Crocus Technology 0A to 65A Integrated Current Sensors
Crocus Technology 0A to 65A Integrated Current Sensors have a 1MHz Bandwidth and better than 1% accuracy. The sensors feature high-speed operation and accurate output to optimize system design for smaller sizes and higher efficiency. The XtremeSense TMR sensor is a design solution that combines high bandwidth response and high accuracy.
  • Supports AC and DC
  • Resolution (SNR) <10 mARMS
  • Common mode field rejection
  • 1MHz bandwidth
  • High accuracy (up to ±0.5%)
  • Up to 5kV isolation
  • Over-current detection
more information: https://crocus-technology.com/products/integrated-sensors/
S-19720 Series Automotive Voltage Tracker
ABLIC’s automotive voltage tracker contributes to high-accuracy sensing
ABLIC’s S-19720 is a voltage tracker with a low offset voltage of ±5 mV. This helps keep the power supply voltage of the off-board ratiometric sensor equal to the reference voltage (VREF) of the analog-to-digital converter (ADC) handling ECU measurements, raising sensor reading accuracy.
The S-19720 also integrates an overcurrent protection circuit, a thermal shutdown circuit, and a reverse current protection function. As a result, it will protect an ECU even in the event of a short to power/short to ground in a wire harness. The S-19720 achieves low current consumption during power-off of 4 µA (typical) when this function operates.
  • Input voltage: 4.0 V to 36.0 V
  • Offset voltage: ±5 mV (0.1 mA ≤ IOUT ≤ 50 mA)
  • Dropout voltage: 160 mV typ. (VADJ/EN = 4.0 V, IOUT = 10 mA)
  • Current consumption:
    • During operation: 30 μA typ.
    • During power-off: 4.0 μA typ.
  • Output current: Possible to output 50 mA (VIN = VADJ/EN + 2.0 V)*1
  • Input capacitor: A ceramic capacitor can be used (1.0 μF or more)
  • Output capacitor: A ceramic capacitor can be used (1.0 μF to 1,000 μF)
  • Built-in overcurrent protection circuit limits overcurrent of output transistor
  • Built-in thermal shutdown circuit with detection temperature of +175°C typ.
  • Reverse current protection function: IREV = -5 μA min. (VIN = 0 V, VADJ/EN = 5.0 V, VOUT = 16.0 V)
  • Operation temperature range: TA = -40°C to +125°C
  • Lead-free (Sn 100%), halogen-free
  • Withstand 45 V load dump
  • AEC-Q100 qualified
more information: https://hub.ablic.com/en/products/s-19720
BMI323 Inertial Measurement Unit
Bosch Sensortec’s low-power six-axis IMU is ideal for mobile applications
Bosch Sensortec’s BMI323 is a general-purpose, low-power inertial measurement unit (IMU) that combines precise acceleration and angular rate (gyroscopic) measurement with intelligent on-chip motion-triggered interrupt features. The six-axis IMU comprises a 16-bit triaxial gyroscope, a 16-bit triaxial accelerometer, and a 16-bit digital temperature sensor in a miniature 2.5 mm x 3.0 mm x 0.83 mm (14-pin) LGA package.
Applications
  • Notebooks and tablets
  • Wearable devices such as smartwatches and sports and fitness devices
  • Game controllers and smart remote controls
  • Toys and gadgets
more information: https://www.bosch-sensortec.com/products/motion-sensors/imus/bmi263/
PAN1770 – Bluetooth 5.1 Low Energy (LE) module
The PAN1770 is a Bluetooth 5.1 Low Energy (LE) module based on the Nordic nRF52840 single-chip controller that allows you to attach an external antenna via uFL. The Bluetooth 5.1 features additionally a higher symbol rate of 2 Mbps using the high-speed LE 2M PHY or a significantly longer range using the LE coded PHY at 500 kb/s or 125 kb/s. The new channel selection algorithm (CSA#2) improves the performance in high interference environments. Furthermore, the new LE advertising extensions allow for much larger amounts of data to be broadcasted in connectionless scenarios.
An output power of up to 8 dBm and the high sensitivity of the nRF52840 in combination with the LE-coded PHY make the module very attractive in applications, where a long range is required. In addition, the ultra-low current consumption of the PAN1770 makes the module an ideal choice for battery-powered devices. With the Cortex ® M4F processor, 256 kB RAM and the build-in 1 MB flash memory the PAN1770 can easily be used in standalone mode, thereby eliminating the need for an external processor, saving complexity, space, and cost. The rich set of security features from the ARM TrustZone CryptoCell 310 security subsystem provide the necessary means for secure device operation in the IoT space. The PAN1770 also supports Type 2 Near Field Communication (NFC-A) for use in simplified pairing and payment solutions (external antenna required).
