![pixxiLCD series from 4D Systems pixxiLCD series from 4D Systems](https://www.electronics-lab.com/wp-content/uploads/2021/03/pixxilcd-13p2_feature_wgui_2.png)
The new pixxiLCD graphic displays from 4D Systems are the ideal solution for easy integration. Due to the wide range of options offered by the embedded displays, developers can find the right full-color HMI for almost any application. The series is available at Rutronik UK.
4D LABS-configurable PIXXI-28 or PIXXI-44 GPUs enable a variety of functions, including touch detection, microSD or serial flash memory, GPIO and ADC, with multiple millisecond timers, UART and I²C communication.
The displays are offered in different shapes and sizes, such as round (with 1.3’’) or rectangular versions with 2’’, 2.5’’ or 3.9’’. In addition, depending on the requirements of the application, there is a choice option between capacitive and non-touch displays.
The pixxiLCD embedded graphic displays have a standard 15-pin ribbon cable connector in 0.5mm pitch with ZIF socket interface, through which UART, I/O, I²C and the power supply with reset signals are led from/to the display. The 4D Workshop4 IDE developer software, which is compatible with all available pixxiLCD displays, offers extensive possibilities for programming the system.
- 1.3″, 240×240 pixel, slim Intelligent Display Module with embedded PIXXI-28 processor.
- Non-Touch
- IPS Display with Wide Viewing Angles
- Suitable for fast and easy integration of a full colour HMI into any application or product.
- Starter Kits available for first time users.
- See product description below for more details.
more information: https://4dsystems.com.au/pixxilcd-13p2
