TPS7B86-Q1 Automotive LDO Linear Regulator
Texas Instruments’ adjustable regulator features power-good and is designed for powering always-on components in standby systems
Texas Instruments’ TPS7B86-Q1 is a low-dropout (LDO) linear regulator that is designed to connect to the battery in automotive applications. The device has an input voltage range extending to 40 V, which allows the device to withstand transients (such as load dumps) that are anticipated in automotive systems. With a 17 µA quiescent current at light loads, the regulator is an optimal solution for powering always-on components such as microcontrollers (MCUs) and controller area network (CAN) transceivers in standby systems.
The TPS7B86-Q1 has a state-of-the-art transient response that allows the output to quickly react to changes in load or line such as during cold-crank conditions. Additionally, the device has a novel architecture that minimizes output overshoot when recovering from dropout. During normal operation, the device has a tight DC accuracy of ±0.85% overline, overload, and overtemperature. The power-good delay can be adjusted by external components, allowing the delay time to be configured to fit application-specific systems. The TPS7B86-Q1 is available in thermally conductive packaging to allow the device components to efficiently transfer heat to the circuit board.
  • AEC-Q100 qualified for automotive applications:
    • Temperature Grade 1 range TA: -40°C to +125°C
    • Junction temperature range TJ: -40°C to +150°C
  • Input voltage range: 3 V to 40 V (42 V max.)
  • Output voltage range:
    • Adjustable output range: 1.2 V to 18 V
    • Fixed output: 3.3 V and 5 V
  • Power-good with a programmable delay period
  • Output current: 500 mA (max.)
  • Output voltage accuracy: ±0.85% (max.)
  • Low dropout voltage: 475 mV (max.) at 450 mA (VOUT ≥3.3 V)
  • Low quiescent current:
    • 17 µA (typ.) at light loads
    • 5 µA (max.) when disabled
  • Excellent line transient response:
    • Deviation during cold-crank: ±2% VOUT
    • Deviation: ±2% VOUT (1 V/µs VIN slew rate)
  • Stable with a 2.2 µF or larger capacitor
  • Package options:
    • 5-pin TO-252: 29.7°C/W RθJA
    • 8-pin HSOIC-8 with a thermal pad: 41.8°C/W RθJA
more information: https://www.ti.com/product/TPS7B86-Q1
Texas Instruments LDC3114/LDC3114-Q1 Inductance-to-Digital Converter
Texas Instruments LDC3114/LDC3114-Q1 Inductance-to-Digital Converter is an inductive sensing device that enables touch button design for human-machine interface (HMI) on a wide variety of materials. This feature is done by measuring small deflections of conductive targets using a coil that can be implemented on a small printed circuit board (PCB) located behind the panel. This technology can be used for precise linear position sensing of metal targets for automotive, consumer, and industrial applications by allowing access to the raw data representing the inductance value. Inductive sensing solution is insensitive to humidity or non-conductive contaminants such as oil and dirt.\
The button mode of LDC3114/LDC3114-Q1 can automatically correct for any deformation in the conductive targets. The LDC3114/LDC3114-Q1 offers well-matched channels, which allow for differential and ratiometric measurements which enable compensation of environmental and aging conditions such as temperature and mechanical drift. The LDC3114/LDC3114-Q1 includes an ultra-low power mode for power on/off buttons or position sensors in battery-powered applications.
The Texas Instruments LDC3114/LDC3114-Q1 is easily configured through an I2C interface. The LDC3114/LDC3114-Q1 is available in a 16-pin TSSOP package. The LDC3114-Q1 devices are AEC-Q100 qualified for automotive applications.
