  • GPU: AMD Radeon 760M up to 2.8 GHz, 4 nm technology
  • System Memory: Up to 96GB DDR5 @ 5600MHz with dual SO-DIMM slots
  • Storage: Up to 4 TB M.2 nimble NVMe 2280 PCIe 4.0 SSD
  • Video output:
    • 1x HDMI 2.1 port with 4K@120Hz and 8K@60Hz output
    • 1x Display Port 1.4 up to 4K@144Hz
    • 1x USB4 and Thunderbolt 4 up to 8K (60Hz), 5K (72Hz) or 4K (240Hz)
    • Supports triple-screen display (HDMI + DP + USB4)
  • Audio output:
    •  1x HDMI
    • 1x DP 1.4
    • 3.5mm audio jack
  • Connectivity:
    • M.2 2230 Wi-Fi support for Wifi 6E and Bluetooth 5.3
    • 1x 2.5GbE RJ45 LAN port
  • USB:
    • 2x USB 3.2 Gen2 Type-A
    • 2x USB 2.0
    • 1x USB 4.0 (Alt PD)
  • Misc:
    • 1x Clear CMOS
    • Efficient cooling system
    • Power button and LED
  • Power Supply: 19V DC with adapter
  • Dimension: 130 x 127 x 50 mm
  • Weight: 671 gm
UM760 Slim mini PC pinout
The UM760 Slim is equipped with a phase-change cooling system featuring a silent fan and three copper heat pipes. According to Minisforum, this setup ensures efficient heat dissipation, maintaining stable 60W performance while keeping noise levels under 35dB.
The package includes the UM760 Slim Mini PC, an adapter with cable, an HDMI cable, a wall-mount kit, and a user manual. The device comes pre-installed with Windows 11 and Copilot, as noted on the product page.
The Minisforum UM760 Slim is priced at $349 for the version with 16GB RAM and a 1TB SSD.
About Sayantan Nandy
view all posts by sayantan