  • Bluetooth 5.1 (Long Range, 2Mbps PHY)
  • ARM® Cortex®-M4F (64MHZ) with 1 MB flash memory and 256 kB internal RAM
  • Includes ARM® TrustZone® Cryptocell 310 and supports secure boot including Root-of-Trust
  • New channel selection algorithm (CSA#2) improves the performance in high interference environments
  • Up to 48× General Purpose I/Os (GPIO), which are shared by up to 4× SPI, 2× I²C, 2× UART, 4× PWM, 8× ADC, NFC-A, 32 kHz IN/OUT, nRESET
  • USB 2.0 full-speed device interface
  • REACH and RoHS Compliant
  • Over-the-air update of application software
  • Surface Mount Type (SMT) 15.6 mm x 8.7 mm x 2.05 mm
  • Typical max. output power 8 dBm, configurable from -20 dBm in 4dB steps
  • Sensitivity -95 dBm @ 1 Mb/s and -103 dBm @ 125 kb/s
  • Current consumption of 4.8 mA in TX (@ 0 dBm) and 4.8 mA in RX mode
  • On-module DC-DC and LDO regulators with automated low current modes
  • Voltage range: 1.7 V to 5.5 V
  • Typical current consumption: 0.4 μA in System OFF mode, 1.5 μA with RTC wake up
  • Temperature range: -40 °C to 85 °C
  • Certified Antenna list
more information: https://industry.panasonic.eu/products/devices/wireless-connectivity/bluetooth-low-energy-modules/pan1770-nrf52840
ZOTAC Announces a Powerful Portable PC with Extremely Small Form-Factor – ZBOX PI336 pico
ZBOX PI336 pico Kit
The Global Manufacturer of Innovation, ZOTAC Technology recently announced a range of products including the ZBOX PI336 pico, the smallest full-fledged PC, a wearable PC, the new thinnest professional workstation, and a series of powerful graphic cards.
The new ZBOX PI336 launched by ZOTAC Technology enables users to uncover endless possibilities on the go with the power of an Intel Celeron N6211 dual-core processor with 4K capabilities and the all-new Windows 11.  It is one of the smallest full-fledged PCs available on the market. It allows the users to exploit the features of a full-scale PC in a compact enclosure having a form factor of 115 x 76 x 20.7 mm.
Intel Celeron running at the heart of ZOTAC ZBox
The ZBOX PI336 supports a simultaneous 4K (Ultra HD) dual display with HDMI 2.0 and DisplayPort 1.4. The Mini PC has onboard 4GB memory and 128GB onboard storage. Moreover, it allows the users to expand their storage through its microSDXC slot.
The ZBOX PI336 provides three USB 3.1 ports (including a type-c port) and a 3.5mm audio jack. Further, the ZBOX mini PC enhances connectivity through its WiFi 6E (6GHz spectrum support) and Bluetooth 5.2. Moreover, it offers a Gigabit Ethernet port that allows it to connect up to speeds of 1000 Mbps.
The ZBOX PI336 comes with multi-tip power adapters enabling users across the globe to exploit the capabilities of this powerful mini PC. Moreover, the PI336 pico features a passive cooling design with no active cooling components, making it more durable and pocket friendly.
Specifications of the ZBOX PI336 pico
  • Intel Celeron N6211 dual-core processor
  • Onboard 4GB LPDDR4x memory
  • Integrated Intel UHD Graphics
  • 60Hz Dual display  – HDMI 2.0 & DisplayPort 1.4
  • 128GB eMMC onboard storage
  • Micro SDHC/SDXC card reader
  • 3.5mm I/O audio jack
  • 3 x USB 3.1 ports (including a type-C port)
  • 10/100/1000 Ethernet port
  • Intel WiFi 6E
  • Bluetooth 5.2
  • Pre-installed Windows 11 OS
“Uncovering Endless Possibilities” with the World’s Smallest Full-Fledged PC
The new ZBOX PI336 pico by ZOTAC Technologies features the capabilities of a full-fledged desktop in an astonishingly small size. With its amazing features, the ZBOX PI336 pico is an “Ideal media hub, security device and digital signage solution at any home, office or workspace”, as stated by ZOTAC on the product page.
