![MP2174C Switch Mode Converter MP2174C Switch Mode Converter](https://www.electronics-lab.com/wp-content/uploads/2020/12/mp2174c_tac.jpg)
MPS’ MP2174C is a 2.7 V to 5.5 V, 4 A, high-efficiency, synchronous step-down converter
Monolithic Power Systems’ MP2174C is a monolithic, step-down, switch-mode converter with built-in, internal power MOSFETs. It achieves 4 A of continuous output current from a 2.7 V to 5.5 V input voltage with excellent load and line regulation. The output voltage can be regulated as low as 0.6 V. The device has a constant on-time (COT) control scheme providing fast transient response and easy loop stabilization. Fault condition protections include cycle-by-cycle current limit and thermal shutdown. The MP2174C requires a minimal number of readily available standard external components. It is available in an ultra-small QFN-12 (2 mm x 2 mm) package making it ideal for a wide range of applications, including PDAs, portable instruments, DVD drives, and handheld devices.
Features:
- Forced PWM mode operation
- Wide 2.7 V to 5.5 V operating input range
- Output voltage as low as 0.6 V
- 4 A output current
- 35 mΩ and 18 mΩ internal power MOSFETs
- Peak efficiency above 96%
- 1.1 MHz frequency
- 100% duty cycle in dropout
- 0.5 ms internal soft-start time
- EN and power good for power sequencing
- Auto-discharge at power-off
- Short-circuit protection with hiccup mode
- Available in a QFN-12 (2 mm x 2 mm) package
more information: https://www.monolithicpower.com/en/mp2174c.html
