![Power ON Delay Switch Power ON Delay Switch](https://www.electronics-lab.com/wp-content/uploads/2016/01/Power_ON_Delay_IMG.png)
Power-ON Delay Switch which can be used in all applications requiring a delay during power-on from 1 to 60 seconds.
Specifications
- Supply input 5 VDC
- Relay output SPDT relay
- Relay specification 5 A @ 250 VAC
- Preset adjustable range function
- Power-On LED indicator
- Screw terminal connector for easy relay output connection
- Four mounting holes of 3.2 mm each
- PCB dimensions 44 mm x 42 mm
Power ON Delay Switch – [Link]
Login
