![PD Micro – A Pro Micro with USB-C Power Delivery PD Micro – A Pro Micro with USB-C Power Delivery](https://www.electronics-lab.com/wp-content/uploads/2020/03/pdmicro-angle-04_png_project-main.jpg)
PD Micro is the first Arduino-compatible board with USB-C power delivery. The pins are compatible with Pro micro. PD Micro allows you to control high voltage easily from USB-C Power delivery. It’s useful for applications that require voltage higher than 5V – like motor control or a high-power LED.
New USB-C Power Delivery Library
PD Micro is accompanied by our newly-implemented, simple, compact, USB-C power delivery library. This was written over the course of porting the code for PD Micro. We ended up writing a library completely from scratch. The result is a simple, compact, portable source code for USB-C device only application, which can be put inside ATmega328/ATmega32U4.
Specifications:
- Microcontroller: ATmega32U4 running at 5V/16MHz
- Voltage Regulator: TPS62175 DC-DC for efficient 5-20V to 5V
- USB-C PHY: FUSB302 (USB PD communication on CC pins)
- ESD protection on D+/D-/CC1/CC2 pins
- Pinout: (pin compatible to Pro Micro)
- 9x 10-bit ADC pins
- 12x Digital I/Os (INT and I2C bus are shared with FUSB302)
- 5x GND pins
- 3x VBUS pins (USB-C power)
- 1x 5V pin (DC-DC output)
- Status LEDs:
- TX / RX
- 5 LED for Power Delivery voltage level
- 3 LED for Power Delivery current level
- Reset button
- USB-C port for programming and power delivery
- 3.5 mm 2 pos Terminal Jack for power output
- Four layer PCB with ground plane and 3 mm wide VBUS trace
- Size: 1.6 x 0.7 inches (extra 0.3 inches for power connector pins)
Features:
- Set power delivery voltage output level by updating code through Arduino IDE
- New USB Power delivery protocol library for UFP(device):
- Written from draft, not base on any existing library
- Simple, size optimized, more than half of RAM and Code space in ATmega32 are available to user
- Highly portable code
- Fully open source
The project will soon launch on www.crowdsupply.com, stay tuned.
Login
