SparkFun introduces Qwiic 6DoF IMU breakout board featuring six degrees of freedom IMU
SparkFun 6DoF IMU breakout board
Colorado-based embedded electronics specialist, SparkFun, has released a compact Qwiic 6DoF IMU breakout board powered by STMicroelectronics ISM330DHCX. The ISM330DHCX is a system-in-package with a high-performance 3D digital accelerometer and gyroscope tailored for industry applications.
The ISM330DHCX’s fundamental parameters are remarkable, delivering wide bandwidth, ultra-low noise, and a selectable full-scale acceleration range of ±2 to up to ±16g. Furthermore, the 3D gyroscope has an angular rate range of ±125 and goes up to ±4000 dps, and it provides excellent stability over time and temperature in addition to having extremely low noise. The implementation of smart and complex sensor nodes that provide great performance at incredibly low power is made possible by an unparalleled collection of embedded features such as a machine learning core, programmable FSM, FIFO, sensor hub, event decoding, and interrupts.
The ISM330DHCX chip features four operating modes:
  • Mode 1: This is the “peripheral only” mode by default, and it allows you to use either I2C or SPI.
  • Mode 2: This mode provides an additional I2C port controlled by the 6DoF; up to four external sensors can be added to the device’s I2C controller interface.
  • Modes 3 and 4: An additional SPI serial port is offered for connecting external devices (i.e. camera module) in addition to the basic I2C peripheral interface. However, Mode 3 is only accessible for the gyroscope, but Mode 4 is available for both the gyroscope and the accelerometer.
SparkFun 6DoF IMU breakout board in use
No soldering is required to connect the Qwiic 6DoF IMU to the rest of your boards because it connects by default through I2C using our convenient Qwiic Connect System. However, for customers who prefer a soldered connection, the manufacturer routed the I2C signals out to a set of 0.1″-spaced pins.
The board, with its compact design, aims to simplify applications such as platforms, optical images, lens stabilization, robotics, industrial automation, navigation systems, and vibration monitoring and correction. The chip also has an inbuilt pedometer, a temperature sensor, and a self-test mechanism to make sure the gyroscope and accelerometer components are complying.
On the software side, the manufacturer provides a simple Arduino library to get you started reading data from the ISM330DHCX. You only need to search for “SparkFun Qwiic 6DoF – ISM330DHCX” in the Arduino Library Manager tool to install the library. The library can be obtained from the GitHub Repository for users who wish to manually install it.
SparkFun Qwiic-compatible breakout board is priced at $24.95 which can be ordered from the official product page. The manufacturer has also provided a hookup guide on the website.
Polyhex launches DEBIX Model A – an industrial single-board computer
DEBIX Model A single-board computer
Polyhex Technology has rolled out the DEBIX Model A, an industrial-grade single-board computer powered by an NXP i.MX 8M Plus quad-core Cortex-A53 processor. To target industrial automation, IoT, and multimedia applications, the hardware integrates a 2.3 TOPS neural processing unit with expandable storage.
DEBIX Model A single-board computer comes with 2GB of LPDDR4 memory and a microSD card for storage. The company claims it can also be upgraded to 4GB or 6GB of RAM and can optionally handle up to 64GB of eMMC storage. A LoRa board compatible with the DEBIX Model A as well as an I/O extension board are also offered by Polyhex, opening up countless possibilities. To operate effectively in a harsh environment, the hardware has industrial-grade components and a CPU temperature range of -40°C to 105°C. It provides powerful network control of peripherals in industrial control, industrial automation, and IoT by combining the Gigabit network, 2.4G and 5G Wi-Fi, and Bluetooth 5.0.
Specifications of DEBIX Model A single-board computer
  • SoC: NXP i.MX 8M Plus
  • CPU: A quad-core Cortex-A53 clocked up to 1.6GHz frequency
  • NPU: An integrated neural processing unit (NPU) that delivers up to 2.3 TOPS.