Adafruit’s Bluefruit EZ-Link Launches Back to the Market in a New Form
Original Bluefruit EZ-Link Module
After discontinuing the production of the Bluefruit EZ-Link many years ago, Adafruit is trying to bring back the Bluefruit EZ-Link with some exciting modifications to the board, giving it a new form.
The EZ-Link was the most advanced product added to the Adafruit Bluefruit line of products a few years back. The Bluefruit EZ-Link was a regular SPP serial link client device that could pair with any Bluetooth-enabled device (Except iOS). The feature that made it outstand other Bluetooth modules was its ability to dynamically detect and change the serial baud rate automatically. Moreover, the DTR/RTS/DSR flow control pins could automatically sync to the computer serial port.
This ability of the Bluefruit EZ- Link to toggle the DTR pins as desired enabled it to wirelessly program simple microcontrollers (like Arduino) remotely (within the transmission range of Bluetooth protocols). Adafruit claimed it to be a “Wireless FTDI-like cable”.
Bringing back the Bluefruit EZ-Link from dead with enhanced features
Unfortunately, due to some technical and unspoken issues, Adafruit discontinued the production of the Bluefruit line of series. However, recently Adafruit stated about “Bringing it back from the dead” with an Espressif ESP32 pico module. Adafruit claims the new version would have a much smaller form factor than the original one while maintaining the same configuration of pinouts. The board will provide classic Bluetooth support with an improved SDK version. Moreover, the new form of EZ-Link would have an external antenna, further enhancing the range of communication.
Layout of the new Adafruit's Bluefruit EZ-Link
The new EZ-Link will use the hardware UART on the ESP32 for Rx and Tx. The onboard LED is an RGB NeoPixel for displaying the connection status. Further, the pair-button uses the GPIO-0, allowing it to enter the programming mode.
With the plan to restart the production of the Bluefruit EZ-Link with new features, Adafruit has just stated about some of the new features in a recent blog. However, no information has been provided yet regarding the Launch date and pricing. Adafruit has quoted “We’ll see if this works!” at the end of the blog.
Beetle RP2040 Mini Development Board from dfrobot.com
Designed by Raspberry Pi, RP2040 features a dual-core ARM Cortex-M0+ processor with up to 133MHz clock and 264KB internal RAM, and supports USB 1.1 devices, which allows users to focus on function implementation instead of spending too much time and effort on improving codes.
DFRobot Beetle RP2040 is a development board built around the RP2040 chip. It has a compact size of 27mm×20mm, which is easy to be embedded into small devices or projects.
  • RP2040 microcontroller chip designed by Raspberry Pi
  • 2M FLASH storage
  • Small size of 27mm x 20mm
  • Immersion gold pad for easy soldering
  • Support C++, MicroPython, and Arduino C programming
  • 8 GPIO pins, I2C × 1, UART × 2, SPI × 1, digital port × 8, analog port × 2
  • Onboard BLINK_LED light
  • USB TYPE-C interface
  • Work well with USB 1.1 device
The board adopts a beginner-friendly large pad design, effectively reducing the difficulty of soldering. And it provides 8 carefully-selected GPIO ports that can serve as I2C, UART, SPI, digital port, analog port, etc., more convenient and flexible for users to develop various applications.
Specification
  • MCU: Raspberry Pi RP2040
  • Main Frequency: 133MHz
  • RAM: 264K
  • FLASH: 2M
  • Power Supply: DC 3.3V~5V
  • System Level: 3.3V
  • USB Interface: TYPE-C
  • GPIO: ×8
  • I2C: ×2
  • UART: ×2
  • SPI: ×1
  • Digital Port: ×8
  • Analog Port: ×2
  • Reset Button: ×1
  • BOOT Button: ×1
  • LED: ×1
  • USB Device: USB 1.1
  • Programming Method: C++, MicroPython, Arduino C, Mind+ graphical programming
  • Soldering Pad Size: 4×3.5mm
  • Pad Pitch: 2.54mm
  • PCB Material: FR-4
  • PCB Copper Clad Process: immersion gold
  • Solder Material: environment-friendly and lead-free
  • Dimension(without package): 27×20×4.91mm (at the highest point)/1.06×0.79×0.19″
Documents
DOOGEE V30 Series Positioned To Lead the High-end Rugged Smartphone Market with Dimensity 900 Chipset
DOOGEE V series rugged phones are flagship models that carry the most recent technologies of the time. The DOOGEE takes a lot of pride in its V series and designs them to stand out. For example, earlier this year, the DOOGEE V20 5G with an innovative rear display was released to much acclaim and quickly became the most loved and sold the rugged phone.
