![Neousys Announces IGT-30 Series, an Industrial IoT Gateway Optimized for Industry 4.0 Neousys Announces IGT-30 Series, an Industrial IoT Gateway Optimized for Industry 4.0](https://www.electronics-lab.com/wp-content/uploads/2020/04/161365.jpg)
Neousys Technology, a professional rugged embedded computer provider, today announced IGT-30, its latest industrial IoT gateway platform. IGT-30 is powered by Texas Instrument Sitara™ AM3352, validated by AWS Device Qualification Program (DQP), certified by Verizon to operate on their network.
Shipped with pre-installed Debian 9 and equipped with industrial application prerequisites makes IGT-30 series a perfect IoT Gateway for smart manufacturing, environment monitoring, and intelligent transportation.
Support IEEE 802.3at PoE+ PD
IGT-30 series supports PoE Powered Device (PD) mode meaning it can be powered by a LAN cable from a PoE Power Sourcing Equipment (PSE), and at the same time transfer data via this cable as well. The simplified cabling makes IGT-30 series easier to deploy under harsh conditions with steady power supply and data transmission.
Rich Integrated Industrial I/Os
IGT-30 series features one USB2.0 port, two 10/100M LAN ports, one configurable COM port (RS-232/422/485) and an optional CAN bus port (IGT-31D only).
It also features 8 built-in isolated digital input channels that accept discrete signals from various sensors or buttons/ switches, and 2 built-in isolated digital output channels to control actuators and indicators.
Support dual microSDHC
IGT-30 series has dual microSDHC slots, one internal and one external. This design allows users to separate system/ user data and can expedite in OS deployment for mass production.
Applicable to harsh industrial environment
As required by any industrial applications, IGT-30 series has wide-range DC input from 12 to 25 VDC and a wide operating temperature from -25°C to 70°C. In addition, IGT-30 series is in compliance with common industrial certifications such as CE/FCC, shock and vibration. With a compact and rugged design, IGT-30 series is easy to install in a confined environment.
Learn more about Neousys IGT-30 Industrial IoT Gateway: https://www.neousys-tech.com/product/application/embedded-iot-gateway/igt-30-sitara-am3352-arm-based-embedded-iot-gateway
