![MP8833 1.5 A Thermoelectric Cooler Controller MP8833 1.5 A Thermoelectric Cooler Controller](https://www.electronics-lab.com/wp-content/uploads/2021/11/mp8833_tac_2_1.jpg)
Monolithic Power Systems monolithic thermoelectric cooler controller has built-in internal power MOSFETs
Monolithic Power Systems introduces the MP8833, a monolithic thermoelectric cooler controller with built-in internal power MOSFETs. It achieves 1.5 A of continuous output current from a 2.7 V to 5.5 V input voltage range with a thermoelectric cooler (TEC) voltage range. The TEC voltage is linearly controlled by the analog voltage. Features such as TEC voltage and current limiting are controlled by the 400 kHz I2C serial interface. The MP8833 is ideal for TEC device applications such as optical laser diodes and fiber communication networks. Full protection features include internal soft-start, over-current protection (OCP), over-voltage protection (OVP), and over-temperature protection (OTP). The MP8833 is available in a QFN-16 (2 mm x 3 mm) package for a minimum solution size.
- 1% 2.5 VREF accuracy
- Operating input range: 2.7 V to 5.5 V
- Up to 1.5 A TEC current
- TEC current monitor
- 30 mΩ internal MOSFETs for PWM switches and linear switches
- Default 1 MHz switching frequency
- External SYNC function
- EN/SD for power sequencing
- Available in a QFN-16 (2 mm x 3 mm) package
more information: https://www.monolithicpower.com/en/mp8833.html
