A Powerful Alternative of ESP8266 Wifi Module
The potential competitor of ESP8266 wifi module will be available next week for just $2!
Pine64, the manufacturer of the first $15 64-bit single board computer, is now preparing to launch “PADI IoT Stamp” RTL8710AF module.
This module has the size of the stamp, a small 24mm x 16mm package with powerful specifications compared to its price.
The Size Compared To A Stamp
Realtek RTL8710 could be a good alternative thanks to its ARM Cortex-M3 processor @ 166 MHz, a little more user memory (48KB), audio support, and faster WiFi performance.
Here are the specifications of the module:
SoC: Realtek RTL8710AF ARM Cortex-M3 @ 83 MHz with 1MB ROM, 512KB RAM, and 1MB flash
Connectivity: 802.11 b/g/n WiFi @ 2.4 GHz – 2.5 GHz (2400 MHz – 2483.5 MHz) with PCB antenna; Station / SoftAP / SoftAP + Station modes
Expansion headers: 22 half-holes with
  • Up to 1x SPI @ 41.5 Mbps max
  • Up to 3x UART with 2x up to 4Mbps, 1x @ 38400 bps
  • Up to 4x PWM
  • Up to 1x I2C @ 3.4 Mbps max
  • Up to 19 GPIOs including 10 supporting interrupts
Power Supply: 3.0 to 3.6V (3.3V recommended)
Power Consumption: 87 mA typ. @ 3.3V using 802.11b 11 Mbps, +17 dBm; 0.9 mA light sleep; 10 uA deep sleep
Dimensions: 24 x 16 mm
Temperature range: -20 ℃ ~ 85 ℃
PADI IoT Stamp Pinout Diagram
With the ability to program the module via IAR, openOCD, and/or J-Link, it also supports firmware updates via UART, OTA, and JTAG.
The processor is said to run FreeRTOS operating systems, which happens to be the one also used in Espressif ESP8266 and ESP32 SDKs. It will also support ARM® mbed™ as a future plan.
More details can be found at the official product page and the module’s datasheet.
Via: CNXSoft
2 Comments
Airhead Bit
One or the other: ARM Cortex-M3 processor @ 166 MHz, a little more user memory (48KB), audio support, and faster WiFi performance.
OR
The RTL-8710 is 83Mhz and the RTL-8711 is 166Mhz
It is true that in the past 4 years, the ESP8266 is the most popular Wifi solution for Makers, the good spec and cheap price make the competitors, such as RTL8710, hard to grow up.
But sometimes plan B is indeed needed. Recently the W600 Arm SoC Wifi solution, released by Winner Micro, I think would be an evenly matched competitor for ESP8266.
