![MYIR Introduces ARM SoM Based on Xilinx Zynq UltraScale+ MPSoC MYIR Introduces ARM SoM Based on Xilinx Zynq UltraScale+ MPSoC](https://www.electronics-lab.com/wp-content/uploads/2019/07/MYC-CZU3EG_n1.png)
MYIR introduces a high-performance MYC-CZU3EG CPU Module powered by Xilinx Zynq UltraScale+ ZU3EG MPSoC with a 1.2 GHz quad-core ARM Cortex-A53 64-bit application processor, a 600MHz dual-core real-time ARM Cortex-R5 processor, a Mali400 embedded GPU and rich FPGA fabric. It is ready to run Linux OS and targets a wide variety of applications like the Internet, cloud computing, Data center, Machine Vision, Military facilities, Flight navigation, etc.
The CPU Module has an ultra-compact size measuring only 60mm by 52mm, equipped with XCZU3EG-1SFVC784E MPSoC, 4GB DDR4, 4GB eMMC and 128MB QSPI Flash as well as integrated Ethernet PHY, USB PHY and Intel Power Module to provide control and processing capabilities as a minimum embedded system. Two Samtec 0.5mm pitch 160-pin Razor Beam High-Speed headers are available on the rear of the SoM to allow easy access to 156 user PL I/O pins, 4 PS GTR transceivers with 2 GTR reference clock inputs, 4 PL GTH transceivers with 1 GTH reference clock input and PS MIOs.
MYIR also offers a versatile platform MYD-CZU3EG Development Board for evaluating the MYC-CZU3EG CPU Module. It takes full features of the XCZU3EG-1SFVC784E MPSoC to have explored a robust set of peripherals such as USB 3.0, Gigabit Ethernet, CAN, TF, DisplayPort (DP), PCIe interface, SATA interface, JTAG, HDMI, LCD interface, ARDUINO User Interface, PMoD, FMC and four SFP interfaces (for EV MPSoCs only). The MYD-CZU3EG is a solid reference design for development based on Xilinx Zynq UltraScale+ MPSoC solutions.
The MYC-CZU3EG is priced at $399 and the MYD-CZU3EG is priced at $659
More information about the new products can be found at:
