![Motorcycle custom instrument panel Motorcycle custom instrument panel](https://www.electronics-lab.com/wp-content/uploads/2015/10/20151019_165950_levels-1024x768-1024x768.jpg)
Josh from Colorado build a nice dashboard for this motorcycle based on ATMega128 and EPSON S1D13700 LCD Screen:
Since the GSXR is now a street fighter the factory gauges won’t do, and I wanted something I could log air/fuel ratios with so I can jet the bike. I went a little overboard making a new dash.
I had a Planar 160×80 EL graphic display that’s been in my parts bin for years that I’ve always wanted to use, and this was perfect. Unfortunately it doesn’t have a controller so I had to interface it to the CPU with an Epson S1D13700 graphic controller. The display indicates speed from a GPS module, air/fuel ratios from the wideband O2 sensor, engine temp, battery voltage, time from GPS, and RPM. I used a light sensor to sense ambient brightness levels and dim the display by changing TC/R in the graphics controller. The refresh of the display is high enough to allow a large dimming range without flickering.
Motorcycle custom instrument panel – [Link]
