![Nebra AnyBeam, world’s Smallest pocket-size Laser Projector Nebra AnyBeam, world’s Smallest pocket-size Laser Projector](https://www.electronics-lab.com/wp-content/uploads/2019/04/AnyBeam-Front-Left-1.png)
Nebra Ltd company has launched the world’s smallest pocket-sized projector called “Nebra AnyBeam”. The Nebra AnyBeam is a low cost, high definition laser pico projector that can fit in your pocket. For movie lovers, there can be a movie night every night! It is the world smallest pocket cinema projector – with the ability to project crystal clear pictures on to any surface. The device can be powered by a power bank, or from the USB port of a computer.
The Nebra AnyBeam is different from traditional projectors which tends to be big, hot, noisy, use a lot of power, require focus adjustment, and aren’t very portable. The difference is possible through laser and high-speed two-dimensional scanning by adopting the MEMS scanner. The Nebra AnyBeam projects a high-resolution image of HD (720p at 60 Hz) by reflecting the three color laser by high-speed driving of the MEMS mirror and scanning the horizontal and vertical two-dimensional directions.
The Nebra AnyBeam adjust the focus automatically, unlike the conventional projectors where you need to adjust the focus manually. It makes use of a laser that travels straight and hardly spreads. It also always takes into account the distance, the unevenness of the projected surface, and the curved surface, so it is always in focus. Worthy to note is that as it utilizes a MEMS scanner, it requires no bulb. By exploiting semiconductor lasers of three colors R, G, and B as light sources, the projector displays a wide color gamut and colorful images. The 19 by 60 by 103mm and 140g projector fits in your pocket. The device is equipped with a state-of-the-art laser module with the power to project screens up to 150 inches and beyond. The laser MEMS technology at the core of the Nebra AnyBeam projector range is very light and compact.
The power consumption of the Nebra AnyBeam is as low as 3.0 W, which makes it “power friendly,” and can be used for a long time with a power bank/battery. It also features a screw thread in the base for you to add a tripod. There are four key products in the AnyBeam projector range – allowing you to use the laser projector technology in a number of ways which suits your application. With HDMI compatibility feature, your Nebra AnyBeam projector is compatible with virtually every streaming audio, video or gaming service available. With the Raspberry Pi versions, you can set up your own Kodi / OSMC home cinema set up in a matter of seconds – with a built-in projector. The laser projector is fanless, noiseless and you don’t need to replace the bulb.
The specifications include:
- Resolution: 720P/60FPS
- Contrast: 80,000:1
- Aspect Ratio: 16:9
- Brightness: 30 ANSI (Equivalent to 150 ANSI lumens in a standard DLP Projector)
- Operating Temperature: 5oC to 35oC (41F to 95F)
- NEBRA ANYBEAM
- Size: 103 x 50 x 19mm
- Weight: 133g
- Speaker Power: 1 Watt
- Audio Output: 3.5mm audio jack
- Input Interface: HDMI (v1.4 HDMI female connector)
- Input Voltage/Current: DC 5v/1.5A
- Mounting: Standard 1/4-20 UNC tripod mount
- Navigation: Multi-way switch
NEBRA ANYBEAM HAT
- Size: 65 x 57 x 31mm
- Weight: 79g
- Input Interface: DPI over 40pin GPIO header
- Input Voltage/Current: Raspberry PI GPIO Header or 5v/2.5A microUSB
- Navigation: 3 switches
NEBRA ANYBEAM DEV KIT
- Size: 95 x 65 x 15mm (assembled)
- Weight: 86g
NEBRA ANYBEAM MONSTER BALL
- Size: 10 x 10 x 10 cm (10cm sphere)
- Weight: 580g
- Input Interface: via inbuilt Raspberry Pi Zero W
For more information visit Nebra Kickstarter Page.
