Osram SPL SxL90A LiDAR QFN Packaged SMT Lasers are infrared high-power SMT components for LiDAR (Light Detection and Ranging) applications. This allows autonomous vehicles to “see” farther and more effectively. The AEC-Q102 qualified four-channel and single-channel pulse lasers offer a performance of 125W at 40A per channel and an efficiency of up to 33%. The single-channel-version (SPL S1L90A_3 A01) offers low thermal resistance of 31K/W, whereas the four-channel device (SPL S4L90A_3 A01) offers just 17K/W. This makes it easy for heat to dissipate from the components even at high currents.
The four-channel version features a chip with four emission areas that deliver an outstanding optical power at 480W. The laser enables a much longer detection range at a size of just 3.35mm x 2.45mm x 0.65mm. This makes it only slightly larger than the single-channel-version of size 2.0mm x 2.3mm x 0.65mm. The two high-power SMT lasers also enable short pulse widths of around 2ns.
- 905nm laser wavelength
- AEC-Q102 automotive qualified
- High duty cycles and low Rth
- 1- or 4-channel pulsed laser modules
- Suited for short laser pulses from 1ns to 100ns
- Up to 480W optical peak power (120W per channel)
- SMT device
more information: www.osram.com
