![TE Connectivity’s MS5837-02BA Barometric Sensors TE Connectivity’s MS5837-02BA Barometric Sensors](https://www.electronics-lab.com/wp-content/uploads/2018/12/MS5837-02BA21.png)
TE Connectivity’s MS5837-02BA sensors are one of the smallest gel-filled watertight altimeters on the market.
TE Connectivity’s MS5837-02BA barometric pressure sensors take devices to the next level. These sensors are one of the smallest gel-filled watertight altimeters on the market. The ultra-small gel filled pressure sensors are optimized for both altimeter and barometer applications. Expanding on TE’s MS5837 series of ultra-compact digital altimeters, the generation 2 bar models offer options for chlorine resistance and shielding.
![](https://www.electronics-lab.com/wp-content/uploads/2018/12/ms5837-02ba06-block.png.jpg)
- Provide precise digital 24-bit pressure and temperature value with ultra-low power consumption
- Support design flexibility with ultra-small size while providing precise outputs: 3.3 mm x 3.3 mm x 2.75 mm
- Enable depths up to 100 m with watertight seal with 1.8 mm x 1.8 mm O-ring
- Enhanced construction and design materials offer a high endurance, chlorine resistant model suited for devices that will be exposed to environments with chlorine
- Reduce signal noise and interference that may be experienced with sensors installed in plastic housings or high electrical noise environments with these shielded models
more information can be found on www.te.com
Login