  • Memory: 2GB LPDDR4 and optional 4GB and 6GB
  • Storage: 1x microSD card with optional 8GB up to 128GB eMMC
  • Wireless connectivity: Dual-band 2.4GHz and 5GHz Wi-Fi and Bluetooth 5.0
  • Display: 1x HDMI, 1x LVDS single & dual channel 8-bit, 1x MIPI-DSI interface
  • Camera: 1x 4-lane MIPI-CSI interface
  • Audio: 1x headphone and microphone combination port
  • Peripherals: 1x LAN RJ45 port with PoE support, 1x LAN port via 12-pin header
  • USB interfaces: 4x USB 3.0 Host Type-A ports, 1x USB 2.0 OTG Type-C port
  • Expansion: 40-pin headers with 3x UART, 2x I2C, 2x SPI, 2x CAN, 6x GPIO, 1x PCIe, support PCIe x1 FPC socket
  • Power supply: DC 5V/3A via USB Type-C port
  • Dimensions: 85×56 mm
DEBIX Model A single-board computer image
Along with these additional features, the processor comes with dual cameras, numerous serial ports, and multi-network interaction. Its video encoding and decoding skills, as well as network capabilities, make it suitable for building monitoring systems. The manufacturer makes it easy to integrate with many industrial projects, like truck safety systems, object identification systems, industrial control, and warning systems.
You can use hardware in a variety of applications that use AI to detect objects, accurately locate positions, and develop centralized control and processing systems. Talking about software support, the model is compatible with Android 11, Yocto, and Ubuntu operating systems. The
The DEBIX Model A is commercially sold for £130.26 incl. VAT (approx. $144 USD) on Okdo. More details on the technical specifications of the DEBIX Model A single-board computer are available on the official product page.
Meet DeskPi Super6C – a standard mini-ITX motherboard with up to Six Raspberry Pi CM4 Modules
DeskPi Super6C is a standard mini-ITX board designed to help users with learning cluster applications or distributed Machine learning computing under the vast ecosystem of Linux, cloud-native and Raspberry Pi.
The cluster board which can take up to six Raspberry Pi CM4 modules is now a close competition with the Turing Pi 2 mini-ITX cluster board launched some months ago. They both have the same form factor but the Turing Pi2 can only accommodate up to four Raspberry Pi CM4 modules. The Super6C also has its modules inserted horizontally which gives it a slimmer design than the Turing Pi2.
The board features 2x 1 Gbps RJ45 network interfaces,  3x 12V fan interfaces, 1x on/off switch, 1x reset button, 2x HDMI interfaces for the multiple displays, 2x power supply options for the users and rich PC case front panel headers. Each module on the board has its own peripheral interfaces to help enhance its functions such as a micro USB 2.0 connector, a TF card, an M.2 slot, and a 5V fan interface. The modules also communicate with each other through an onboard 1Gbps switch and each gets its own IP address.
Specifications of the DeskPi Super6C include:
  • SOM Support
    • Has support for up to 6x Raspberry Pi Compute Module 4 (CM4) with or without eMMC
  • Display
    • 1x HDMI 2.0 output
    • 1x HDMI 1.4a (connect to Primary CM4)
  • Network
    • 2x GbE RJ45 LAN ports
    • GbE switch to interconnect all 6x SOMs
  • USB Interface
    • 2x USB-A 2.0
    • 2x Host 2.54 Pins (connect to primary CM4)
    • 6x MicroUSB 2.0 (one for each CM4)
  • Fan
    • 6x 5V FAN header (one for each CM4)
    • 3x 12V FAN header
  • LED / Reset Button
    • 6x LED indicators
    • Onboard ON/OFF and Reset Button
  • Booting Options
    • eMMC, SD card, or the network.
  • Expansion
    • 6x M.2 2280 slots (one for each CM4)
    • 6x TF card slot (one for each CM4)
  • Power
    • 19V to 24V / 100W DC
    • 12V ATX power supply
  • Dimension
    • 170 mm x 170 mm x 21 mm (Mini-ITX)
Applications
The DeskPi Super 6C can be used to:
  • handle a MySQL or Postgres database
  • install an Apache server
  • program and manage resources in Linux
  • make and manage your own cloud services
  • script in BASH, Python, and other scripting languages
  • Turn cluster nodes’ resources into one superior server (supercomputer) with the help of simultaneous processing software
  • learning concepts of distributed Machine learning apps
More Details
The board is currently available and sells on three different sites: Seeedstudio and Deskpi online stores sell for $199 while Amazon sells for a much higher price of $249.