DOOGEE is preparing the next device in the V series line-up dubbed DOOGEE V30 series. This series includes the V30, V30 Pro, V Max, and V Max Pro models with different price points and slightly different features.
All the models in this series will adopt MediaTek 6nm chipsets with the higher-end V30 Pro and V Max Pro going with Dimensity 900 chipset. V30 series smartphones will be the first and the only rugged phone to sport these processors when they hit the market.
The new MediaTek Dimensity 900 chipset brings extra advantages including Bluetooth 5.2, 4k video recording, encoding capabilities at 30fps, better LPDDR5 RAM, faster UFS 3.1 storage, 120Hz refresh rate, and Wi-Fi 6.
The V30 series also stand out design-wise. The back is covered by a deerskin and a ceramic strip lines the edges. These aren’t typical materials you would expect from phones designed to withstand drops, dunks in water, and withstand extreme weather. But they do add a certain aesthetic value and feel great in the palm. The materials are also lighter, more durable, and improve signal transmission.
This is exclusive, and we are hoping you will be interested in publishing the story first. Attached are some rendered pictures of the V30 series. There is also a screenshot of the side-by-side comparison of the MediaTek Dimensity 900 and Dimensity 700 to see the improvements the V30 series come with.
AAEON’s de next-TGU8 Breaks Through Board Space Limitations in Single Board Computing
In a major breakthrough in single board computing, AAEON introduces the de next-TGU8, the smallest board featuring an on-board Intel® Core™ i-level processor ever created, measuring just 3.31” x 2.17” (84mm x 55mm).
Offering up to 4 cores, with 8 threads, the 11th Generation Intel® Core™ i7/i5/i3/Celeron® Processor (formerly Tiger Lake-UP3) provides the de next-TGU8 with the kind of high-performance power never-before-seen in a board so small.
This power ensures users can utilize the potential of the de next-TGU8’s 16GB onboard LPDDR4x memory and expandability. It has an M.2 2280 M-Key (PCIe [x2]) to enable AI acceleration, Wi-Fi, and 4G modules. The de next-TGU8 also provides an FPC slot for PCIe [x4] Gen 3 with a Riser kit, for additional storage or more advanced graphics options to go along with its Intel® UHD Graphics.
Despite being such a small board, the de next-TGU8 is equipped with a sophisticated interface featuring dual RJ45 ethernet ports, two USB 3.2 Gen2, and four USB 2.0 slots, along with a dual display interface via HDMI and eDP ports.
Because of these features, AAEON believes the de next-TGU8 to be the product to usher in the next generation of edge AI applications in drone and robotics technology.
For more information about the new de next-TGU8, visit its product page or contact an AAEON sales representative.
SolderGO the smart ergonomic soldering iron launches campaign on kickstarter
SolderGO launches comfortable ergonomic smart soldering iron to raise funding for the first production run exclusively on the platform Kickstarter known to bring projects to life.
The SolderGO iron features an easy-to-use, intuitive user interface and OLED display, compact ergonomic size with a full-size tip which is portable and can minimize workbench footprint. The SolderGO provides 72W of power for rapid heat-up time, temperature stability, and thermal recovery with a user-adjustable soldering temperature range up to 450 ⁰C.
The iron is DC powered for portability and can be connected to a mains power supply or various batteries which the iron can detect and protect. Sleep and wake up modes are employed to increase tip life and efficiency. The screen can be flipped for left or right handed use. A large variety of interchangeable tips can handle a range of soldering tasks from standard size to micro components.
The SolderGO iron has been developed with ergonomics and usability in mind, the iron case shape is designed for a comfortable grip between index finger, thumb and middle finger with support in the perlicue area which could alleviate muscle fatigue for long periods of use compared to traditional irons. (Patent Pending)
The company which has been running for 7 years designing and manufacturing drone parts under the brand name MenaceRC has already invested into the SolderGO soldering iron design, production mould tooling, production line setup to limit the risks to Kickstarter backers and to provide the soldering iron on time.
Greg Spencer, Director at Darmill Limited said:
“I am proud to bring the SolderGO iron to the world, it has been developed to be the most comfortable iron in hand and packed with features all at the right price point for hobbyists and professionals”
more information: https://www.kickstarter.com/projects/422909497/soldergo-the-smart-ergonomic-soldering-iron
TOP PCB Companies
