![The MPLAB® Snap In-Circuit Debugger/Programmer sells with 50% discount The MPLAB® Snap In-Circuit Debugger/Programmer sells with 50% discount](https://www.electronics-lab.com/wp-content/uploads/2019/09/180601-Dev-Tools-PHOTO-PG164100-_MPLAB-Snap-Angle-7x5.jpg)
The MPLAB® Snap In-Circuit Debugger/Programmer allows affordable, fast and easy debugging and programming of most PIC®, dsPIC®, AVR and SAM flash MCUs, using the powerful graphical user interface of MPLAB X Integrated Development Environment (IDE) version 5.05 or later. The MPLAB Snap can be connected to a computer using a High-Speed USB 2.0 interface and can be connected to the target via an 8-pin Single In-Line (SIL) connector. The connector uses two device I/O pins and the reset line to implement in-circuit debugging and In-Circuit Serial Programming™ (ICSP™). It has all the speed and features entry-level users need to quickly debug their prototype.
The MPLAB Snap programs fast, with a powerful 32-bit 300MHz SAME70 MCU for quicker debug iterations. Along with a wide target voltage, the MPLAB Snap supports advanced interfaces such as 4-wire JTAG and Serial Wire Debug with streaming data gateway, while being backward compatible for demo boards, headers and target systems using 2-wire JTAG and ICSP.
Note: The Snap is compatible with MPLAB X IDE version 5.05 and later.
Download MPLAB X IDE Now.
The MPLAB Snap In-Circuit Debugger/Programmer supports most, but not all, PIC, AVR and dsPIC DSCs at this time. The firmware is continually being upgraded to add support for new devices.
To check supported devices: Check the MPLAB X IDE Device Support List. If you have MPLAB X IDE installed, you can browse to the “docs” folder under your MPLAB X installation directory and open the file “Device Support.htm”. Alternatively, you can download it from this link: http://www.microchip.com/mplabx-ide-release-notes
Files are available for creating an MPLAB Snap enclosure from Thingiverse here.
Part Number: pg164100 – 50% Off – Use Coupon Code : TP1973 – Expires : 30-Sep-2019