More useful details on the cluster board including schematics and setting up instructions can be found on GitHub.
Banana Pi BPi PicoW-S3 ESP32-S2 Board Launches for $5.5
SinoVoip Co, the company behind some of the most recent microcontroller boards including the Banana Pi BPi Leaf-S3, has just launched a new Banana Pi’s BPI-PicoW-S3 low-power board designed for IoT development.
The $5.50 IoT board is based on Espressif System ESP32-S3 MCU – a dual-core XTensa LX7 processor capable of running at 240 MHz and integrated with 512 KB internal SRAM, 2.4 GHz WiFi 4 and Bluetooth 5 connectivity. The board also features an on-chip 320 KB RAM, one micro USB slot, up to 27x GPIOs, one Neopixel LED, one temperature sensor, a wide variety of interfaces and support for Arduino and Micropython.
The new Banana Pi BPi Pico W-S3 board looks like one of Raspberry Pi’s full-fledged mini PCs, the Raspberry Pi Pi Pico W IoT board launched earlier this year. You can call take them as perfect alternatives to each other especially as they have almost the same size and shape despite being powered by different processors. The Banana Pi Pico W-S3 measures 51.88 by 21.03 mm while its Raspberry Pi variant measures 51.3 by 21 mm — close enough to be roughly interchangeable in hardware applications.
Here are some of the key features and specifications of the BPi Pico W-S3 Board:
  • Processor: 32-bit ESP32-S3 dual-core Tensilica LX7 up to 240 MHz
  • On-chip 384 KB ROM
  • On-chip 320 KB RAM
  • Onboard 2MB Flash ROM
  • On-chip 8MB PSRAM
  • 2.4 GHz 802.11 b/g/n WiFi 4
  • Bluetooth 5.0 and Bluetooth Mesh with long-range support, up to 2Mbps data rate.
  • Support for 8-bit to 16-bit DVP image sensor interface
  • Support for 8-bit to 16-bit parallel RGB
  • 1x micro USB
  • Up to 27x GPIOs including 8x 14-bit PWM, 18-bit analog inputs, 14x Touch, 2x MCPWM, 3x UART, 4x SPI, 2x I2C, 2x I2S, and 1x SDIO host interface
  • 1x Neopixel LED
  • 1x Temperature Sensor of -20°C to 110°C
  • 40 MHz external crystal
  • Secure boot and flash encryption
  • Power: 3.3V to 5.5V; 10uA
  • Operating Temperature: -40°C to 85°C
  • Dimensions: 21 mm x 51.88 mm
  • Operating System: ESP-IDF, Arduino, Micropython
The table below shows how the Banana BPi Pico W-S3 compares with the Raspberry Pi Pico W and the Banana Pi BPi Leaf-S3:
Further details on the Banana Pi BPI-PicoW-S3 board are available on AliExpress where the board is currently selling for $5.50. The board ships for an extra $10 for customers in the United States and $6 for those in South East Asia.
Zynq UltraScale+ MPSoC System on Modules for LiDAR
LiDAR has emerged as an essential remote-sensing technology for many scientific and military applications. It provides high-resolution & accurate measurements of 3D structures, easily convert the received data into 3D maps to interpret the surrounding, and remains unaffected even in even in challenging weather and lighting conditions.
The adaptability of Zynq UltraScale+ MPSoC to support LiDAR technology
The Zynq UltraScale+ MPSoC devices enable an adaptive SoC-based product design, which is extremely promising for LiDAR application implementation. Integrating both the processor and FPGA architecture into a single device allows rapid deployment of a flexible yet optimized solution for any given domain.
The programmability of FPGA provides a great deal of flexibility in developing custom capabilities for the product. Also, FPGAs have the potential to speed up processing by employing multi-level parallelism.
The Zynq UltraScale+ MPSoC series combines real-time control with soft and hard engines for graphics, video, waveform, and packet processing. As a result, MPSoC devices are powerful and flexible enough to deliver advanced capabilities for Lidar sensors: signal processing, point cloud pre-processing, and point cloud machine learning acceleration. Additionally, Zynq MPSoC devices are well known for being power efficient, which is critical for LiDARs.
