![PIC16F628A Programmable Digital Timer PIC16F628A Programmable Digital Timer](https://www.electronics-lab.com/wp-content/uploads/2016/04/TimerOP1.jpg)
Raj Bhatt shared another project with us. This time is a programmable digital timer with relay switch based on PIC16F628A.
Programmable relays find use in numerous automation applications such as automatic street light control, watering and pump control, HVAC, home automation, power plants automation in industries, etc. This article describes how to build a fully functional, one-channel programmable relay switch using the PIC16F628A microcontroller. It allows you to set both ON and OFF time. The maximum time interval that you can set for on and off operations is 99 hours and 59 minutes. Another interesting feature of this project is it offers cyclic option, which means you can choose to run it in a continuous loop of ON and OFF cycles. The device can be programmed through 4 push switches. The programming menu and device status are displayed on a 16×2 character LCD. The timing resolution of this relay timer is 1 minute. The timer also saves the user inputs to its internal EEPROM so that it can retain these values after any power supply interrupt.
PIC16F628A Programmable Digital Timer – [Link]
