Particle Announces M-Series – Multi-Radio Connectivity Solutions with BLE, Wi-Fi, LoRa, and Satellite Support
1.154
Particle recently launched their new M-Series devices, including M-SoM modules and their development boards. These modules are designed to cater to different needs, offering a variety of features to support quick prototyping.
At the time of writing this series is built with three distinct modules and their dev boars: M-SoM LTE-M/2G + Wi-Fi (M404) for North America, M-SoM LTE CAT1/2G/3G + Wi-Fi (M524) for Europe, and M-SoM LTE-M/2G/Satellite + Wi-Fi (M635) for global use.
The series also introduces development boards tailored for different regions, including the Muon LTE-M/2G + Wi-Fi + LoRaWAN Dev Board (MUON404) for North America, the Muon LTE CAT1/3G/2G + Wi-Fi + LoRaWAN Dev Board (MUON524) for Europe, and the Muon LTE-M/2G/Satellite + Wi-Fi + LoRaWAN Dev Board (MUON635) for global applications.
All three M-SoM modules feature a Realtek RTL8722DM MCU that includes BLE and Wi-Fi. Powered by a 200MHz Arm Cortex-M33 CPU, with dual-band 802.11a/b/g/n Wi-Fi on 2.4GHz and 5GHz. They offer 2MB for user applications memory and 3MB of RAM.
The M404 model, for North America, features a Quectel BG95-M5 LTE Cat M1 modem with 2G fallback and integrated GNSS. The European-targeted M524 has a Quectel EG91-EX LTE Cat 1 modem with 2G/3G fallback and GNSS. The global M635 model includes LTE Cat 1 with satellite fallback and GNSS, designed for worldwide use.
The Muon carrier board works with all M-series modules, featuring a LoRa radio, QWIIC connector, and expansion card interface. It has an onboard temperature sensor, EEPROM, a real-time clock, and a watchdog chip. Power options include USB-C, VIN (6-12 VDC), and LiPo battery, plus it has an RGB status LED and Mode & Reset buttons.
Particle M-Series devices Specification:
  • M-Series SoM Options:
    • M404 (North America): LTE Cat M1 with 2G fallback
    • M524 and M635 (EMEAA): LTE Cat 1 with 2G/3G fallback, M635 includes Satellite fallback
    • Global: LTE Cat 1 with Satellite fallback option
  • MCU and CPU:
    • Realtek RTL8722DM MCU for BLE and Wi-Fi
    • Arm Cortex-M33 CPU at 200MHz
  • Form Factor:
    • M.2 SoM, similar to B-SoM
  • Connectivity:
    • Built-in GNSS for location services
    • Dual-band 802.11a/b/g/n Wi-Fi (2.4GHz & 5GHz)
    • BLE 5 with shared antenna for Wi-Fi/BLE
    • Cellular connectivity with variants for specific regions
  • Antennas:
    • PARANTGN1EA/GN1: GNSS antenna
    • PARANTCW1: Certified wide band cellular antenna
    • PARANTWM1: Certified Wi-Fi/BLE antenna
    • LoRaWAN antenna for Muon Carrier Board
  • Memory:
    • 2048KB (2MB) maximum user application size
    • 3072KB (3MB) RAM available to user applications
  • Muon Carrier Board Features:
    • LoRa radio
    • QWIIC connector for easy peripheral addition
    • Expansion card interface
    • Onboard temperature sensor
    • Configuration EEPROM
    • Real-time clock and watchdog chip
    • RGB status LED
    • Multiple power input options: USB-C, VIN (6-12 VDC), and LiPo battery with a temperature sensor (3-pin JST-PH)
    • Mode & Reset buttons for easy operation
Particle’s new devices are now up for pre-order, set to ship in April, and can be purchased individually or as part of a bundle with the carrier board. For a deeper dive into these products, check Particle’s official website.
The pre-order pricing for each model is as follows:
  • M404 (North America, LTE-M/2G + Wi-Fi): $45.95
  • M524 (Europe, LTE CAT1/2G/3G + Wi-Fi): $59.95
  • M635 (Global, LTE-M/2G/Satellite + Wi-Fi): $54.95
  • MUON404 (North America, LTE-M/2G + Wi-Fi + LoRaWAN): $49.95
  • MUON524 (Europe, LTE CAT1/3G/2G + Wi-Fi + LoRaWAN): $69.95
  • MUON635 (Global, LTE-M/2G/Satellite + Wi-Fi + LoRaWAN): $59.95
About Debashis Das
view all posts by das
