![MP23ABS1TR – MEMS Audio Single Ended Microphone MP23ABS1TR – MEMS Audio Single Ended Microphone](https://www.electronics-lab.com/wp-content/uploads/2020/01/41IRAhQsJL._SR600315_PIWhiteStripBottomLeft035_SCLZZZZZZZ_.jpg)
The MP23ABS1 is a compact, low-power microphone built with a capacitive sensing element and an IC interface. The sensing element, capable of detecting acoustic waves, is manufactured using a specialized silicon micromachining process to produce audio sensors. The MP23ABS1 has an acoustic overload point of 130 dBSPL with a typical 64 dB signal-to-noise ratio. The sensitivity of the MP23ABS1 is -38 dBV ±1 dB @ 94 dBSPL, 1 kHz.
- Single supply voltage operation 1.52 V – 3.6 V
- Omnidirectional sensitivity
- High signal-to-noise ratio
- High acoustic overload point: 130 dBSPL typ.
- Package compliant with reflow soldering
- Enhanced RF immunity
- Ultra-flat frequency response
- Low latency
- Ultra-low-power: 150 μA max
- ECOPACK®, RoHS, and “Green” compliant
Specifications
… Be Heard
Login