Why use an SoM approach to build LiDAR products
Using a System on Module approach for building LiDAR products provides significant benefits by offloading several complexities involved in the design cycle. A product designer can focus on developing firmware and software stacks by eliminating the complex hardware part of the design. Which significantly reduces time to market with reduced product development costs.
Furthermore, a System on Modules provides enormous scalability and flexibility to a designer when migrating to a higher computing SoM without changing the design of a carrier card.
Zynq MPSoC System on Module features for lidar
The Zynq UltraScale+ MPSoC SoM features the heterogeneous ARM + FPGA architecture and provides a robust combination of the processing system (PS) and programmable logic (PL).
  • The PS contains a quad-core ARM Cortex-A53 processor operating at up to 1.5GHz and a real-time processing unit equipped with ARM Cortex-R5 processors operating at up to 600MHz
  • PL based on 16nm UltraScale+ architecture that contains up to 504K configurable logic block, Block RAM, and DSP elements
Other benefits include
  • Any-To-Any interfacing
  • Design toolchains
  • Image processing capabilities
  • Accelerate neural network
  • Safety and Security features
Compliance with different interfacing standards is a significant challenge presented by sensor interfacing and processing. A typical solution should have the capability to support high-speed interfaces such as MIPI, JESD204B, LVDS, and GigE to support high-bandwidth sensors such as cameras, RADAR, and LiDAR. Sensor interfacing and processing will also be required to interface with lower-bandwidth sensors that use standards such as CAN, SPI, I2C, and UARTs for accelerometers.
The Zynq UltraScale+ MPSoCs PS and PL support a variety of industry-standard interfaces such as CAN, SPI, I2C, UART, and GigE. The PL I/O flexibility allows for direct interfacing with MIPI, LVDS, and GigaBit Serial Links, allowing for higher levels of protocol implementation within the PL.
By providing the correct PHY in the hardware design, the PL enables any interface to be implemented, providing any-to-any interfacing.
Design toolchains
The Zynq UltraScale+ devices come with Vivado Design Suite to configure the PS and PL design. Vivado provides the complete PL development experience, including the support for synthesis, place & route, and simulation.
Vitis comes into play when it comes to developing software solutions. Vitis supports Embedded Linux development using PetaLinux and real-time operating systems such as FreeRTOS.
In addition to system development capabilities, Vitis supports kernel acceleration within the PL using OpenCL.
Image processing is critical in LiDAR applications for navigation and monitoring. Typically, the algorithms used in these systems are created and modeled in high-level frameworks such as OpenCV.
An H.264/H.265 video codec unit is included in the Zynq UltraScale+ MPSoC EV series to support image processing.
Accelerate Neural Network
Aside from image processing, machine learning is a critical technology for developing automated applications. Machine learning helps classify objects on the highway or observe and monitor occupants.
To enable this, Viti AI provides Model Zoo, AI compiler, Optimizer, Quantizer, and profiler to deploy the application onto the deep learning processing unit.
Safety & Security features
The Advanced Encryption Standard (AES) is used to secure the configuration of Xilinx devices.
The Zynq UltraScale+ MPSoC devices further implement layered security solutions via configuration security unit (CSU) within the PS. The CSU supports AES 256-GCM, 4096 RSA Multiplier, and SHA-384, providing confidentiality, authentication, and integrity functions.
Anti-tamper response through the inbuilt system monitor enables the customer to track device voltages and die temperatures of the SoM.
Scalability across the iWave Zynq MPSoC SoM
iWave offers an extensive portfolio of System on Modules for Zynq UltraScale+ MPSoC series ranging from ZU4 to ZU19 variants. These modules serve a variety of industries, including high-end industrial, military, and defense.
In terms of logic density, I/O availability, number of transceiver lanes, and high-speed DDR design, these System on Modules provides excellent scalability for end applications. Thus, a designed carrier board can cover multiple I/O ports for a wide range of end products, from ZU4 with 192K logic cells to ZU19 with up to 1.1 M logic cells.
