Novasom – the SBC manufacturing company, is famous for its two set of product lines, the U-Line for low power IoT devices and M-Line for multimedia processing based applications. Their products are Intel and ARM processors based for different applications and operating systems. Their latest board in the market is the SBC-U1 which is based on the popular ESP32.
The SBC-U1 comes in two main variants. One with the name of Novasom SBC-U1, while the other with Novasom SBC-U1A. They both share almost 100% of the features, processor is a dual-core Tensilica LX6 with speed of 240 MHz and RAM of 384 KBs. It comes along with 4GB flash data storage memory and SD card support of up to 32GB. In terms of connectivity, 802.11 b/n/g WiFi (WiFi 4) and Bluetooth 4.1 LE are available which are aligned with modern versions installed in such products.
With a broad spectrum of temperature stability, it has a good design to be kept in the long run. Temperature range is between -40 to 85C, with such, there is nothing to be worryabout.
Just like other ESP32 based boards, these boards are designed for IoT and Smart devices applications. Power and battery supply are also well optimized according to standards. 5V input, with 0.9 W active consumption is not that much to be worried about. Still, on standby, its consumption lowers down to 0.75mW.
SBC-U1/SBC-U1A board specifications:
- SoC – Espressif Systems ESP32 dual core Tensilica LX6 processor @ 240 MHz, 384KB RAM
- Storage – 4MB flash, micro SD card slot up to 32GB
- Connectivity – 802.11 b/n/g WiFi 4, Bluetooth 4.1 LE
- I/Os – 24-pin 2.54mm pitch header with up to 15 GPIO @ 3.3V, I2C, SPI, 2-ch 12-bit ADC, 2-ch 10-bit DAC, 2x protected inputs up to 30V
- Misc – User LED, RTC
- Power Supply
- 5V inversion polarity protected
- Battery support with a charger circuit
- Consumption – 0.9W operating, 0.75mW in standby
- Dimensions – 37.5 x 31 mm
- Temperature Range – -40 to 85°C
The company claims that its processor is the smallest in size. Adding to it, the functionality it holds compete many big sized boards. In a system of slim design and the general trend for portability, these devices can easily be applied in several domains. The board runs FreeRTOS real-time operating system.
Both Novasom SBC-U1 and Novasom SBC-U1A seemed to have the same set of features, but the Novasom claims to have customization difference in both. Officially, Novasom SBC-U1A is an easy one to configure according to customized needs, header pins and extensions can be re-configured which is the reason behind is its compatibility and the A. While the Novasom SBC-U1 come with baseline specs that a user order for. For someone with plan to have addons, then Novasom SBC-U1A would be the most suitable option. Otherwise, there is no performance or other difference in these both versions.
More information about both devices is available in the products catalog.
