Torex Semiconductor XC6810 Linear Charger IC for Li-ion Batteries
Torex Semiconductor XC6810 Linear Charger IC for Li-ion Batteries comes in an ultra-small (1.17mm x 1.57mm x 0.33mm) WLP-12-01 package that is compatible with wireless charging and contact power supplies. The charging current (1mA to 25mA) provides a wide 3.8V to 4.4V charging voltage range. The XC6810 components are equipped with a shutdown function to suppress battery discharge when stored or not in use and a wake-up function using an external push button, extending the life of batteries and devices. This IC is equipped with a battery voltage monitoring function, which can directly monitor the battery voltage through a microcontroller or a low battery voltage notification function. The Torex Semiconductor XC6810 Linear Charger IC supports wireless power and energy harvester charging such as solar and wearables, hearables, or IoT devices.
  • WLP-12-01 (1.17mm x 1.57mm x 0.33mm) package
  •  Functions
    • Shutdown, wake-up
    • Battery voltage monitor or battery low voltage notification
    • OUT line switch interlocked by UVLO, charge enable
    • Battery temperature monitor
    • Current path/input current limit
  • Protections
    • Battery over-discharge
    • Output short
    • Thermal control
    • Reverse current
    • Safty timer of charging
    • UVLO
  • Lead-free and RoHS compliant
Specifications
  • 3.5V to 28V input range
  • 3.80V to 4.40V charge voltage in 0.05V increments
  • 1mA to 25mA charge current set by an external resistor
  • 110mA input current limit
  • 10nA typical BAT sink current at shutdown
  • -40°C to 85°C operating ambient temperature range
Application Diagram
more information: https://www.torexsemi.com/products/battery-charge-ics/series/?name=xc6810
Titanium Ti60 FPGA Devices
Efinix’s FPGA devices feature innovative Quantum™ compute fabric with enhanced computing capability
Efinix’s Titanium FPGAs are fabricated on a 16 nm process and deliver high performance with the lowest possible power in a small physical size. With a wide range of logic element (LE) densities from 35,000 to 1 million, and compatibility with Efinix’s RISC-V SoC (system on chip) cores, they help turn a tiny chip into an accelerated embedded computing system. The Quantum computing fabric in the Titanium TI60 FPGA is made up of configurable tiles, the eXchangeable logic and routing (XLR) cell that optimizes routing efficiency, and speed while achieving high utilization ratios. The fabric also has highly configurable 10 K embedded memory blocks along with dedicated, high-speed DSP blocks. Together, these features deliver optimum performance for a wide array of applications from edge computing to industrial automation and video processing. The 16 nm process node gives Titanium FPGAs a small footprint with low power consumption, making them ideal for highly integrated applications.
The powerful I/Os of these Titanium devices allow the user to interface to processors or camera sensors with MIPI CSI-2/DSI or traditional LVDS. The high-performance fabric supports processing capability using personalized RTL algorithms or a soft RISC-V processor for a more traditional approach. Combining the two methodologies for RISC-V acceleration or custom instructions allows optimized performance, cost, and power.
The Ti60W64 is unique as it is only 3.5 mm x 3.5 mm and still holds 60,000 logic elements.
For further space constraints, use the system-architected F100 BGA device that includes the same Ti60 as well as configuration Flash and HyperRAM memory. This product is truly a highly configurable SoC.
  • 62,000 logic elements
  • 93 18×19 DSP blocks (“fracturable” to perform smaller multiply functions)
  • 2.62 MB embedded block RAM
  • Four PLLs
  • 146 high-speed I/O (HSIO) pins that can be used for MIPI D-PHY lanes for CSI-2 and DSI TX/RX
  • 34 high-voltage I/O (HVIO) pins for interfacing with 3.3 V interfaces
  • Support for AES-GCM-256 bitstream encryption and RSA-4096 bitstream authentication for secure systems
  • Soft error detection block
  • Footprint: 10 mm x 10 mm (BGA225), 5.5 mm x 5.5 mm (BGA100), or 3.5 mm x 3.4 mm (WLCSP64)
more information: https://www.efinixinc.com/products-titanium.html
SparkFun IoT RedBoard – ESP32 Development Board
from SparkFun.com product description:
The SparkFun IoT RedBoard is an ESP32 Development Board that includes everything but the kitchen sink! Espressif’s ESP32 WROOM is a powerful WiFi and Bluetooth® MCU module that targets a wide variety of applications. At the core of this module is the ESP32-D0WDQ6 chip which is designed to be both scalable and adaptive. The IoT RedBoard can target a wide variety of applications, ranging from low-power sensor networks to the most demanding tasks, such as voice encoding, music streaming, and MP3 decoding. The IoT ReadBoard also utilizes our handy Qwiic Connect System which means no soldering or shields are required to connect it to the rest of your system!
