Ethernet connectivity for sensors in confined spaces
Data rates of up to 100 Mbit/s and almost a third less space required than M12: the D-coded M8 circular connectors of binder’s 818 series ensure the space-saving and cost-efficient connection of miniaturized sensors in Ethernet networks.
binder, a leading supplier of industrial circular connectors, offers connectors with D-coding in the M8 form factor as part of its 818 product series. The products are ideal for Industrial Ethernet applications with communication protocols such as EtherCAT, EtherNet/IP or PROFINET according to IEEE 802.3 via twisted-pair cables of the Cat-5e category. Accordingly, the 4-pin connectors enable the network connection of actuators and sensors of particularly small size with data rates of up to 100 Mbit/s.
Optimized for space-saving industrial sensor installations
Today, high-bandwidth Ethernet connectivity, beyond the field level and into the corporate data infrastructure, is a core component of automated processes in all branches of industry. In the Ethernet communication of modern production facilities, for example in drives control, properties such as clock synchronism, real-time capability and determinism, but also reliability and robustness are in demand. Use cases in such environments place special demands on the connection technology, both from a technological and an economic point of view. Connectivity solutions should be designed to be variable and scalable, and above all support users in machine and plant engineering in saving space and time during installation. In addition, secure locking and protection categories appropriate to the field of application are required. M8 circular connectors with screw locking, in accordance with the DIN EN 61076-2-114 standard, are optimized for such application conditions. Here, the M8 form factor in particular has proven itself in installations where space is critical; the use with miniaturized sensors is exemplary for this area of application.
Rugged hybrid connectors with PoE+
The binder series 818 products meet the requirements of data transmission in industrial Ethernet networks. Equipped with screw locking, the electromechanical connection meets the specifications of protection degree IP67 when mated and locked. It thus offers adequate protection against the influences of harsh industrial environments.
Beyond data communication, the hybrid D-coded M8 connectors take on the task of power supply in accordance with the IEEE 802.3at standard (Power-over-Ethernet-Plus, PoE+) to the connected devices.
Overmolded and shielded or screw termination
The 4-pin D-coded M8 connectors are equipped with gold-plated and symmetrically arranged contacts and are designed for more than 100 mating cycles. A rated voltage of 63 V(DC), a rated current of 4 A, and a rated surge voltage of 1500 V are specified for the products. The operating temperature range extends from -25 °C to +85 °C (idle state).
Shieldable products with screw termination and shielded, molded cable connectors are available. While the former have a 4.0 to 5.5 mm cable outlet and are designed for 0.14 to 0.50 mm2 conductors, the wire gauge of the molded variants is 0.34 mm2 (AWG 22).
In addition to straight male and female connectors, shieldable, angled flange versions are also available from Binder.
Analog Devices Inc. LTC4124 100mA Wireless Li-Ion Charger
Analog Devices Inc. LTC4124 100mA Wireless Li-Ion Charger is a single-chip wireless power receiver, full-featured linear battery charger, and ideal diode PowerPath™ controller solution. The LTC4124 features pin selectable charge current (up to 100mA) and charge voltage, ensuring versatility while minimizing the number of required external components. Wireless charging with the LTC4124 allows devices to be charged while sealed within enclosures and eliminates bulky connectors in space-constrained applications. Elimination of exposed conductive connectors also creates more robust devices while ensuring an effortless end-user experience.
The LTC4124 includes an NTC input for safe temperature qualified to charge and Low Battery Disconnect prevents damage to a battery due to over-discharging.
The compact 2mm x 2mm LQFN (Quad Flat No-leads) package and a minimal number of external components make the LTC4124 well-suited for low power portable applications where small solution size is mandatory.
  • Complete Wireless Power Receiver, Li-Ion Charger and PowerPath™ Controller
  • Wireless Input Power Control and Rectification
  • Wideband Wireless Power Frequency: DC to >10MHz
  • Pin-Selectable Charge Current: 10mA/25mA/50mA/100mA
  • Pin-Selectable Charge Voltage: 4.0V/4.1V/4.2V/4.35V
  • Pin-Selectable Low Battery Disconnect: 2.7V/3.2V
  • Zero Battery Drain Current in Disconnect/Ship Mode
  • Pin-Selectable Enable for Low Battery Pre-Charge Current
  • NTC Input for Temperature Qualified Charging
  • Safety Charge Termination Timer
  • Tiny Total Solution Size with Few Externals
  • Small Thermally Enhanced LQFN-12 package
  • Package Dimensions: 2mm × 2mm
  • RoHS and WEEE compliant
Application Diagram
more information: https://www.analog.com/en/products/ltc4124.html
Power Integrations InnoSwitch™3-PD ICs suit USB Type-C chargers
Power Integrations InnoSwitch™3-PD ICs simplify the development and manufacturing of USB Type-C™ and USB-PD (Power Device) power supplies. This simplification is achieved by integrating primary switch and controller, isolated feedback, secondary control, and USB-PD controller into a single compact package.
