Orbbec and NVIDIA Launch Orbbec Perceptor Developer Kit for Autonomous Mobile Robots
1.070
The Orbbec Perceptor Developer Kit (OPDK) is a new out-of-the-box solution for developing autonomous mobile robots (AMRs). It uses four Gemini 335L Depth+RGB cameras for 360-degree vision, powered by an NVIDIA Jetson AGX Orin system-on-module. This allows the OPDK to handle complex tasks like SLAM and 3D scene reconstruction in dynamic environments such as warehouses and factories. The cameras offer high-precision depth resolution and a wide field of view, while the Jetson AGX Orin provides the processing power needed for AI model inference and other demanding tasks. The OPDK aims to simplify and accelerate AMR development, especially in applications requiring robust vision and navigation capabilities.
Previously we have written about various robotic kits including the High Torque Mini π, the Qualcomm Robotics RB1, and RB2 development kit, the s Makeblock’s premier DIY robotics and educational kit, and much more feel free to check those out if you are interested in the topic.
Orbbec Perceptor Developer Kit Specifications
  • System-on-Module (SoM):
    • NVIDIA Jetson AGX Orin (64GB)
    • 275 TOPS AI performance
    • CUDA-accelerated libraries and AI models
    • Supports NVIDIA JetPack, Isaac ROS, and AI workflows
  • Cameras:
    • 4x Orbbec Gemini 335L RGB-D Cameras
    • Depth resolution: 1280×800 at 30 FPS
    • Field of View: 4×90° horizontal, 65° vertical
    • IP65-rated for dust and water protection
    • USB connectivity
    • Multi-camera synchronization via Orbbec Sync Hub
  • Depth Processing:
    • In-camera depth processing powered by Orbbec MX6800 ASIC
    • Reduces computational load on external hardware
  • Visual SLAM & Navigation:
    • 360-degree visual SLAM with 4 RGB-D cameras
    • Integrated with NVIDIA Isaac Perceptor for robot control
    • Option for visual odometry (cuVSLAM) or wheel odometry
  • Power & Efficiency:
    • Efficient power consumption for AI applications
    • Reduced GPU/CPU load due to in-camera processing
  • Sync & Mounting:
    • Orbbec Sync Hub for precise camera synchronization
    • 3D printed mounting brackets for camera placement and stability
  • Dimensions: Not Mentioned
The OPDK integrates four Gemini335L Depth+RGB cameras with the NVIDIA Jetson AGX Orin SoM for 360-degree vision. The cameras feature Orbbec’s MX6800 ASIC for in-camera depth processing, optimizing power consumption and reducing computational load, freeing up resources for tasks like SLAM and dynamic object detection.
The company also mentions that Each Gemini 335L camera offers 1280×800 depth resolution at 30 FPS, a wide field of view for 360-degree coverage, USB connectivity, and an IP65 rating for durability in various environments. The Sync Hub coordinates the cameras for precise multi-angle data collection, reducing latency and enhancing 3D mapping accuracy.
The company mentions that the Orbbec Perceptor Developer Kit with PDK and GMSL cameras will soon be available. Further details on pricing are not specified on the product page. Some more additional information can be found on the press release page.
About Debashis Das
view all posts by das