The USB-to-serial is achieved with a USB-C connector with through hole anchoring and the ubiquitous CH340G requiring fewer driver installs. We’ve included 3.3V voltage translation and a Qwiic connector to the edge of the board to allow for quick and seamless connection to our ever-growing line of I2C based Qwiic products. The board even includes a microSD socket if your application requires you to log and save data to a memory card.
The operating system is freeRTOS with LwIP; TLS 1.2 with hardware acceleration is built in as well. Secure (encrypted) over the air (OTA) upgrade is also supported, so that users can upgrade their products even after their release, at minimum cost and effort.
more information: https://www.sparkfun.com/products/19177
VisionFive 2 – open source quad-core RISC-V dev board
High-performance quad-core RISC-V single board computer (SBC) with an integrated 3D GPU, 2G/4G/8G LPDDR
Meet the VisionFive 2
A pioneering development board that combines performance with low-cost and full open-source RISC-V single board computer.
At the core of the VisionFive 2 is The StarFive JH7110 64-bit CPU, featuring quad SiFive U74 1.5GHz cores and comes paired with BXE-4-32 GPU from Imagination Technologies. Our goal was to iron out some of the initial issues with our original design. Whereas the JH7100 had two 64-bit SiFive U74 RISC-V cores running at 1GHz, the JH7110 has four cores running at 1.5GHz.
A larger change from the VisionFive 2’s predecessor is the addition of the Imagination BXE-4-32 graphics processing unit, which will go quite some way into increasing the overall performance for desktop and graphical workloads.
The original VisionFive, unveiled late last year and sold exclusively in 8GB form from March this year, was a strong initial design but not without its troubles: as our testing showed, design flaws in the silicon hampered performance while reliance on an outdated end-of-life operating system — a situation now resolved by Canonical’s recent release of an official Ubuntu Server 22.04.1 image for the board — brought its own difficulties.
StarFive has opened crowdfunding for its second hobbyist-focused RISC-V single-board computer (SBC), the VisionFive 2 — promising a faster device with twice the cores, a GPU, and dual gigabit Ethernet ports.
Designed around the new JH7110, fixing flaws in the original VisionFive, the new VisionFive 2 is available for a lot less money.
Video
more information: https://www.kickstarter.com/projects/starfive/visionfive-2
Femto is a RP2040 12x12mm PCB module
Mirek @ https://github.com/mfolejewski writes:
The main goal and reason to create this project was attempt to design as smallest as possible, and fully functional RP2040 module. Please note, that RP2040 MCU nas 7x7mm package, and Femto module has only a bit more, 12x12mm. In comparision, closer competitiors, such as Raspberry Pi Pico or RP2040 Stamp (Solder Party) have appropriately 51x21mm and 25x25mm.
The project consists of 3 parts:
  • Module (mainboard)
  • frame (solder frame)
  • tester (testbench, only for functional verification)
more information: https://github.com/mfolejewski/FEMTO
DeskPi Super6C Raspberry Pi CM4 Cluster Mini-ITX board 6 RPI CM4 supported
DeskPi Super6C is the Raspberry Pi cluster board a standard size mini-ITX board to be put in a case with up to 6 RPI CM4 Compute Modules.
Highlights
  • DeskPi Super6C is the Raspberry Pi cluster board a standard size mini-ITX board to be put in a case with up to 6 RPI CM4 Compute Modules.
  • 6 RPI CM4 supported 1 Gbps RJ45 x2
  • Onboard ON/OFF and Reset button
  • 12V FAN Header x3
  • DC 19v~24V or ATX 12V
  • Package Includes: 1 x Raspberry Pi CM4 Cluster Mini-ITX board, 1 x 100W Power Supply (Note:Raspberry Pi CM4 board are Not Included)
  • PC Case front panel header
  • 12V FAN Header x3
  • Mini ITX Case supported
For every CM4
  • M.2 2280 slot (PCIe Gen 2 x1)
  • TF Card slot
  • 5V FAN Header
  • Micro USB 2.0
Only for 1st CM4
  •  USB Host A 2.0 x2
  • USB Host 2.54 4-pins x2
  • HDMI 2.0 x1
  • HDMI 1.4a x1
52Pi sells the DeskPi Super6C on their website for $199.99 + shipping
more information: https://deskpi.com/collections/deskpi-super6c/products/deskpi-super6c-raspberry-pi-cm4-cluster-mini-itx-board-6-rpi-cm4-supported
UP Squared V2 – Next generation of UP Squared
UP Squared V2 is the successor to our UP Squared series. Based on the latest Intel® Pentium®, and Intel® Celeron® N and J Series processors (formerly Elkhart Lake), UP Squared V2 offers up to 1.7x better compute performance and twice the performance for 3D graphics with Intel® UHD Graphics for 10th Gen Intel® Processors.