  • USB Type-C and PD controller
    • USB power delivery 3.0 + PPS provider and QC4 support
    • Compliant with USB Type-C Rev. 1.3
    • Integrated VCONN FETs with soft start and over-current protection
    • Supports electronically marked cables
    • Configurable pull-up resistor Rp
    • On-chip temperature sensor
    • Telemetry for power supply status and fault monitoring
    • PowiGaN™ technology – up to 100W without heat sinks
    • Dedicated NTC pin for temperature sensing
  • Highly integrated, compact footprint
    • Multi-mode Quasi-Resonant (QR) / DCM / CCM flyback controller, high-voltage switch, secondary-side sensing and synchronous rectifier driver
    • Optimized efficiency across line and load range
    • Integrated FluxLink™, HIPOT-isolated, feedback link
    • Instantaneous transient response
    • Drives low-cost N-channel FET series load switch
  • EcoSmart™ – energy efficient
    • No-load consumption as low as 14mW
    • Enables power supply designs that easily comply with all global energy efficiency regulations
    • Low heat dissipation
  • Advanced protection/safety features
    • Input voltage monitoring with accurate brown-in/brown-out and overvoltage protection
    • Output OV/UV fault detection with independently configured responses
    • Open SR FET gate detection
    • Hysteretic thermal shutdown
    • Programmable watchdog timer for system faults
    • Integrated high voltage FETs for VBUS short protection on CC1, CC2
  • Full safety and regulatory compliance
    • Reinforced insulation
    • Isolation voltage >4000VAC
    • 100% production HIPOT compliance testing
    • UL1577 and TUV (EN60950 and EN62368) safety approved
  • Green package
    • Halogen-free and RoHS compliant
Application Diagram
more information: https://www.power.com/products/innoswitch
TPS61094 – 60-nA quiescent current bi-directional buck/boost converter with bypass mode
Texas Instruments’ synchronous converter features bypass mode and supercapacitor management
Texas Instruments’ TPS61094 is a synchronous bidirectional buck/boost converter with a bypass switch that provides a power supply solution for smart meters and super capacitor backup power applications. The TPS61094 has a wide input voltage range and output voltage up to 5.5 V. The device works in buck mode and charges the supercapacitor; the charging current and the termination voltage are programmable with two external resistors. When the TPS61094 works in boost mode, the output voltage is programmable with an external resistor. During automatic buck or boost mode (EN = 1, MODE = 1), when the input power supply is applied, the device bypasses the input voltage to the output while it can charge a backup supercapacitor.
When the input power supply is disconnected or lower than the output target voltage, the TPS61094 enters boost mode and regulates output voltage from a backup supercapacitor. The TPS61094 consumes 60 nA quiescent current in this mode. The TPS61094 supports true shutdown mode (EN = 0, MODE = 1) and the forced bypass mode (EN = 0, MODE = 0). In true shutdown mode, the TPS61094 completely disconnects the load from the input supply. When supporting forced bypass mode, the TPS61094 connects the load to the input voltage directly through a bypass switch and consumes 4 nA current to achieve long battery life.
  • Input voltage range: 0.7 V to 5.5 V
  • Input voltage for startup: 1.8 V (min.)
  • Programmable boost output voltage range: 2.7 V to 5.4 V
  • Programmable buck charging:
    • Termination voltage range: 1.7 V to 5.4 V
    • Output current range: 2.5 mA to 600 mA
  • Ultra-low quiescent current:
    • Boost/buck charging mode: 60 nA
    • Forced bypass mode: 4 nA
  • Four operation modes controlled by the MODE and EN pins
  • Inductor valley current limit: 1.4 A (min.)
