![MPM3860 Step-Down Power Module can achieve 6 A of continuous output MPM3860 Step-Down Power Module can achieve 6 A of continuous output](https://www.electronics-lab.com/wp-content/uploads/2021/03/mpm3860.jpg)
MPS’ MPM3860 1.2 MHz ultra-thin module can achieve 6 A of continuous output current over a wide input range with excellent load and line regulation
MPM3860 from Monolithic Power Systems is a fully integrated, high-frequency, synchronous, rectified, step-down power module with an internal inductor. It offers a very compact solution to achieve 6 A of continuous output current over a wide input range with excellent load and line regulation. The device has synchronous mode operation for higher efficiency over the output current load range. Full protection features include short-circuit protection (SCP), overcurrent protection (OCP), undervoltage protection (UVP), and thermal shutdown. The MPM3860 features constant on-time (COT) control operation, providing very fast transient response and easy loop design, as well as very tight output regulation. It is available in a QFN-24 (4 mm x 6 mm) package.
Features:
- Wide 2.75 V to 7 V operating input range
- 6 A output current
- Fixed 1200 kHz switching frequency
- External programmable soft-start time
- EN and power good for power sequencing
- OCP and hiccup mode
- Thermal shutdown
- Internal power MOSFETs
- Output adjustable from 0.6 V
- High-efficiency synchronous mode operation
- Pre-biased start-up
- Forced CCM mode for low VOUT ripple
- Available in a QFN-24 (4 mm x 6 mm) package
Video
more information: https://www.monolithicpower.com/en/mpm3860.html
