![MPPT solar charger MPPT solar charger](https://www.electronics-lab.com/wp-content/uploads/2016/10/20160927_SolarCharger_036-1024x683.jpg)
Lukas Fässler show us his progress on the MPPT solar charger:
One of my main goals with this design is to achieve very low standby current, somewhere in the tens of microamps. The basis for this is a low-power buck on the basis of a Texas TPS62120 where the microcontroller can switch the output voltage between 2.2 and 3.3 volts nominally. This works as intended. With no load and the output voltage low, the supply consumes 12.9 microamps at 12V input voltage. With the high output voltage the idle current goes up to 14.3uA. Quite a bit of that current is due to the voltage divider that sets the output voltage. The regulator itself consumes about 9uA in both cases.
MPPT solar charger – [Link]
Login