  • Two MOSFETs: 60 mΩ (LS) and 140 mΩ (HS)
  • Bypass switch resistance: 100 mΩ
  • Switching frequency: 1 MHz
  • Auto-snooze mode operation at light load
  • Efficiency:
    • Up to 92.3% at VIN = 3 V, VOUT = 3.6 V, and IOUT = 10 μA
    • Up to 96.3% at VIN = 3 V, VOUT = 3.6 V, and IOUT = 100 mA
  • Output short-circuit protection
  • Thermal shutdown protection
Block Diagram
Application Diagram
more information: https://www.ti.com/product/TPS61094
Full range of ams OSRAM’s OSLON® UV-C LEDs now available from Farnell
ams OSRAM’s OSLON® UV-C LEDs are suitable for a range of disinfection and purification applications.
Farnell, an Avnet Company and global distributor of electronic components, products and solutions, is now stocking the full range of ams OSRAM’s OSLON® UV 3636 UV-C LEDs available for fast delivery. Design engineers can access a greater range of market leading UV-C LEDs solutions from ams OSRAM to support a range of purification and disinfection applications such as point-of-use water treatment, automotive interior disinfection, air purification, general disinfection of high touch surfaces, medical environments, home goods and other consumer applications. UV-C LEDs are proven to effectively inactive the SARS-CoV-2 virus.
The OSLON® UV 3636 LED product range emits UV-C radiation and is available in three different power ratings of 4.7mW, 13.5mW, 42mW, enabling designers to select the LED best suited to their application. Each UV-C LED is compact, flexible and harnesses the cleaning properties of UV-C light allowing innovators to make the world cleaner, greener and healthier at the flick of switch. Featuring a robust design, the OSLON® UV-C LED family combines both low and mid-power with a reliable and efficient radiation output.
ams OSRAM’s OSLON® UV 3636 LED product range, now available for fast delivery from Farnell, includes:
  • The SU CULCN1.VC provides radiant flux typically of 13.5mW and a radiant efficiency of 2.4 percent.
  • The SU CULBN1.VC provides a typical radiant flux output of 4.7mW and radiant efficiency of 2.6 per cent.
  • The SU CULDN1.VC is the most powerful in the range providing radiant flux of typically 42 mW and radiant efficiency of 2.1 percent.
All products feature a ceramic package with integrated glass cover and are based on AlGaN Flip chip technology. The Lambertian emitter offers radiation of 120° and UV-C colour of 275nm.
Lee Turner, Global Head of Semiconductors and SBC at Farnell said:
“Farnell is pleased to offer our customers an extended range of the latest new-to-market UV-C LEDs from ams OSRAM for their designs. ams OSRAM has a long-established reputation for manufacturing innovative optical solutions, offering the highest standards in quality and reliability. Our customers rely on having access to high-quality UV-C components to keep pace with this fast-growing market. The range of optical solutions from ams OSRAM enables our customers to improve quality of life in terms of health, safety and convenience, while reducing impact on the environment.”
The ams OSRAM Group, including the listed companies ams AG as parent company and OSRAM Licht AG, is a global leader in optical solutions. With over 110 years of combined history, ams Osram’s core is defined by imagination, deep engineering expertise and the ability to provide global industrial capacity in sensor and light technologies. By adding intelligence to light, the company enables customers in the consumer, automotive, healthcare and industrial sectors to maintain competitive edge and drive innovation. ams OSRAM works to create technology for breakthrough applications, which is reflected in more than 15,000 granted and applied for patents.
Farnell offers an extensive range of products in its comprehensive semiconductor portfolio to support design engineers. Customers also have free access to online resources, datasheets, application notes, videos, webinars and 24/5 technical support.
Customers can now buy the full range of ams OSRAM’s OSLON® UV 3636 UV-C LEDs with fast delivery from Farnell in EMEA, element14 in APAC and Newark in North America.
www.uk.farnell.com
Waterproof connectors eliminate mating misalignments
Yokowo touts the first waterproof blade and receptacle connectors with a floating contact design that eliminates mating misalignments in rugged applications.
Yokowo has claimed the first waterproof blade and receptacle connectors that are constructed with a floating contact design. The waterproof connectors with a spring-loaded, dual-beam contact system use a floating contact design that absorbs any mating misalignment, according to Yokowo. The new connectors are suitable for high vibration/high shock wet or washdown applications.
The TBR (receptable) and TBP (blade) Series connectors are designed for battery connections in rugged devices such as tablet PCs, data collection terminals, and drones. The connectors protect devices and batteries from water ingress damage to the internal electronic components with an IPX7 waterproof rating (submerged in 1 meter of water for 30 minutes),
In addition to eliminating mating misalignment issues, the floating contact design absorbs shock and vibrations, enabling a reliable power connection, said the company. The floating degree is +/-0.3 mm.
