![MINIX Z100-0dB Mini PC – An Alder Lake-N N100 Powred Quad Core Fanless Mini PC with Wi-Fi6, BT5.4, and more MINIX Z100-0dB Mini PC – An Alder Lake-N N100 Powred Quad Core Fanless Mini PC with Wi-Fi6, BT5.4, and more](https://www.electronics-lab.com/wp-content/uploads/2024/03/MINIX-Z100-0dB-Mini-PC-Intel-N100-Quad-Core-3.4GHz.jpg)
The MINIX NEO Z100-0dB, a silent mini PC, features the Intel Alder Lake-N N-100 quad-core CPU. It supports up to 32GB of RAM and 512GB M.2 storage. The PC comes with multiple USB ports, a MicroSD card slot, two HDMI 2.0 ports, 2.5GbE Ethernet, and other features.
The 0dB in the Z100-0dB comes from the fact that this device doesn’t have a fan and it’s designed to be a “ZERO Decibel Cooling System”.
In our previous posts, we have covered many similar mini PCs such as the ASUS Mini PC PL64, the Topton M4, and AAEON’s UP 7000 Edge, and we also wrote a review for the smallest of them all the Pantera Pico PC feel free to check those out if you are interested in the topic.
MINIX Z100-0dB Mini PC Specifications:
- Processor: Intel N100 quad-core Alder Lake-N, up to 3.4 GHz Turbo, 6MB cache
- Graphics: 24EU Intel HD at 750 MHz; 6W TDP
- RAM: Options of 4GB, 8GB, 16GB DDR4-3200, expandable to 32GB
- Storage: Choices of 128GB, 256GB, 512GB M.2 SSD (PCIe Gen3 x4), expandable to 4TB; MicroSD card slot
- Video Output: Dual HDMI 2.0 ports supporting up to 4K at 60Hz; capability for 2 independent displays
- Audio: 3.5mm headphone/mic jack; digital output over HDMI
- Connectivity: 2.5GbE RJ45; WiFi 6 and Bluetooth 5.2 with dual high-gain antennas
- USB Ports: 2x USB 3.2 (10 Gbps), 1x USB 3.2 Type-C (data only), 2x USB 2.0
- Additional Features: Power button, CMOS reset, Kensington lock, BIOS with Wake on LAN, Auto Power on, RTC wake-up
- Power: 12V to 19V DC jack (12V/3A adapter included)
- Dimensions: 12.3 x 12 x 4.6 cm
- Weight: 1.3 kg, aluminum, and galvanized steel build
Inside the box, you will find a 12V/3A power adapter, an HDMI cable, a VESA mount for attaching it to a monitor or TV, and two WiFi antennas. The device will come with a preinstalled copy of Windows 11 Pro. MINIX is not a new brand and it has been operating for quite a few years now but its products often cost more than similar products from other brands.
The MINIX Z100-0dB Mini PC is on sale at GeekBuying and the MINIX official website, offering versions with 16GB RAM and 512GB SSD, as well as 8GB RAM and a 256GB NVME SSD.