  • Multiple modes of operation
    • Raw data mode: access pre-processed inductance measurement data to enable advanced algorithms on MCU for linear sensing
    • Button mode: button press detection with baseline tracking and advanced on-chip post-processing
  • Force level measurement of touch buttons
  • Pin and register compatible with LDC2114
  • Robust EMI performance allows for CISPR 22 and CISPR 24 compliance
  • Four independent channel operation
  • Configurable scan rates
    • 0.625SPS to 160SPS
    • Continuous scanning option
  • Advanced button press detection algorithms
    • Adjustable force threshold per button
    • Environmental shift compensation
    • Simultaneous button press detection
  • Low current consumption
    • One button: 6µA at 0.625SPS
    • Two buttons: 72µA at 20SPS
  • Temperature range
    • TSSOP (16): –40°C to +125°C
  • Interface
    • 1.8V and 3.3V compliant I2C and INTB
    • 1.8V logic output per channel for buttons
Block Diagram
more information: https://www.ti.com/product/LDC3114-Q1
Infineon Technologies MOTIX™ BTN9990LV Motor Control IC
Infineon Technologies MOTIX™ BTN9990LV Motor Control IC contains one p-channel high-side MOSFET and one n-channel low-side MOSFET with an integrated driver IC in one package. The interfacing to a microcontroller is made easy by the integrated driver IC and the EMI is minimized due to the p-channel high-side switch. This integrated driver IC features logic-level inputs, slew-rate adjustments, diagnosis with current sense, dead time generation, protection against overtemperature, undervoltage, overcurrent, and short circuit. The MOTIX™ BTN9990LV IC provides a cost-optimized solution for protected high current PWM motor drives with very low board space consumption. Typical applications include automotive 12V brushed DC motor, seatbelt pre-tensioner, seat control, fuel pumps, power liftgate, sliding door, and HVAC control module.
  • Integration of high power PMOS, NMOS, and driver IC minimizes design and manufacturing effort
  • 8V to 18V (max up to 40V) supply voltage range
  • 5.3mΩ @ 25°C path resistance (typical) (max 9.6mΩ @ 150°C)
  • 3.3µA @ 85°C low quiescent current (max)
  • 75A (min) overcurrent detection level
  • Protection features:
    • Overcurrent
    • Undervoltage
    • Overtemperature
  • Higher system reliability due to integrated diagnosis, current sense, and protection functions
  • 8 selectable switching slew rates for optimized EME
  • Status flag diagnosis with feedback of current sense, temperature, and slew rate
  • Less PCB area and BOM compared to a discrete solution
  • Supports half and full-bridge (2x) configuration
  • AEC-Q100/Q006 qualified (grade 1)
Application Circuit
more information: https://www.infineon.com/cms/en/product/power/motor-control-ics/brushed-dc-motor-driver-ics/single-half-bridge-ics/btn9990lv/
DIGI ConnectCore® 8M Nano System-On-Modules (SOM)
DIGI ConnectCore® 8M Nano System-On-Modules (SOM) are designed for industrial reliability and the 10+ year product lifecycles of embedded devices. These SOMs feature up to 4x power efficient Arm® Cortex®-A53 cores and 1x Cortex-M7 core that minimizes power consumption while maintaining a high standard of performance. The 8M Nano SOMs feature TrustFence® for critical security and data privacy capabilities, XBee® integration, and Remote Manager® for remote monitoring and management. These SOMs operate at -40°C to 85°C temperature range, -50°C to 125°C storage temperature range, and 5%RH to 90%RH (non-condensing) relative humidity range. The 8M Nano SOMs are used in a wide range of industrial, medical, agricultural, transportation, Internet-of-Things (IoT), Human-Machine Interface (HMI), edge computing, and machine learning.
