NEO Z300-0dB Fanless Mini PC Featuring Intel Alder Lake-N N300 Processor and UHD Graphics
1.095
The NEO Z300-0dB is a compact, fanless mini PC powered by Intel’s Alder Lake-N N300 octa-core processor with Intel UHD Graphics, designed to handle everyday office tasks and web browsing efficiently. Its passive cooling system ensures silent operation, making it ideal for quiet work environments, while its sturdy build helps maintain safe temperatures during prolonged use.
Built for 24/7 reliability, this mini PC offers steady performance, even under heavy workloads, making it suitable for continuous operation. Its anti-static design further protects against electromagnetic interference, enhancing both hardware durability and operational stability.
Previously, we reviewed several fanless mini PCs, including the Mekotronics R57, MeLE PCG02 Pro, ASUS Mini PC PL64, Topton M4, and others. Feel free to explore these products if you’re interested.
NEO Z300-0dB PC
The NEO Z300-0dB mini PC specifications:
  • CPU: Intel core I3-N300 Octa-core processor up to 3.8GHz, 6MB cache, TDP: 7W
  • GPU: Intel UHD Graphics up to 1.25 GHz, 32EU
  • Memory: Up to 16GB DDR4 RAM with 3200 MHz SO-DIMM memory, upgradeable up to 32GB
  • Storage
    • Up to 512GB M.2 PCIe 3.0 x 4 NVMe SSD, upgradeable up to 4TB
    • 1x eMMC 5.1 TF slot
  • Display
    • 2x HDMI 2.1 4K@60Hz
    • 2x independent displays supported
  • Audio
    • 2x HDMI 2.1
    • 3.5mm Audio output jack
  • USB
    • 2x USB-A 3.2 Gen2
    • 1x USB-C 3.2 Gen2
    • 2x USB 2.0
  • Networking
    • 1x RJ-45 2.5Gbps Ethernet port
    • 802.11ax dual bank wifi 6 (2.4GHz/5GHz)
    • Bluetooth 5.2
  • Miscellaneous
    • Power button
    • Reset button
  • Power supply: DC 12V – 19V input via power jack (12V/4A power adapter)
  • Dimension: 12.3 x 12 x 4.6 cm
  • Weight: 1.3kg
The NEO Z300-0dB is a fanless mini PC featuring Intel’s Alder Lake-N N300 octa-core processor and Intel UHD Graphics, powered by an upgraded 12V/4A power supply to support its higher energy demands. Pre-installed with Windows 11 Pro, it is built for multitasking across office applications, web browsing, and media playback. Its compact, silent, and dust-resistant design ensures reliable, continuous performance in noise-sensitive environments, making it a dependable solution for everyday computing needs.
The NEO Z300-0dB mini PC is available on Amazon for $339.90 and on the MINIX official store for $396. For more details, please visit the product page.
About Sayantan Nandy
view all posts by sayantan
