![MYIR Launched NXP i.MX 8M Mini + Xilinx Artix-7 based ARM+FPGA SoM MYIR Launched NXP i.MX 8M Mini + Xilinx Artix-7 based ARM+FPGA SoM](https://www.electronics-lab.com/wp-content/uploads/2022/11/mycjx8mma7.jpg)
MYIR has launched a powerful and compact ARM+FPGA SoM MYC-JX8MMA7 CPU Module using NXP i.MX 8M Mini quad-core ARM Cortex-A53 plus 400MHz Cortex-M4 processor and Xilinx XC7A25T Artix-7 FPGA. The module takes full advantage of the ARM MPU to provide the powerful multimedia capability for data processing, control, communication, and display, as well as enough FPGA resources for high-speed data acquisition, processing, and AD module expansion.
![](https://www.electronics-lab.com/wp-content/uploads/2022/11/mycjx8mma7bmark.jpg)
![](https://www.electronics-lab.com/wp-content/uploads/2022/11/mycjx8mma7mark.jpg)
Measuring 82mm by 45mm, the MYC-JX8MMA7 CPU Module can operate at industrial temperatures (-40 to 85 degree Celsius). It employs one 0.05 mm pitch MXM 3.0 gold-finger-edge-card connector for interconnecting with MYIR’s standard baseboard of MYD-JX8MMA7 development board or customized baseboards from users, thus providing an interface for the base board to carry out most of the I/O signals to and from the CPU module. In addition, the minimal system has 2GB LPDDR4, 8GB eMMC and 32MB QSPI flash for ARM MPU, 256MB DDR3, and 32MB QSPI flash for FPGA as well as two dedicated PMIC (ROHM BD71847AMWV) respectively for ARM and FPGA.
![](https://www.electronics-lab.com/wp-content/uploads/2022/11/mydjx8ma7bmark.jpg)
![](https://www.electronics-lab.com/wp-content/uploads/2022/11/mydjx8ma7topmark.jpg)
The MYD-JX8MMA7 Development Board is a versatile platform for evaluating the MYC-JX8MMA7 CPU Module. Plenty of peripherals interfaces are carried out to the base board through the gold-finger-edge-card connector including two USB Host and one OTG, one Gigabit Ethernet, two SFP network interfaces, WiFi/Bluetooth module interface, USB 2.0 based M.2 Key B 5G Module interface, LVDS and HDMI display interfaces, MIPI and Parallel CSI interfaces, Audio, one 2 x 20-pin UART/I2C/SPI/GPIO extension header which is compatible with Raspberry Pi interface, etc. MYIR also offers camera modules, RPI COM Module (RS232/RS485/CAN) and LCD modules as options to work with the board to further enhance the board’s functionality.
The MYC-JX8MMA7 CPU Module is shipped with a heatsink mounted by default, and a factory-installed Linux image that can run from eMMC or SD card. The Linux software package and detailed documentation are provided to help users start development easily and rapidly.
MYIR offers commercial and industrial options for the MYC-JX8MMA7 CPU Module. The prices are economical. Discount is to be provided for volume quantities.
More information about the above new products can be found at: http://www.myirtech.com/list.asp?id=702