More information ZU7/ZU5/ZU4 Zynq UltraScale+ MPSoC SoM can be found here.
For more information visit – https://www.iwavesystems.com/platform/xilinx/
LattePanda 3 Delta – The Fastest Pocket-sized Windows 11/Linux Single Board Computer
Introduction
The growing adoption of IoT technology and related products has caused a corresponding growth in the market of single-board computers. In the past few years we have seen several SBC market manufacturers flood the market with different makes and types of boards, so much so that with the number of single-board computers available now in the market, an average maker/hobbyist may get confused trying to select the perfect SBC for a particular project.
To simplify decision-making for readers, our reviews help spotlight top-of-the-line products/tools that we have enjoyed using, and for this article, in the spirit of selecting some great SBCs of 2022, we’ll be taking a short review of the new LattePanda 3 Delta Single board computer designed by a Chinese electronics manufacturer (DFRobot) who had earlier released two generations of the LattePanda single board computer with Intel CPUs. Due to the fact that there has been a high-speed development in science and technology within the last few years, the LattePanda Team saw the need to develop a new product with the latest technology so as to meet the demands of current and future user scenarios, and well, from what we saw with the LattePanda 3, they didn’t do badly with that at all.
Loaded with improved features and capabilities, the LattePanda 3 Delta is the most user-friendly and cost-effective product that the company has ever made. The board is actually claimed to be the world’s smallest pocket-sized hackable computer poised to define a new era of computing and drive mega creativity for tech innovations.
When compared with its predecessors, we discovered that the LattePanda 3 Delta was designed to be faster in all aspects to allow abundant creativity and superfast smooth performance.
Package Includes:
  • 1 x LattePanda 3 Delta
  • 1 x Active Cooling Fan (Assembled)
  • 1 x 45w PD Power Adapter (with EU & US Standard Power Cord)
  • 2 x Dual-band Antenna
  • 1 x RTC Battery (Assembled)
  • 1 x User Manual
  • 1 x Activation Code Card (Windows 10 IoT Enterprise) – optional
Thermal Profile
The LattePamda 3 Delta features
  • 2x CPU performance: Unlike the previous versions which run on a Celeron N4100 processor, the LattePanda 3 Delta ships with Intel 11th generation Celeron N5105 processor with up to 2.9GHz burst frequency, making it 2 times faster than the predecessors.
  • 3x GPU performance
  • 2x Connectivity Speed: The single board computer uses WiFi 6 whose transfer speed is up to 2.4 Gb/s, about 2.7 times faster than the WiFi 5 found in the older models.
  • 2x USB speed: The board also uses a USB 3.2 gen 2 port which also happens to be twice as fast as the USB 3.2 gen 1 in others.
  • 2x Memory Performance and 2x Storage Capacity: LattePanda 3 Delta uses up to 8GB of LPDDR4 RAM with 2933 MHz high-frequency and up to 64 GB storage capacity, both of which doubles the performance of previous generations. So, there won’t be any need for additional/external storage in case you want to install more software and data.
  • Addition of a New Cooling Fan to ensure better cooling and sustain the best performance.
  • A More Extensive Display Support for an enhanced viewing experience: LattePanda 3 features a 3-way video output with a customized 12.5-inch 4K IPS touch display support.
  • Up to 42 expandable rich interfaces for true hackability and rich playability, and,
  • An onboard Gigabit Ethernet that allows you to connect to the internet at an extremely high speed.
