![New Phase Locked Oscillators Available in Tape and Reel Packaging New Phase Locked Oscillators Available in Tape and Reel Packaging](https://www.electronics-lab.com/wp-content/uploads/2020/06/526_11_sfs9250c_lf_big.jpg)
High Performance Fixed Frequency PLO at 9.25 GHz
Z-Communications, Inc. announces a new RoHS compliant fixed frequency phase locked loop model SFS9250C-LF operating in the X-band. The SFS9250C-LF is a simple to use plug and play PLO allowing for quick integration. It is designed to produce a fixed signal at 9250 MHz while locked to an external 10 MHz reference oscillator. This remarkable PLO features exceptionally low phase noise of -75dBc/Hz, -92dBc/Hz, and -118dBc/Hz at the 1kHz, 10kHz and 100kHz offsets, respectively.
The SFS9250C-LF is designed to deliver an output power of -3 dBm into a 50 ohm load while operating off a VCO voltage supply of 5Vdc and drawing 90mA and a phase locked loop voltage of 3Vdc while drawing 11mA. This unmatched product features a typical harmonic suppression of -30dBc and spurious suppression of -70dBc. It is housed in Z-COMM’s standard SFS-L1 package measuring 1.0 in. x 1.0 in. x 0.22 in. The SFS9250C-LF is also ideal for automated surface mount assembly and is available in tape and reel packaging.
Features:
- SFS9250C-LF features a typical harmonic suppression of -30 dBc and spurious suppression of -70 dBc
- Delivers an output power of -3 dBm into a 50 ohm load while operating off a VCO voltage supply of 5 VDC and drawing 90 mA and a phase locked loop voltage of 3 VDC while drawing 11mA
- Designed to produce a fixed signal at 9250 MHz while locked to an external 10 MHz reference oscillator
The SFS9250C-LF is a great choice for quick product rollouts, and is well suited for radar applications requiring operation over the temperature range of -40 to 85°C. For further information on this model or any other product from Z-Communications, Inc. please contact our Applications department via email at applications@zcomm.com or call us at 858-621-2700.
