![Nano Pulse Control™ 4.5 V to 36 V Input, 5 A Integrated MOSFET Single Synchronous Buck DC/DC Converter Nano Pulse Control™ 4.5 V to 36 V Input, 5 A Integrated MOSFET Single Synchronous Buck DC/DC Converter](https://www.electronics-lab.com/wp-content/uploads/2021/10/144002636.png)
The BD9F500QUZ from ROHM Semiconductor is a DC to DC Converter with Input Voltage 4.5 to 36 V, Output Voltage 1 0.6 to 14 V, Output Current 1 0 to 5000 mA, Storage Temperature -55 to 150 °C. Tags: Surface Mount, Buck/Step down. More details for BD9F500QUZ can be seen below.
ROHM Semiconductor BD9F500QUZ Nano Pulse Control™ Synchronous Buck DC-DC Converter features built-in low on-resistance power MOSFETs. The BD9F500QUZ DC-DC Converter offers a current of up to 5A and a fast transient response due to the Constant On-Time control system. Additionally, the Light Load Mode control improves efficiency in light-load conditions.
The ROHM BD9F500QUZ Synchronous Buck DC-DC Converter is ideal for reducing the standby power consumption of equipment. The system can control sequence via the Power Good function. The BD9F500QUZ achieves high power density and provides a small footprint on the PCB, all in a small package.
- Single synchronous buck DC-DC converter
- Constant on-time control
- Light load mode control
- Adjustable soft start
- Power good output
- Nano Pulse Control
- Output capacitor-discharge function
- Overvoltage protection (OVP)
- Over-current protection (OCP)
- Short circuit protection (SCP)
- Thermal shutdown protection (TSD)
- Under-voltage lockout protection (UVLO)
- Backside heat dissipation, 0.5mm pitch
- 3.0mm x 3.0mm x 0.40mm VMMP16LZ3030 Package
Specifications
- 4.5V to 36V Input voltage range
- 0.6V to 14V Output voltage range
- 5A (Max) Output current
- 600kHz, 1MHz, 2.2MHz (Typ) Switching frequency
- 40mΩ (Typ) High-side FET ON resistance
- 22mΩ (Typ) Low-side FET ON resistance
- 2μA (Typ) Shutdown current
- 20μA (Typ) Operating quiescent current
more information: https://www.rohm.com/products/power-management/switching-regulators/integrated-fet/buck-converters-synchronous/bd9f500quz-product