  • Peripherals/interfaces:
    • 1x USB 2.0 OTG controllers with integrated PHY interfaces
    • 3x Ultra Secure Digital Host Controller (uSDHC) interfaces
    • 4x Universal Asynchronous Receiver/Transmitter (UART) modules
    • 4x I2C modules
    • 3x SPI modules
    • 1x Quad SPI
    • 10x PWM channels
    • 1x 16-bit ADC module with accurate internal voltage reference, up to 20 channels
    • 5x Synchronous Audio Interface (SAI) modules supporting I2S, AC97, TDM, codec/DSP, and DSD interfaces
    • 1x S/PDIF input and output, including a raw capture input mode
    • 8-channel Pulse Density Modulation (PDM) input
    • Up to 112 GPIOs
  • Power management with both hardware and software support for low-power designs
  • Application processor:
    • NXP® i.MX8 Nano
    • Up to 4x Cortex-A53 cores at 1.4GHz
    • 1x Cortex-M7 core 600MHz core for real-time processing
  • Memory:
    • Up to 8GB eMMC, up to 1GB of LPDDR4 (16-bit)
  • Security:
    • Digi TrustFence®, TRNG, TrustZone, secure RTC, secure JTAG, and secure element
  • Seamless cellular modem and Digi XBee® integration
  • Bluetooth 5 support
  • 1×1 802.11a/b/g/n/ac dual-band wireless Wi-Fi
  • 1x 10/100/1000M Ethernet + AVB
  • -40°C to 85°C industrial operating temperature range
  • 5%RH to 90%RH (non-condensing) relative humidity range
more information: https://www.digi.com/products/embedded-systems/system-on-modules/i-mx-8m-nano-som
Instrumems Launches Into Flow Sensor Market With a Breakthrough Multi-sense Solution
Instrumems announced its formal entry into the flow sensor market with a breakthrough solution that offers multi-sense capabilities. The company is an innovative spin-off of Princeton University research developed by Professor Marcus Hultmark and Dr. Gilad Arwatz. Instrumems was founded to advance flow sensing capabilities and broaden adoption into more markets such as medical, IoT, and industrial applications. Instrumems’ product is a multi-sense solution that is the first-and-only to measure accurate flow and temperature, including very low flow, using a single sensor. The company is also expanding capabilities of the physical sensor by using real-time edge computing with advanced algorithms.
Instrumems’ platform is ideal for low-power applications that require real-time sensing in respiratory devices, such as CPAP machines, smart inhalers, and ventilators. Its multi-sense solution is also optimal for thermal management and instrumentation that requires precise flow measurement. Instrumems plans to announce expanded support for additional sensing parameters, such as bubble detection and gas detection.
The flow sensor market is estimated to be approximately $7.5 billion. Demand for airflow sensors is growing across industrial automation and end-user industries, including automotive, data centers, healthcare, medical devices, building automation, food and beverage, and more.
Instrumems’ vision is to bring smart sensing solutions to any device by digitizing data and providing real-time flow sensor visibility and control in areas previously impossible. Products that require flow sensors face many constraints, including form factor, battery life, cost, speed, and sensor accuracy. Today’s flow sensors are exorbitant and bulky, making them uneconomical and inadequate to adopt into consumer products or high-volume applications.
“There’s no other combined temperature and flow sensor in the market today that is as small, low power, fast, and economical as Instrumems’ multi-sense flow solution. Our sensing technology opens the door for a multitude of industries to integrate cutting-edge flow sensors into places previously unworkable due to cost, accuracy, and form factor,” said Gilad Arwatz, Instrumems’ founder and CEO. “Our innovative sensing technology enables customers to modernize, miniaturize, or reinvent their products to be more competitive and aesthetically appealing.”
Instrumems executive team brings expertise in several areas, including flow control, high-precision nano sensors, fluid mechanics, and microelectronics design and development. The executive team includes CEO Gilad Arwatz, who holds a Ph.D. in Mechanical and Aerospace Engineering from Princeton University. Gilad is a serial entrepreneur, having founded other startups in IoT, smart packaging, and AdTech. Vice President of Operations, Ashish Shah, is responsible for developing a high-volume supply chain and project management. Sun Choi serves as Vice President of Business Development and is responsible for expanding into new markets. Instrumems has raised $4 million in seed funding from IP Group and PeopleFund.
Instrumems has an evaluation kit available to demonstrate its flow and temperature sensing and can quickly customize the sensor’s packaging to fit a range of applications. Interested parties can contact info@instrumems.com
more information: www.instrumems.com
FWS-2277: Compact Network Solution for Small Office Deployments
AAEON, an industry leader in network white box solutions, announces the FWS-2277 compact desktop network appliance. Not much larger than typical consumer-grade network switches, the FWS-2277 delivers the performance and functionality to bring network functions to Small Office/Home Office (SOHO) deployments, including Unified Threat Management (UTM), VPN, and Next-Generation Firewall (NGFW).
