moRFeus – A field-configurable wideband frequency converter and signal generator
MoRFeus is a 30 MHz–6 GHz field-configurable Fractional-N wideband frequency converter and signal generator. Its LCD display and button interface enable dynamic field-level configuration – from switching between signal generator and other modes, to setting the local oscillator frequency and more. It was designed for wideband frequency up- and down-conversion – with an LO frequency range of 85 MHz–5.4 GHz and input/output frequency range of 30 MHz–6 GHz
MoRFeus is small, lightweight, and functional. It was designed for low spurious emissions and is packaged in a precision-milled aluminum enclosure.
General Specifications
  • Input voltage: 5 V
  • ESD protection (RF IN and OUT ports): IEC 61000-4-2 contact discharge, 8 KV
  • Bias voltage: 5 V
  • Active bias current protection: 425 mA
  • Mixer input/output isolation: see mixer performance
  • Input IP3: +23 dBm
  • RF/IF input absolute maximum power: +15 dBm
  • Operating temperature -40 to +85
  • Storage temperature range -65 to +150
  • Dimensions: 88 mm x 38 mm x 68 mm
  • Weight: 7.4 oz
moRFeusis live on crowdsupply.com and available for 149 USD.
moRFeus – A field-configurable wideband frequency converter and signal generator – [Link]
2 Comments
Hervey John
Hi! We really like this project and want to feature it on our website. If you are interested, kindly drop me a message on my e-mail: hquiao.isi@gmail.com. I’ll be looking forward to your response! Thanks.
