![NUT4NT, Open-Source 4-Channel GNSS Receiver Development Board NUT4NT, Open-Source 4-Channel GNSS Receiver Development Board](https://www.electronics-lab.com/wp-content/uploads/2016/10/NT1065-1.png)
Although the industry of professional satellite navigation systems is limited to experts and large companies, Amungo Navigation is working towards bringing this industry to individual developers, small companies, and startups through its new open source platform “NUT4NT”.
![NT1065 chip](https://www.electronics-lab.com/wp-content/uploads/2016/10/nut4nt-nt1065-alone-jpg-content-body-gallery_jpg_content-body-gallery.jpg)
NUT4NT is a development board which implements NT1065 chip with USB 3.0 interface. NT1065 is a Global Navigation Satellite System (GNSS) receiver designed by NTLab, a fabless microelectronic company. It is the first low-cost low-power RF front-end solution in the world. It also has 4 channels supporting all GNSS systems and bands.
GNSS receivers are electronic devices that receive and process signals from a GNSS satellite. These signals used to provide information about receiver’s position,velocity, and time.
NUT4NT has two different working modes. The first uses dual inputs and acts as a centimeter level precision positioning tool, without the need of high quality antenna. The other mode uses the four inputs and provides an array antenna processing system to simply reduce interference and noise.
![Dual Inputs Mode (Left) - Four Inputs Mode (Right)](https://www.electronics-lab.com/wp-content/uploads/2016/10/dual-4.png)
Hardware and software specifications of NUT4NT:
- Receiver chip: NT1065
- USB 3.0 controller: CYUSB3014
- Clock rate: 10 MHz
- RF inputs: two or four, depending on board option
- RF inputs referred Noise Floor: 1 dB
- ADC resolution – two-bit
- ADC frequency – up to 99 MHz
- Samples transfer – continuous full stream, from 20 to 100 Mbytes/sec
- Power: 5V @ 0.5 A from USB or external adapter
- Size: 70x50x20 mm (early board) / 77x122x25 mm (single board)
- All GNSS systems: GPS, GLONASS, Galileo, BeiDou, IRNSS and future
- All GNSS band: L1/L2/L3/L5, G1/G2/G5, B1/B2, E1/E5 and future
- Four-channel synchronous reception for antenna array processing
- Signal dumper (grabber) software
- Spectrum analyzer software
- NT1065 configuration software
- Supports libusb API
- Supports native Cypress driver API
- Software for Windows, Linux, and potentially all other OS’s with libusb
There are two options of NUT4NT boards, the Early Board and the Single Board.
Early Board is for $399 and there are only limited boards to order through the crowdfunding campaign page. It consists of two separated boards: the base board, which has the USB 3.0 controller, and NT1065 submodule board.
Single Board will be available later as a future plan, and it is said to have only one board instead of two.
![NUT4NT Early Board](https://www.electronics-lab.com/wp-content/uploads/2016/10/Capture.png)
NUT4NT is an open source project. Software sources are available on github and the hardware’s documentation will be available soon.
More information and details about the product with many accessories are reachable on the product crowdfunding page.