With many offices and businesses incorporating Work from Home and Small Office network deployments, many service providers are in search of a compact solution that can power modern network functions while remaining unobtrusive and within their clients’ budgets. The FWS-2277 solves this by delivering exactly the features needed to power SOHO networks, in a compact platform that avoids the trend of carcinization most routers and appliances seem to follow these days.
The FWS-2277 is powered by the Intel® Celeron® N3350 processor (formerly Apollo Lake) with built-in Intel® AES-NI, providing data encryption that is secure with faster processing than standard AES. The FWS-2277 features two Gigabit LAN ports, and is certified for wireless networks including Wi-Fi (11a/b/g/n/ac 2Tx2R) and Bluetooth (V5.0 LE). The system also features HDMI and two USB ports to connect and control directly.
With a rugged metal chassis and exactly the features needed to power small networks, the FWS-2277 is perfect for deploying remote access VPN networks to home offices and other small networks, with its two LAN ports to connect to the internet and a desktop PC or network switch, and the Wi-Fi enabling mobile devices like laptops and tablet PCs to join the VPN network.
“By focusing on the exact needs for SOHO deployments without any unwanted extras, the FWS-2277 delivers a spartan package that is budget friendly while still delivering the tools and performance needed to deploy secure and reliable networks,” said Caridee Hung, Product Manager with AAEON’s Network System Division. “The compact design makes it even easier for service providers to deploy and set up, allowing wide area networks to be deployed quickly.”
AAEON offers a range of industry-leading services and support to ensure users get the exact product they need. From technical support to help accelerate deployment and ensure long-lasting reliable service, to customization support including OEM/ODM services.
more information: https://www.aaeon.com/en/p/desktop-network-appliance-sd-wan-intel-apollo-lake-fws-2277
Infineon Technologies BTG7090-2EPL PROFET™ Load Guard
Infineon Technologies BTG7090-2EPL PROFET™ Load Guard is a smart high-side power switch, providing protection functions and enhanced diagnostic capabilities. The BTG7090-2EPL is equipped with adjustable overcurrent limitations to offer high reliability for protecting the system. This feature ensures that PCB traces, connectors, and loads are protected in case of a short circuit to ground. The BTG7090-2EPL also has a capacitive load switching mode implemented to charge big capacitive loads and reduce current peaks during switch-on of capacitors. With these features, the device addresses different use cases for intelligent power distribution, including load supply protection, wire protection, and power supply protection.
The Infineon Technologies BTG7090-2EPL PROFET Load Guard is offered in a PG-TSDSO-14 package with a -40°C to +150°C operating junction temperature range.
  • Capacitive load switching mode to charge big capacitive loads in the safe operation area
  • Automotive qualified in accordance with AEC Q100 Grade1 and ISO 26262-ready
  • Diagnostics
    • Proportional load current sense
    • Open load in ON and OFF state
    • Short circuit to ground and battery
  • Protection
    • Adjustable overcurrent limitation via an external resistor
    • Absolute and dynamic temperature protection with restart control
  • Switch ON capability while inverse current condition (InverseON)
Applications
  • Driving resistive, inductive, and capacitive loads with currents up to 2A
  • ADAS and AD modules including cameras, radar, ultrasonic, and LIDAR modules
  • Communication modules including antennas, BLUETOOTH®, V2X, and Wi-Fi®
  • Replaces electromechanical relays, fuses, and discrete circuits
  • Protection of system supply, load supply, and wires
  • Main switch for ECU power supply
  • Sensor heating elements
  • Future power distribution architectures
Specifications
  • 3V minimum operating voltage (VS(OP))
  • 2.7V minimum cranking operating voltage (VS(UV))
  • 28V maximum operating voltage (VS)
  • 35V minimum overvoltage protection (VDS(CLAMP)_25)
  • 0.5µA maximum current in sleep mode (IVS(SLEEP)_85)
  • 4.5mA maximum operating current (IGND(ACTIVE))
  • 90mΩ typical ON-state resistance (RDS(ON)_25)
  • 180mΩ maximum ON-state resistance (RDS(ON)_150)
  • 2A nominal load current (IL(NOM))
  • 1000 typical current sense ratio (kILIS)
  • 0.38A to 4.34A adjustable overcurrent limitation (ILIM)
  • -40°C to +150°C operating junction temperature range (TJ)
  • 4.9mm x 3.9mm PG-TSDSO-14 package
Typical Application
more information: https://www.infineon.com/dgdl/Infineon-Infineon-BTG7090_2EPL-DS-v01_00-EN-DataSheet-v01_00-EN.pdf
Texas Instruments TPSM265R1 Power Module with Ultra-Low IQ
Texas Instruments TPSM265R1 Power Module with Ultra-Low IQ is a compact, easy-to-use module that fully integrates a controller, MOSFETs, and an output inductor. The TPSM265R1 Power Module operates over a wide input voltage range up to a maximum continuous input voltage of 65V. The Power Module is designed to quickly and easily implement a power design in a small PCB footprint.