The design also features an isolated contact area that prevents short circuits between adjacent contacts. The contacts feature a 3-A current rating with 50-mΩ contact resistance. The connectors are rated for 2,000 mating cycles. The operating temperature range is -40℃ to 85℃. Samples are available on request.
more information: Yokowo America
LPS28DFW Dual Full-Scale, Absolute Digital Output Barometer
STMicroelectronics’ ultra-compact piezoresistive absolute pressure sensor functions as a digital output barometer
STMicroelectronics’ LPS28DFW is an ultra-compact piezoresistive absolute pressure sensor that functions as a digital output barometer. The device comprises a sensing element and an IC interface that communicates over the I²C or MIPI I3CSM interface from the sensing element to the application. The LPS28DFW provides lower power consumption, achieving lower pressure noise than its predecessor.
The LPS28DFW is available in a ceramic LGA package with a metal lid. It is guaranteed to operate over a temperature range extending from -40°C to +85°C. The package is holed to allow external pressure to reach the sensing element. Gel inside the IC protects the electrical components from water, and the metal cap is, optionally, connected to ground or left floating electrically in the application PCB layout. The connection of the metal cap is determined according to the customer’s target application.
This device has been designed to meet the requirements and mission profile for personal electronics and consumer applications.
  • Dual full-scale absolute pressure with water-resistant package
    • Mode 1: 260 hPa ~ 1260 hPa
    • Mode 2: 260 hPa ~ 4060 hPa
  • Current consumption down to 1.7 μA
  • Absolute pressure accuracy: 0.5 hPa
  • Low-pressure sensor noise: 0.32 Pa
  • Embedded temperature compensation
  • 24-bit pressure data output
  • ODR from 1 Hz to 200 Hz
  • I²C or MIPI I3CSM interface
  • Embedded FIFO
  • Interrupt functions: data-ready, FIFO flags, pressure thresholds
  • Supply voltage: 1.7 V to 3.6 V
  • Easily sealed package with O-ring
  • ECOPACK lead-free compliant
Applications
  • Wearables
  • Altimeters and barometers for portable devices
  • GPS applications
  • Weather station equipment
  • Sport watches
  • e-cigarettes
  • Water depth monitoring
more information: https://www.st.com/en/mems-and-sensors/lps28dfw.html
Exceptionally high speed and dynamics for AM3248 stepper motor
With its speed and torque, the new AM3248 stepper motor from FAULHABER raises the bar in terms of performance and dimensions. Offering up to 10,000 rpm, it can achieve five times the speed of comparable stepper motors. Combined with a gearhead reduction of 100:1, it supplies a torque of 5 Nm. The motor delivers these values with a diameter of just 32 mm. This makes it ideally suited for a wide range of applications in areas such as aerospace, laboratory automation, large optical systems, the semiconductor industry, robotics and 3D printing.
The multi-pole, two-phase AM3248 stepper motor performs 48 steps per revolution and offers a very high holding torque of 85mNm. The motor starts with a high speed from the very first step; thanks to its low inertia, it can be used in applications that require very fast acceleration and fast changes of direction. Newly developed large ball bearings further extend the already long service life of this motor type. For its size class, the performance values that it achieves in combination with a 32 GPT gearhead are unrivaled on the market. The motor can also be combined with an IE3 magnetic encoder.
These properties and options make the motor ideally suited for a variety of demanding applications. This includes aligning the solar panels of satellites, for example. The motors move the booms so that the panels are always directly facing the sun. In addition to working precisely and reliably over many years, the motors must also be able to withstand the extreme temperatures in outer space. In the semiconductor industry, very high dynamics and speed are required when positioning the wafers in very confined installation conditions in the machines. This is another application in which the highest level of precision and reliability are essential.
“Our new AM3248 model meets all requirements and is ideally suited for high-performance applications of this kind,”
explains Thomas Würgler of FAULHABER PRECISTEP.
The corporate unit specializing in stepper motors is located in the Swiss city of La Chaux-de-Fonds, known for its watchmaking.