It has been upgraded to 12V standard industrial power input, increased memory options and audio wafer for easily expand the audio mic-in and line out feature. UP Squared V2 offers high performance with low power consumption in a form factor that can fit anywhere.
Hardware overview
  • UP Squared V2 with the Intel® Pentium® Processor J6426 and Intel® Celeron® Processor N6210 (formerly Elkhart Lake)
    • Intel® Pentium® J6426, up to 3.00 GHz
    • Intel® Celeron® N6210, up to 2.60 GHz
  • Intel® UHD Graphics
  • 1x Passive heatsink
  • 1x RTC battery
Expand your UP Squared V2 further with the 40 GPIO having the same connector and pin definition of UP series boards, giving developers freedom to build up their shield. It also designed with M.2 slots to unlock WiFi/ Bluetooth/ AI/ Storage expansion capability. With TPM v2.0 on board, UP Squared V2 has added hardware-based, security-related functions as well.
AAEON is taking pre-orders for the UP Square 2 starting at $161 for the model with a Celeron N6210, 2GB RAM, 32GB eMMC flash, and going up to $323 with a Pentium J6426 CPU, 64GB eMMC flash, and 16GB RAM.
more information: https://up-board.org/up-squared-v2/
Gole1 Pro – Pocket-sized Windows 11 Desktop PC has WiFi 6.0 and a 5.5″ Touchscreen Display
Renowned Chinese PC Manufacturer, HIGOLE; maker of the GOLE 1 mini PC released back in 2016, has released its newest touchscreen mini PC, the GOLE 1 PRO loaded with improved features and capability.
Unlike the GOLE 1 which runs on an Intel Atom x5-Z8300 processor, the GOLE 1 PRO ships with either a dual-core Intel Celeron N4000 or a Quad-core Intel Celeron J4125 processor, both of which, in all ramifications, outperform the performance of the processor on the initial GOLE1.
The GOLE 1 PRO is the world’s smallest touchscreen PC to offer users portability and desktop experience simultaneously as it can be operated with/without a mouse and keyboard thanks to its 5.5-inch display.  The GOLE 1 PRO also features 8GB RAM, 128GB ROM,256GB SD card slot for secondary storage and data transfer along with four USB 3.0 ports and two HDMI 2.0 ports for simultaneous display expansion at up to 4k resolution.
Both versions of the GOLE 1 PRO feature a built-in microphone and speaker for audio function and some difference (asides from the processors) only starts setting in, when you consider their wireless communication features, as the J4125-based device, offers Wifi 6.0 and Bluetooth 5.2,  while the N4000 based GOLE 1 PRO comes with Wifi 5.0 and Bluetooth 5.0. This however takes nothing away from both versions of the device as the communication protocols they support are still very much in vogue and makes GOLE 1 PRO ready for use with all sorts of external devices including projectors, printers, mouse and keyboards, modems, headsets, and speakers, etc., used at home and in the office.
The coolest thing about the GOLE 1 PRO, for me, is the size. It fits into 91.2 x 17.76 x 142mm matte textured metal enclosure which provides it with a built-in radiator plate and doubled layer vent that aids its seamless fanless design for handling processors and other components heat. The enclosure also carries a built-in battery, which according to HIGOLE can power the device for up to 4 hours under average usage conditions, and a type-c port through which the device can be powered/charged with a 12VDC adapter.
Highlight features and specifications of the GOLE 1 Pro are provided below:
GOLE 1 PRO (J4125):
  • Processor:
    • Quad-core Intel Celeron J4125 processor @ 2.0 ~ 2.6 GHz, 10 watt; Intel UHD graphic 60 or
    • Dual-core Intel Celeron N4000 @ 1.1 ~ 2.6 GHz, 6-watt; Intel UHD graphic 60
  • Memory: 8 GB LPDDR4X
  • Storage: 128GB SSD, 1 x 256GB SD slot (not sipped with card)
  • Operating System: Windows 11 (Professional)
  • Display: 5.5-inch touchscreen.
  • Wireless: Wifi 6.0 and Bluetooth 5.2 or Wifi 5.0 and Bluetooth 5.0
  • Audio: 1 x combo MIC, 1 x 3.5mm headphone plug
  • Expansions: 4 x USB 3.0 interface, 2 x HDMI 2.0 ports (supports 4k displays simultaneously), 1 x RJ45 port
  • Power: Built-in battery, 12 DC (external), power button.