eMMC vs NVMe Performance
onboard eMMC benchmark
M.2 NVMe benchmark
Highlight features and specifications of the LattePanda 3 Delta:
  • Processor: Intel Celeron N5105 quad-core Jasper Lake processor @ 2.0 ~ 2.9 GHz Quad-Core, Four Thread, 10 watt; Intel UHD Graphics 605 @ 450 – 800 MHz
  • Co-Processor: Microchip ATmega32U4-MU 8-bit AVR Arduino Leonardo compatible microcontroller
  • Memory: 8GB LPDDR4 @ 2933 MHz
  • Storage: 64GB eMMC 5.1 flash, M.2 NVMe or SATA SSD support, microSD card slot
  • Wireless: 1x Dual-band 802.11ax WiFi 6 @ 2.4/5 GHz, 1x Bluetooth 5.2, 1x GbE, optional 4G or 5G modem via M.2 socket plus SIM card slot
  • Audio: Microphone plus Headphone combo connector
  • Display: 1x HDMI 2.0, 1x DisplayPort via USB Type-C port, 30-pin 2-lane eDP connector, Up to 3x independent displays
  • USB: 2x USB 3.2 Gen 1 Type-A, 1x USB 3.2 Gen 2 Type-A, 1x USB Type-C for power and data (480 Mbps), 1x USB 2.0 header
  • GPIO: 12x analog Inputs, Up to 23x Digital Input/Output (7 PWM), 1x UART, 1x I2C, 1x SPI, 1x Audio connector, 1x 4-pin header for power and switch, 1x 4-pin 1.25mm PWM 5V Fan port, 1x 4-pin RS232
  • 1x M.2 M Key, PCIe 3.0 2x, 1x M.2 B Key, PCIe 3.0 1x
  • NVMe SSD support, USB 2.0, USB 3.0 support
  • RTC with CR927 coin-cell battery, Reset Button, Watchdog
  • Security: TPM 2.0
  • Power: USB PD input; 12V DC input
  • Dimensions: 125 mm x 78 mm x 16 mm
  • Operating Temperature: 0°C ~ 75°C
Windows 11 & Linux Support
LattePanda 3 Delta maintains almost the same pinout and layout as its predecessors to allow for effortless system migration or upgrade. It is also worth mentioning that the LattePanda 3 Delta has support for Windows 11, alongside Windows 10 and Linux Operating System.
Video loading Win 11
Usage and Applications
Being an optimum development tool for creative developers, talented and eager individuals, LattePanda 3 Delta will find its usefulness in a wide range of applications in:
  • IoT Edge
  • Smart factory
  • Home Automation
  • Robotics
  • Handheld devices
  • AI localization
Pinout
What’s more? The LattePanda 3 Delta is going to be readily available across the globe as the Team also announced that it’s working hand in hand with Global electronic components distributors to ensure that the product choice for the board is passed on to customers in a quick and easy way.
“LattePanda Team is so proud to cooperate with the global electronic components distributors for this joint launch. It delivers an exciting message to our customers that they can gain fast, easy access to our high-performance and hackable LattePanda 3 Delta anywhere in the world,” said Sandy Zhang, CMO of the LattePanda Team. “Our collaboration will ensure even higher levels of customer service.”
The LattePanda 3 Delta currently sells for $279, for the model that comes with an unactivated version of Windows 10 and $339, for the one with an activated version of the Windows 10 IoT Enterprise
Documentation and more
More useful details about the LattePanda 3 Delta including getting started guides are available on the documentation website.
Useful Links:
You can also check the product page or the company’s blog post for details.
Geniatech XPI-3566 single-board computer follows the Raspberry Pi form factor
Geniatech, one of the leading OEM/ODM service providers, has announced the release of the XPI-3566 single-board computer that comes in  Raspberry Pi form factor to target retail and interactive applications. This XPI-3566 single-board computer is designed to boost its performance through the powerful Rockchip RK3566 with a Quad-core Cortex-A55 processor clocked up to 1.8 GHz.
The manufacturer offers 2GB of RAM by default, while the eMMC storage capacity is 16GB. On the other side of the board, there is a 64GB SD card slot for additional storage. The XPI-3566 has the same number of USB ports as other SBCs with comparable form factors, including two USB 2.0 ports, one USB 3.0 port, and one USB 2.0 port that solely supports On The Go (OTG) mode. The Geniatech XPI-3566 single-board computer is equipped with Wi-Fi and Bluetooth 4.0 connectivity in addition to a single HDMI port that can output video and digital audio.
