![New T-configuration MOSFET Relay Modules with 1 pA Low Leakage Current New T-configuration MOSFET Relay Modules with 1 pA Low Leakage Current](https://www.electronics-lab.com/wp-content/uploads/2021/09/Omron-T-modules.jpg)
OMRON Electronic Components Europe has introduced new high voltage and high current versions of its T-configuration MOSFET relay modules. The new G3VM T-modules with mechanical and MOSFET relay technology provides an accurate, compact, and long-lasting switching solution with no mechanical contacts.
The new OMRON G3VM-61MT and G3VM-101MT join high isolation G3VM-21MT and feature a load current of 800 mA and 550mA respectively. The electrical load characteristics of the new devices are 800 mA, 60 V for the G3VM-61MT and 550 mA, and 100 V for the G3VM-101MT. The G3VM-21MT features high isolation performance of less than – 30dB at 1 GHz and is rated at 200 mA, 20 V. The unique T- circuit structure that sends most leakage current to the ground leads to the exceptionally low leakage current of just 1 pA or less.
Housed in a compact 5 mm x 3.75 mm x 2.7 mm package, these new modules are surface mounted and are offered in SPST with no configuration required. The devices in the series support accurate measurements in all types of test equipment where mechanical relays have previously been preferred due to their low leakage current.
more information: http://components.omron.eu/Product-details/G3VM-series
