![Ockel Sirius B – Windows 10 Pocket PC Ockel Sirius B – Windows 10 Pocket PC](https://www.electronics-lab.com/wp-content/uploads/2017/12/product_15762_product_shots1_image.jpg)
As the world gets more advanced, technology is getting smaller. Case in point: the Ockel Sirius B Windows 10 Mini-Computer. This pocket-sized PC is powered by an Intel processor and 2GB of RAM, and boasts high-speed built-in WiFi and Bluetooth. Plus, with a wide range of inputs and outputs, you can link with just about any device you want. [via]
What you can do with this mini PC:
- Compute powerfully on the move w/ Intel-powered Windows 10
- Use this pocket-size PC wherever you want by simply plugging into an HDMI display & connecting to a power outlet
- Quickly browse files & open applications with the built-in 32GB flash storage
- Connect to almost any device you want w/ two USB 2.0 ports, an HDMI port, Micro SD card slot, & AUX in/AUX out
- Browse fast & connect wirelessly w/ ease thanks to built-in WiFi & Bluetooth
Specifications
- Operating system: Windows 10
- Processor: Quad core Intel Atom Bay-trail Z3735F processor (Up to 1.83GHz)
- GPU: Intel HD Graphics (16 @ 350 – 1350 MHz)
- RAM: 2GB 1333MHz DDR3
- Storage: 32GB eMMC Flash extended
- Storage support: Micro SD card (max 128 GB), 2 USB hard drives
- Video supported: 1080P, AVI/MOV/MP4/RMVB/FLV/MKV
- Audio supported: MP3, WMA, RA, OGG, WAV, APE, FLAC, AC3, DTS
- Image format support: JPG, GIF, PNG, BMP, TIF
- HDMI 1.4a output up to 1920×1080 60Hz
- 2 USB 2.0 ports
- Micro SD card slot
- MIC input 3.5mm jack
- L/R stereo 3.5mm jack
- DC in jack
- Power: DC 5V 2A
- Dimensions: 123mm x 79mm x 11mm
- Weight: 120 g
- Certificates: CE/FCC/RoHS
- WiFi card: 2.4/5.0GHz
- Bluetooth 4.0
Login
