![Programmable CW Morse beacon Programmable CW Morse beacon](https://www.electronics-lab.com/wp-content/uploads/2016/02/beacon-600x196.jpg)
Marko Pavlin has designed a Mini USB dongle with STM32F0xx that is connected to USB and controlled via command line interface.
Mini USB dongle with STM32F0xx is suitable many for simple, mini projects. I attached speaker to Timer14 PWM output (Pin PA6) and LED (or optocoupler connected to PTT) to GPIO pin PA0
The provided software is based on USB Virtual Com Port (VCP) device. The setup is done with command line interface using terminal from any PC. The setup is stored in the internal flash and PC is not required for normal operation. The mini beacon keyer can be used when powered with 5V.
Programmable CW Morse Keyer – [Link]
Login
