![PIC Development Board for RS485 & DMX512 Applications PIC Development Board for RS485 & DMX512 Applications](https://www.electronics-lab.com/wp-content/uploads/2017/05/62421e95-6143-417a-ba54-2a0ac70d8320-002-1.png)
This PIC development board has been designed to develop RS485 based and DMX512 applications, the board has 28 pin SMD Pic micro-controller, RS485 chip for communications, all I/O line has pull-up resistor which can be soldered as per application requirement on particular port pins. In-circuit programming of PIC micro-controller can be achieved via a 6-pin header that is compatible with the Microchip PICkit2 or PICkit3. On board 3.3 V and 5V DC regulators allows using 3V and 5V PICS. This board support both 3.3V low power and normal 5V operation, supply selection with jumper closure. All I/O pins supported with parallel GND and VCC header connector for easy interface of any device or sensor and also can be used as address setting jumper by pulling high or low. Important for DMX512 Address.
PIC Development Board for RS485 & DMX512 Applications – [Link]
