![Overclocking Raspberry Pi Overclocking Raspberry Pi](https://www.electronics-lab.com/wp-content/uploads/2018/01/Lead-magnet-Eltechs-1-w450.png)
How to overclock the Raspberry Pi device? Don’t matter if you are looking for the way to overclock the Raspberry Pi 3 or overclock the Raspberry Pi 2 – the algorithm stays the same.
The only thing should be taken into consideration is that the Raspberry Pi 3 has significantly improved processor performance compared to previous models. Through various techniques such as overclocking and overvoltage, we can get even more power out of the Raspberry Pi 3. While Raspberry Pi 2 device will always be a little bit behind on performance due to basic technical peculiarities.
Overclocking, basically, is the way to boost Raspberry Pi hardware performance by tuning up several device parameters. For that, additional hardware and special skills are required. Also, you’ll need to implement several tests to make sure of changes to take effect as well as keep your device from damage.
As you have already understood, the overclocking of your Raspberry Pi 3 exercises some risks. What are they and how to avoid them, read in this article on the link.