Specifications of Geniatech XPI-3566 single-board computer
  • CPU: Rockchip RK3566
  • Processor: Quad-core Cortex-A55 processor up to 1.8 GHz
  • GPU: Arm Mali-G52 2EE GPU
  • Wireless connectivity: Wi-Fi 2.4GHz and 5GHz dual band, Bluetooth 4.0
  • Memory: 2GB and optional 1GB, 4GB, and 8GB
  • Storage: 1x microSD card and 16GB of eMMC storage with options of 8GB, 32GB, and 64GB
  • Interfaces: 1x GbE RJ45 port
  • Display: 1x HDMI up to 4Kp60 and 1x MIPI DSI
  • USB ports: 1x USB 3.0 Host, 2x USB 2.0, 1x USB 2.0 OTG
  • Expansion: A 40-pin header with up to 28x GPIOs
  • Power supply: DC 5V/3A (via USB Type-C)
  • Dimensions: 85x 55 mm
Geniatech XPI-3566 single-board computer image
For interfacing, MIPI-CSI and MIPI-DSI for camera and display, respectively, allow developers to further build robust, next-gen applications. Furthermore, 28 programmable GPIOs are accessible via a 40-pin header at the top of the board. When it comes to software, this hardware supports Android 11 and Debian10, yet there is no documentation for this board.
This credit card-sized, high-performance single-board computer is a DIY product designed specifically for teenagers. However, Geniatech has not released pricing or availability information. For more information on XPI-3566 SBC head to the official product page.
TB-RK1808M0 features Rockchip RK1808K SoC equipped with 3.0 TOPS AI Accelerator
Since the Rockchip RK1808 SoC series was released about three years ago, this is the first time we will see the chip being used in the mPCIe form factor, despite always finding its way into several single-board computers. Toybrick TB-RK1808M0 offers a more recent version of the Rockchip RK1808 SoC (RK1808K) with 1GB RAM, and 8 GB eMMC flash in a mini PCIe form factor.
Being the first from the company to be fully dedicated to artificial intelligence applications, the RK1808 SoC series features an NPU with an accelerator delivering up to 3.0 TOPS, a dual-core Arm Cortex-A35 processor which allows it to run Linux, 1GB RAM, and 8GB eMMC flash.
The RK1808K happens to be almost similar to the RK1808, except that it is qualified to operate with a much wider temperature range. Check the road map here to get an insight into the Rockchip processor history
The mini PCIe module does not seem to follow a standard footprint pinout, so it may not be possible to use it in a mini PCIe socket from any board. Carrier boards with USB or PCIe x1 were made available instead.
Features and Specifications of the Toybrick TB-RK1808M0 Include:
  • CPU: Rockchip RK1808K Dual-core Cortex-A35 processor running at up to 1.4 GHz
  • AI Accelerator: 3.0 TOPS NPU for INT8 inference (300 GOPs for INT16, 100 GFLOPs for FP16), Support for TensorFlow, Caffe, ONNX and Darknet models.
  • VPU: 1080@60 H.264 decode, 1080@30 H.264 encode
  • 1GB of DDR system memory
  • 8GB eMMC flash
  • Mini PCIe edge connector with USB 3.0, USB 2.0, UART and GPIO
  • Heatsink for cooling
  • Power supply input: 3.3 V @ 1 A
  • Dimensions: 51 mm x 30 mm
  • PCB: 8-layer board design, gold deposition process
  • Temperature range: -20°C to 85°C
  • Software: Debian 10
Compared with similar boards like the Google Coral development board which sells for around the same price but comes equipped with a MediaTek MT8167S quad-core Arm Cortex-A53 SoC, double the size of the RAM, and with 4 TOPS Google Edge TPU, one would realize that the Toybrick TB-RK1808M0 is really not a tough match for them, but, it can serve as a really good alternative particularly now when the Google board seems not to be available checking through from all known vendors.
The mini PCIe module also comes preinstalled with optimized Debian 10 and other system software libraries required for AI development such as RKNN, MPP, and RGA.
Further details on the TB-RK1808M0 board can be found on AliExpress where it currently sells for $93 or for $128 if you are buying it with either a mini PCIe to USB 3.0 or mini PCIe to PCIe carrier board (shipping included). You would also find other useful resources like the hardware files and Linux images here.
