![MPM3650 Synchronous Ultra-Thin Power Module MPM3650 Synchronous Ultra-Thin Power Module](https://www.electronics-lab.com/wp-content/uploads/2021/03/mpm2650.jpg)
MPS’ 2.75 V to 17 V, 6 A, 1.2 MHz module is ideal for applications such as industrial equipment
MPS’ MPM3650 is a fully integrated, high-frequency, synchronous rectified, step-down power module with an internal inductor. It offers a very compact solution to achieve 6 A of continuous output current over a wide input range with excellent load and line regulation. The device has synchronous-mode operation for higher efficiency over the output current load range. Full protection features include SCP, overcurrent protection (OCP), UVP, and thermal shutdown. The constant-on-time control operation provides a very fast transient response, easy loop design, and very tight output regulation. The MPM3650 is available in a QFN-24 (4 mm x 6 mm) package.
Features:
- Wide operating input range: 2.75 V to 17 V
- Output current: 5 A
- Fixed switching frequency: 1,200 kHz
- External, programmable soft-start time
- EN and power good for power sequencing
- OCP and hiccup mode
- Thermal shutdown
- Internal power MOSFETs
- Output adjustable from 0.6 V
- High-efficiency synchronous-mode operation
- High efficiency with DCM in light-load operation
- Supports pre-biased startup
- Package: QFN-24 (4 mm x 6 mm)
more information: https://www.monolithicpower.com/en/mpm3650.html
