![onsemi NCP716BC LDO regulator onsemi NCP716BC LDO regulator](https://www.electronics-lab.com/wp-content/uploads/2021/08/onsemiNCP716BCLDORegulator.jpg)
The NCP716BC is a 150 mA LDO Linear Voltage Regulator with a wide input voltage range from 2.5V up to 24 V
The NCP716BC is a 150 mA LDO Linear Voltage Regulator with a wide input voltage range from 2.5V up to 24 V. The device comes in a TSOP-5/SOT-23-5 package and is an extension of the NCP715, NCP716, NCP716B, and NCP718 series, which all feature an input voltage range of up to 24 V. It is a very stable and accurate device with ultra-low ground current consumption and comes with several protection features such as thermal shutdown and current limit protection.
Key features
- Wide Iiput voltage range: 2.5 V to 24 V
- Ultra-Low quiescent current: 3.2 µA typical, 4.7 µA maximum over temperature
- Compact TSOP-5/SOT-23-5 package
- Thermal shutdown and current limit protection
Additional features
- Fixed voltage options available:
- 3.0 V, 3.3 V, 3.45 V and 5.0 V
- ±2% accuracy over the full temperature range
- Noise: 115 μVRMS from 200 Hz to 100 kHz
- Cross-reference and pin-to-pin replacement for TLV704
- Pb-Free, Halide Free
more information: https://www.onsemi.com/products/power-management/linear-regulators-ldo/ncp716bc
Login
