![NIXLER: limited edition nixie tube clock NIXLER: limited edition nixie tube clock](https://www.electronics-lab.com/wp-content/uploads/2020/03/41cbc180e02c9a227aab17a0f4ebce9e_original.jpg)
The NIXLER is being built as an open-source project and designed with the DIYer in mind. I’ve included a USB to UART chip directly on the board making the NIXLER easy to reprogram. This together with the onboard ESP32 microcontroller with wifi/bluetooth, enables full customization. Hook up the NIXLER to your computer, open up the ARDUINO IDE and start modifying the code in order to realize your own version.
Use it as a super cool up/down counter or display values pulled from the web etc. I can’t wait to see what you might want to use it for. An example code will be released together with the NIXLER.
Features:
- 4x IN-12 Nixie tubes – cycles through hours, minutes and seconds
- Two buttons interface – set time(12/24h)/date/year and other functions
- 4x RGB backlight LEDs
- USB-C connector
- Powered from a typical 5v USB wall adapter
- Max 6-watt power consumption
The project is live on kickstarter and has 26 days to go. Pledges start at $199
Login