The TI TPSM265R1 Power Module features two fixed output voltage options, 3.3V and 5V, and an adjustable output voltage option that can be adjusted from 1.223V to 15V. Additionally, each option has a load current rating of 100mA. The TPSM265R1 operates in Pulse Frequency Modulation (PFM) mode, delivering optimal efficiency at light loads. The control scheme does not require loop compensation, providing excellent line and load transient.
The TPSM265R1 offers many features while being designed for small size and simplicity. These features include precision enable, adjustable UVLO, and hysteresis that allows for specific power-up and power-down requirements. Selectable/adjustable start-up timing options entail minimum delay (no soft start), internally fixed (900µs), and externally programmable soft-start via an external capacitor. An open-drain PGOOD indicator can be used for sequencing and output voltage monitoring.
The TPSM265R1 Power Module is available in a tiny 2.8mm × 3.7mm × 1.9mm package, ideal for space-constrained applications.
  • Wide input voltage range of 3V to 65V
  • Output voltage options:
    • Adjustable 1.223V to 15V
    • Fixed 3.3V or 5V
  • 100mA output current
  • 10.5µA quiescent current
  • ±1% internal voltage reference
  • PFM mode of operation
  • –40°C to 125°C ambient temperature range
  • Active slew rate control for low EMI
  • Meets CISPR11 (EN55011) EMI standards
  • Monotonic start-up into a pre-biased output
  • Power-good flag
  • Precision enable and input UVLO with hysteresis
  • Thermal shutdown protection with hysteresis
  • 2.8mm x 3.7mm x 1.9mm package
  • Create a custom regulator design with the TPSM265R1 using WEBENCH® Power Designer
Block Diagram
more information: https://www.ti.com/product/TPSM265R1
5G-Ready Embedded Computing Systems with 11th Gen Intel Core Processors
IBASE Technology Inc., recognized as a world leader in the design and manufacture of industrial motherboards and embedded computing systems, has launched the ASB200-953 compact box PC housing IBASE’s IB953 3.5-inch SBC powered by 11th Gen Intel® Core™ i7-1185G7E, i5-1145G7E and i3-1115G4E processors (formerly Tiger Lake) with a 15W TDP threshold.
Aimed at smart applications in warehouse logistics management, factory automation, and the automotive industry, the fanless ASB200-953 features high performance with low power consumption. With a black chassis color, it supports up to 64GB in two SO-DIMM slots and 12V~24V wide-range DC power input. Useful I/O ports on the front side include 3x USB 3.1, 1x USB 2.0, 2x DisplayPort, 1x COM, and 2x GbE ports. The rear panel is equipped with digital I/O, power button, HDD LED, DC-in terminal block, and two antenna holes that can be used with the optional WiFi accessory kit.