  • Dimension and Weight: 91.2 x 17.76 x 142mm, 0.2kg
For OS, the GOLE 1 PRO runs Windows 11 Professional out of the box but also supports Ubuntu and some other Linux distros.
The GOLE 1 PRO is currently available via its crowdfunding page on Indiegogo with a start price of $1,638 (HKD).
More information on the PC and Crowdfunding details can be found on the product IndieGoGo Page.
SkyWater and Google will use $15m Funding to expand an open source chip design project
SkyWater Technology has announced that it will be extending its partnership with Alphabet’s Google, releasing an open source Process Design Kit., for its commercial 90nm, fully depleted silicon on insulator (FDSOI), CMOS process technology. This announcement came shortly after the US chip manufacturer received $15 million in funding from the US Department of Defense (DOD).
“Through this important investment from the DOD and collaboration with Google, we will enable open source design for our commercial SKY90-FD process technology, creating an IP [Intellectual Property] pipeline and pathway to commercial volume manufacturing,” says SkyWater CEO, Thomas Sonderman. “This will expand our 90nm foundry offering as a platform for innovation and productization here in the U.S.”
This is not the first time the duo will be partnering on a project like this; they joined forces together about two years ago to enable the open source design of custom application-specific integrated circuits (ASICs) on SkyWater’s 130 nm mixed-signal CMOS process node. The results of the project so far have been incredible as about 240 designs from the over 364 community submissions have been manufactured.
Speaking on why the US government decided to invest in the initiative, Thomas Sonderman stated that there’s a lot the government stands to get from the output of the development. The US military will have a new way to procure homemade chips in the future.
“We’re hoping that the collaboration is going to address what are really historical limitations of chip design and production, both for national defense as well as commercial markets, because researchers get improved accessibility and developers get to go through that exploration faster and candidly at lower costs,” said Google Public Sector CEO, Will Grannis.
The new platform is for analog-digital mixed-signal chips that we usually see in smart home products. This kind of chip takes advantage of larger transistors for cheaper production.
The partnership among the three represents a new era in accessible chip design driven by an open source approach. According to Matthew Kay, head of the new open-source silicon program at the Department of Defense,
“investments in commercial endeavors such as the partnership between SkyWalker and Google is another example of how the DOD can leverage technology advancement within the open source community to effectively and efficiently improve its defensive posture for the future.”
SkyWater provides the next-generation chip design system and secure fabrication facilities, Google provides the compute and technical know-how, while the $15 million funding from the Department of Defense makes it all scalable and accessible.
The process design kit, a set of files that describe the building blocks of the project, is open source but the fabrication process itself isn’t. Other useful details on this announcement are available on SkyWalker’s page and Google OpenSource Blog.
Oukitel Summer Sale: WP19 World’s Biggest Battery Rugged Phone Selling with 71% Discount
Well-known smartphone brand OUKITEL launched WP19 the world’s biggest battery phone in June, which has gained huge popularity and broke the rugged phone selling record on AliExpress during its global premiere. Thanks to the overwhelming favor and support from our fans, OUKITEL today announces that WP19, this hottest smartphone will be on promotion and offer a massive discount of up to 71% off from 22nd to 26th August PST on AliExpress. Moreover, for the first 30 orders during the summer sale (Aug 22nd-26th),  you can get a WP19 rugged phone at the price of USD $250.99 only.
21000mAh Most Powerful Monster with Night-vision Camera
The WP19 rugged phone is equipped with 21000mAh, the world’s largest battery, which is the best choice for your outdoor adventures. This long-lasting smartphone can support 7 days of daily use. It also comes with 33W rapid recharging, which takes only 3 hours to charge from 0 to 80%. The powerful WP19 is also a portable power bank since its OTG function could enable you to recharge your other devices.
The high-end cameras are another remarkable feature. 64MP SAMSUNG S5K main camera, SONY IMX350 20MP night vision Camera, and 2MP macro camera allow you to shoot professional photos, even taking a nice one with clarity in the evening. With the help of the 4 built-in IR emitters, you could easily find out the potential threat in the darkness.
Massive Display and More Durable Features
This is a 6.79-inch FHD+ display phone with 397 pixels per inch (PPI) and a 90Hz refresh rate. It is the latest Android 12 system. WP19 performs incredibly well in multiple Apps operation and gaming as a result of the MediaTek Helio G95 processor with 8GB RAM and 256GB ROM. Apart from those killing features, the industrial ruggedness with IP68 & IP69K & MIL-STD-810H certified enables it to sustain any tough environment. WP19 also comes with fingerprint & face ID, NFC Google Pay, customized key, etc.
TOP PCB Companies