Smart Bee Designs’ Bee S3 ultra-low power development boards is an affordable option
Smart Bee Designs' Bee S3
US-based Smart Bee Design LLC provides an ESP32-S3 powered ultra-low power development board for home applications and hobbyist use cases. Inside the hardware platform is an Xtensa LX7 microcontroller that lets users build low-power projects at a very affordable cost of only $10.00 USD. However, the board is currently sold out and interested people are requested to join the waitlist, more of them will be available soon.
Espressif ESP32-S3 is a new AIoT-designed system-on-chip that features a dual-core Xtensa LX7 microcontroller that is capable of running up to a clock frequency of 240MHz. The hardware also comes with integrated 2.4GHz wireless connectivity– IEEE802.11b/g/n Wi-Fi and Bluetooth 5. With a rich set of peripherals, the ESP32-S3 has 45 programmable general-purpose input/output ports.
Specifications of Smart Bee Designs’ Bee S3:
  • CPU: Espressif ESP32-S3 microcontroller
  • Processor: Dual-core XTensa LX7
  • Memory: 512kB of internal SRAM
  • Wireless connectivity: Integrated 2.4 GHz 802.11 b/g/n Wi-Fi and Bluetooth 5 (LE) connectivity
  • GPIOs: 45x programmable GPIOs
  • Serial communication: SPI, I2S, I2C, and UART
  • Power: Ultra-low power and battery voltage monitoring built-in
  • LED: RGB led
  • Interface: USB Type-C interface port
  • Software: Supports Arduino, MicroPython, and Circuit Python
Smart Bee Designs' Bee S3 Pinout
For any advanced system-on-chip, artificial intelligence acceleration is very important. Espressif ESP32-S3 has support for vector instructions in the microcontroller which provides acceleration for neural network computing and signal processing workloads. Engineers and developers can leverage these vector instructions through ESP-DSP and ESP-NN libraries for better optimization of specific applications.
In terms of security, ESP32-S3 provides necessary security protocols for building applications without requiring any external security. The hardware platform supports AES-XTS-based flash encryption, RSA-based secure boot, digital signature, and HMAC. These security features enable the user to implement functions in a trusted-execution environment.
Recently, Arduino IoT Cloud released support for more Espressif microcontroller devices, which also includes the latest ESP32-S3 system-on-chip. This means that Smart Bee Designs’ Bee S3 can now be remotely monitored and managed through Arduino IoT Cloud.
BBC launches a new Web Python Editor for micro:bit
BBC Web Python Editor
BBC micro:bit has announced the release of a new web Python editor that will let young developers from educational institutions build applications, breaking entry-level barriers. BBC’s Make It Digital initiative launched micro:bit educational program to allow young school students to explore the world of digital transformation through an embedded ecosystem. The Python editor is designed for young people to learn programming skills for various embedded applications.
The Micro:bit Educational Foundation took 18 months to develop a Python editor that will address the barriers users can face in working with text-based languages by creating a more user-friendly, creative, and intuitive learning experience. The free access is given in multiple languages, including English, French, Japanese, Korean, and Spanish. This will help school students to get hands-on experience with programming lessons.
“To truly address the digital skills gap – and the digital diversity gap – we need to remove the barriers that surround learning text-based languages,” commented Lucy Gill, Product Manager at the Micro:bit Educational Foundation.
Some of the interesting features that come with the cloud-native web Python editor are drag-and-drop code examples, code structure and error highlighting, auto-complete, a simulator, and quick ideas to get started. Drag and drop is my favorite feature as it lets the students easily discover examples that can be dragged into the code to make a new logic function.
The BBC also has a list of projects developed in Python programming languages, searchable by computing topic, level, and micro:bit features. There are a total of 74 projects developed in Python programming language that cover many device features, including accelerometer, buttons, compass, LED display, sound, radio, light sensor, temperature sensor, speaker, pins, microphone, and many more.
“With over six million of our devices in use globally, we have been able to draw on a broad scope of insights and data to redefine how we teach Python and make it more accessible to a broader spectrum of users. This is purpose-designed to make the step up from beginner feel far smaller and to bring code to life with a physical device, keeping learners more engaged and motivated.”
To get hands-on experience with the all-new web Python editor, head to the official page and start your programming journey.
TOP PCB Companies
