![New Low-Voltage, High-Side Load Switch New Low-Voltage, High-Side Load Switch](https://www.electronics-lab.com/wp-content/uploads/2019/11/zint.jpg)
Diodes Incorporated has announced the introduction of the AP22913, a 2A single-channel, slew-rate-controlled load switch with true reverse current blocking for high-side load-switching applications.
Single-channel high-side load switches provide an effective way of applying or removing power to a load, particularly to removable peripherals powered through a USB port.
The AP22913A load switch incorporates true reverse current blocking, which removes the normal body diode unwanted current paths to provide a solution to load switching.
With a load current of up to 2A across a wide operating voltage range, the AP22913 is designed to deliver a typical Rds(on) of 92mΩ at 1.5V and 54mΩ at 5.0V. The firm claims this achieves maximum load current handling capacity with a low forward voltage drop.
![](https://www.electronics-lab.com/wp-content/uploads/2019/11/2019-10-01_9-57-062.png)
The turn-on slew rate of the device is controlled internally to provide a soft-start feature for sensitive loads while the device also features an active-high enable input to enable load switching. To ensure true reverse current blocking when disabled and in its off state, the vin and vout terminals are completely isolated internally.
- 1.4V to 5.5V wide input voltage range
- Low on-resistance (X1-WLB0909-4):
- 92mΩ typical @ 1.5V
- 76mΩ typical @ 1.8V
- 56mΩ typical @ 3.3V
- 54mΩ typical @ 5V
- Low on-resistance (SOT26):
- 122mΩ typical @ 1.5V
- 106mΩ typical @ 1.8V
- 86mΩ typical @ 3.3V
- 84mΩ typical @ 5V
- High DC current capability up to 2A
- Truly Reverse Current Block (TRCB)
- Discharging resistor on VOUT when disabled
- 1µA ultra-low quiescent current
- Active-high control pin:
- Minimum 1.1V VIH of ON
- ESD protection:
- 2kV human body model
- 1kV charged device model
- Package:
- X1-WLB0909-4 with backside laminate
- 0.9mm x 0.9mm, 0.5mm ball pitch
- Standard green SOT26
- Totally lead-free and fully RoHS compliant
- Halogen and Antimony free
The AP22913 load switch is designed to operate from 1.4-5.5V and consumes a quiescent current of 1µA, making it suited for 1.8V, 2.5V, 3.3V, and 5V systems. With a maximum load current of 2A, the AP22913 is suitable for applications in smart phones, portable, wearable and medical devices, and navigation devices as well as notebooks and ultra-mobile PCs.
The AP22913 is available in options including the AP22913CN4-7, which is housed in the X-WLB0909-4 package, and the AP22913W6-7, which is available in the SOT26 package, both in 1000 unit quantities.
