Orange Pi 5 Ultra SBC with Rockchip RK3588 SoC, Mali-G610 GPU, and 6 TOPS NPU for 8K and Edge AI Applications
1.030
The OrangePi 5 Ultra SBC features the Rockchip RK3588 SoC, which boasts an octa-core 64-bit processor with 4 Cortex-A76 cores running at 2.4GHz and 4 Cortex-A55 cores at 1.8GHz, along with an independent NEON coprocessor. Built on an 8nm LP process, it integrates the ARM Mali-G610 GPU, supporting OpenGL ES1.1/2.0/3.2, OpenCL 2.2, and Vulkan 1.2 for robust graphics performance. The embedded NPU offers hybrid computing with INT4/INT8/INT16/FP16 support, delivering up to 6TOPS of computing power, making it ideal for edge computing applications.
The board is available with 4GB, 8GB, or 16GB of LPDDR5 RAM, offering higher data rates and lower power consumption compared to LPDDR4, making it well-suited for large applications and complex 3D games. It also supports 8K display output, combining the power of its octa-core CPU and 8nm process for clear picture quality and smooth performance. Additional features include an eMMC flash socket, Wi-Fi 6E, and Bluetooth 5.3 with BLE support for powerful wireless communication.
Previously, we covered several OrangePi products, including the OrangePi 5 Max, OrangePi 4A, OrangePi 3B V2.1, OrangePi 5 Pro, and OrangePi 3B, all of which share the same form factor. Feel free to explore these products if you’re interested.
Orange-Pi 5 Ultra front
Orange-Pi 5 Ultra specifications:
  • SoC: Rockchip RK3588 (8nm LP process)
    • CPU: 8-core 64-bit ARM processor with Quad Core Cortex-A76 @ up to 2.4 GHz, Quad Core Cortex-A55 @ up to 1.8 GHz with independent NEON coprocessor
    • GPU: Integrated ARM Mali-G610 Built-in 3D GPU fully compatible with OpenGL ES1.1/2.0/3.2, OpenCL 2.2, and Vulkan 1.2
    • NPU: 6 TOPS AI accelerator with support for INT4/INT8/INT16/FP16 mixed operation
    • VPU: 8Kp60 H.265/VP9/AVS2 10-bit decoder, 8Kp30 H.264 decoder, 4Kp60 AV1 decoder, 8Kp30 H.265/H.264 encoder
  • System Memory: 4GB, 8GB, or 16GB LPDDR5 DIMM
  • Storage:
    • eMMC flash socket for 32GB, 64GB, 128GB, or 256GB module or eMMC flash chip soldered on-board (co-lay)
    • 16MB QSPI NOR Flash
    • MicroSD card slot
    • M.2 2280 PCIe 3.0 x4 socket for NVMe SSD
  • Video Output:
    • 1x HDMI 2.1 port up to 8Kp60
    • 4-lane MIPI DSI connector up to 4Kp60
  • Video Input:
    • 1x HDMI 2.1 out up to 8k@60FPS
    • 1x HDMI 2.0 in up to 4k@60FPS
    • 1x MIPI DSI TX 4 Lane
  • Camera:
    • 2x 4-lane MIPI CSI connectors
    • 1x 4-lane MIPI D-DPHY Rx connector
  • Audio:
    • ES8388 audio codec
    • 3.5mm audio jack with headphone and microphone support
    • Onboard MIC
    • Support for HDMI 2.1 eARC
  • Networking:
    • 2.5GbE RJ45 port via RTL8125BG controller
    • Onboard WiFi 6E and Bluetooth 5.3 module (AP6611S) using SDIO 3.0 for WiFi, UART, and PCM for Bluetooth; IPEX antenna connector
  • USB: 2x USB 3.0 ports, 2x USB 2.0 ports
  • Debugging: Debug serial TTL UART included in 40PIN expansion port
  • Expansion:
    • 40-pin header with GPIO, UART, I2C, SPI, CAN, PWM, and others
    • M.2 Key-M socket (PCIe 3.0 x4) for a 2280 NVMe SSDs, or other PCIe 2280 modules (e.g. AI accelerators)
  • Misc:
    • Power and MaskROM buttons
    • Power LED
    • 2-pin 5V fan connector
    • 2-pin 1.25 mm pitch 3V RTC connector for RTC backup battery
  • Power Supply:
    • 5V/5A via USB Type-C port
    • RK806-1 PMU
  • Dimensions: 89 mm x 57 mm x 1.6 mm
  • Weight: 60.5 grams
Orange-Pi 5 Ultra SBC specifications
The OrangePi 5 Ultra SBC offers a wide range of interfaces, including HDMI output, HDMI input, a GPIO interface, USB 2.0, USB 3.0, a 3.5mm headphone jack, a PCIe extended 2.5G high-speed network port, and an M.2 M-Key slot (PCIe 3.0 4-Lane). The M.2 slot supports the installation of NVMe or SATA SSDs, providing versatile storage options.
Similar to the Raspberry Pi 5, the OrangePi 5 Ultra uses a 5V 5A power supply via a USB Type-C input. However, it surpasses its competitor in PCI Express connectivity, offering a full four lanes of PCIe Gen 3 through the M.2 M-Key slot on the underside of the board, compared to the Raspberry Pi 5’s single lane of PCIe Gen 2.
The OrangePi 5 Ultra supports multiple operating systems, including Orange Pi OS (its official operating system), Ubuntu, Android 13, Debian, and more, ensuring compatibility with various development and application needs.
The Orange Pi 5 Ultra is officially priced at $125 for the 16GB RAM variant on AliExpress. On Amazon, the 8GB and 16GB RAM models are listed at $112.99 and $144.99, respectively. For further details, visit the official product page.
About Sayantan Nandy
view all posts by sayantan