ASB200-953/ASB210-953 FEATURES:
  • ASB200-953: Fanless system with IBASE IB953 3.5” SBC (TDP 15W)
  • ASB210-953: Slim System with IBASE IB953 3.5” SBC  (TDP up to 28W)
  • Onboard 11th Gen Intel® Core™ U-Series Processor
  • Supports 3x M.2 sockets (B-Key/E-Key and M-Key)
  • 12V (-10%) ~ 24V (+10%) DC-in power input
  • 2x DDR4-3200 SO-DIMM, Max. 64GB
  • 3x USB 3.1, 1x USB 2.0, 2x Intel® GbE, 1x COM
  • External GPIO, 2x DisplayPort, TPM (2.0)
  • Optional VESA mount bracket
Measuring 180x150x72mm (WxDxH), the ASB200-953 comes with anti-scalding net design and flexible expansion support with high-speed 5G connectivity and other M.2 modules as well as dual storage for a 2280 NVMe SSD and a 2.5-inch HDD. The ASB210-953 variant comes with fan support and up to 28W TDP. Both have Trusted Platform Module (TPM 2.0) security and are compatible with Windows 11 and Windows Embedded Standard 8 operating systems.
New R&S LCX strengthens Rohde & Schwarz portfolio for high performance impedance measurements
With a completely new family of high performance LCR meters, the frequency range of impedance measurements provided by Rohde & Schwarz test equipment is dramatically extended to cover AC components operating from 4 Hz to 10 MHz, supporting all practical applications.
The R&S LCX family of LCR meters serves all established impedance measurements plus specialized measurements for selected component types and provides both, the high accuracy required in R&D, and the high speed needed in production test and quality assurance.
Rohde & Schwarz launches its new LCR meter family of high-performance general-purpose impedance testers covering a wide range of applications. With its supported frequency range from 4 Hz to 10 MHz, the R&S LCX is suitable not only for the vast majority of devices operating at conventional 50 or 60 Hz domestic power frequencies or 400 Hz for aircraft but also for everything from low-frequency seismic sensors to high power communication circuits operating at several Megahertz.
For engineers selecting suitable capacitors, inductances, resistors, and analog filters to match the device application, the R&S LCX models provide high precision impedance values with market-leading accuracy. Equally, higher speed measurements at production-use accuracy for quality control and monitoring are also supported. All the essential software and hardware required for production environments is available, including remote control and result logging, as well as rack mounting for the instrument, and a full range of test fixtures for handling components.
The auto-balancing bridge technology used by the R&S LCX supports conventional impedance measurements by measuring the AC voltage and current for the device under test, including the phase shift. This is then used to calculate complex impedance at any given operational point. As a general purpose LCR meter, the R&S LCX covers many applications, such as the measurement of equivalent series resistance (ESR) and equivalent series inductance (ESL) of electrolytic capacitors and DC-link capacitors. Furthermore, users can test transformers and measure DC resistance in addition to the full range of impedance measurements. To investigate components with impedance values varying at different frequencies and levels, option R&S LCX-K106 supports dynamic impedance measurements with the frequency, voltage or current as the swept parameter.
The R&S LCX family is launched with two models; the R&S LCX100 covers a frequency range from 4 Hz to 300 kHz, the R&S LCX200 a basic frequency range from 4 Hz to 500 kHz with options to cover all frequencies up to 10 MHz. Both models feature a large capacitive touchscreen and virtual keyboard to support tap-and-test for all main measurements. Alternatively, voltage, current, and frequency values can be set using the rotary knob. Less frequently used functions are menu-operated. Settings, results, and statistics can be displayed on the screen or output for automated post-processing. Up to four measurements can be selected and plotted versus time, with minimum and maximum values included in the display for at-a-glance pass/fail analysis.
For investigating impedance in a wider range of materials, the MFIA impedance analyzer from Zurich Instruments AG, a subsidiary of Rohde & Schwarz, complements the R&S LCX perfectly. With the MFIA researchers can characterize semi-conductors or undertake material research into materials including dielectrics, piezoelectrics, ceramics and composites, as well as tissue impedance analysis, cell growth, food research, microfluidics, and wearable sensors.
The R&S LCX family of LCR meters is part of the R&S Essentials portfolio and is now available from Rohde & Schwarz and selected distribution partners. For further information on the R&S LCX visit https://www.rohde-schwarz.com/product/lcx. For more information the LCR meter portfolio from Rohde & Schwarz, including the MFIA from Zurich Instruments AG, visit https://www.rohde-schwarz.com/lcr-meters.
TOP PCB Companies
