AAEON, an industry leader in embedded AI Edge solutions, announces the PICO-WHU4, the latest compact board designed for embedded artificial intelligence, and edge computing. Built on the PICO-ITX form factor and powered by 8th Generation Intel® Core™ Processors, the PICO-WHU4 is a powerful and compact solution for a wide range of applications.
The PICO-WHU4 is built to offer high performance computing in a compact size. It features the 8th Generation Intel® Core™ i3/i5/i7 and Celeron® processors (formerly Whiskey Lake) combined with support for up to 16 GB of DDR4 RAM. This setup provides an impressive level of computing performance on the compact PICO-ITX form factor, allowing the PICO-WHU4 to power many AI and edge computing applications. With a wide operating temperature range from 0°C to 60°C, the PICO-WHU4 is a tough and reliable system for any working condition.
Built to meet the ever-growing demands for embedded AI and Edge Computing, the PICO-WHU4 offers an I/O configuration designed to integrate with almost any embedded application. The PICO-WHU4 features two Ethernet ports, two HDMI ports, and four USB 3.2 Gen 2 ports. The board also features two COM headers, supporting RS-232/422/485 serial port operation.
The PICO-WHU4 is also easy to expand, with an M.2 slot providing support for Wi-Fi and Bluetooth connectivity, and a mSATA/mPCIe slot which can support expansions such as the AI Core X with Intel® Movidius® Myriad™ X. Manufacturer Support from AAEON can also custom configure the PICO-WHU4 to suit customer projects, helping to reduce development time and time-to-market.
The PICO-WHU4 is also available as a turn-key solution, the PICO-WHU4-SEMI compact embedded system. With a compact chassis, the PICO-WHU4-SEMI is built to provide customers a complete system solution which is easy to setup and deploy.
“The PICO-WHU4 is a powerful solution that’s built for the edge,” said Kevin Chiu, Head of AAEON’s Embedded Computing Division. “With compact size and Intel® Core™ processors, the PICO-WHU4 is the perfect solution for vertical markets including Smart Retail applications and Smart City infrastructure.”
more information: www.aaeon.com