“We are able to adapt the product to the requirements of the respective application, even in small production runs. We provide our customers with the entire drive package, including technical advice and support from a single source.”
more information: www.faulhaber.com
Axiomtek revamps advertisement with multiple view digital signage player – DSP511
Axiomtek – a world-renowned leader relentlessly devoted in the research, development and manufacture of series of innovative and reliable industrial computer products of high efficiency – is pleased to introduce the DSP511, a 4K Ultra HD digital signage player with four HDMI 2.0 ports and a 2.5G Ethernet port, which enhance multiple view and real-time displays. The outstanding signage player is powered by the 11th generation Intel® Core™ i5/i3 (codename: Tiger Lake-UP3) which makes it much more versatile in smart retail applications such as interactive advertisement or AI precision marketing.
In addition to the standard GbE LAN port, it adds a 2.5G LAN port to support faster internet transmission to upload videos and advertisements in higher resolutions for real-time display. It has four HDMI 2.0 ports for multiple displays and the resolution can reach 4K 60Hz. The DSP511 utilizes the Intel® Tiger Lake-UP3 processor; with Iris Xe Graphics, the computing performance is boosted. While the computing capability is powerful enough, even for Artificial Intelligence (AI) processing, the digital signage player doesn’t need a discrete graphics card. Measuring 260 x 160 x 26 mm, the DSP511 is perfectly suited for menu board and video wall solutions in airports, shopping malls, and other commercial premises that require reliable 24/7 operation.
“Now the advertisements for display are transmitted through the internet to the player. The DSP511 with a 2.5G LAN port, which is relatively rare among similar products in the industry, will be much more efficient. The DSP511 aims to be the front-runner in the business,”
said Yifei Wang, a product manager of the Product PM Division at Axiomtek.
Advanced Features
  • 11th gen Intel® Core™ i5/i3 & Celeron® processor (Tiger Lake-UP3)
  • 2 DDR4-3200 SO-DIMM for up to 64GB
  • 4 HDMI 2.0 with 4K supported
  • One 2.5G LAN, 1 GbE LAN, and 4 USB
  • 1 M.2 Key E 2230 for Wi-Fi/BT
  • 1 M.2 Key B 3052 for 5G/4G LTE
  • 1 M.2 Key M 2280 for storage
The DSP511 with a low power consumption design has DDR4-3200 SO-DIMM, maximum up to 64GB that could ensure the display quality. The M.2 Key M 2280 slot is compatible with SATA and NVMe for storage, which gives the player abundant space to save high-resolution videos or data. To meet the requirement of diverse applications, it provides rich I/O options including three USB 3.2 Gen 2 ports, one USB 2.0 port, four HDMI ports, one audio jack, one RS-232 port and six antenna openings.
In addition to providing quad 4K, the HDMI 2.0 ports offer hardware EDID (Extended Display Identification Data) and independent audio outputs. The expansion interfaces include one M.2 Key E for Wi-Fi/BT, one M.2 Key B for 5G/4G LTE, and one SIM card slot.
The Axiomtek’s DSP511 is now available for purchase. For more product information or pricing, please visit our global website at www.axiomtek.com or contact one of our sales representatives at info@axiomtek.com.tw.
AAEON Adds UP Squared 6000, a powerful board powered by Intel® Atom® x6000E/RE, Pentium® or Celeron® N/J series SoC
To expand vertical markets and accelerate AIoT deployments for clients, AAEON announced its introduction of UP Squared 6000, a high-performance industrial computing maker board at small form factor (101.6mm x 101.6mm) powered by Intel® Atom® x6000E/RE, Pentium® or Celeron® N/J series SoC (formerly Elkhart Lake) to its expanding UP Family. With the next-generation IoT-enhanced processors, UP Squared 6000 delivers upgraded single-thread, multi-thread and graphical performances, and features Intel® Programmable Service Engine (PSE) and onboard TPM to accelerate and optimize AIoT vertical applications.
To drive optimal performances required for today’s vertical markets, such as robotics, smart agriculture, retail, and vision-intensive applications, UP Squared 6000, powered by Intel® Atom® x6000E/RE, Pentium® or Celeron® N/J series SoC (formerly Elkhart Lake), delivers up to 1.7x single-thread performance, 1.5x multi-thread performance, and 2x graphical processing performance enabled by Intel® UHD Graphics (11th Generation GPU). By adopting the next-generation IoT-enhanced processors, UP Squared 6000 brings improved performance and efficiency in artificial intelligence deployments.
Expansion and scalability are critical in edge AIoT deployments. To meet the design requirements, UP Squared 6000 comes with multiple M.2 sockets for Intel® Myriad X module, NVMe storage, 5G connectivity and Wi-Fi5/6 modules. In addition, UP Squared 6000 features 40-pin GPIO (HAT-compatible) and 100-pin board-to-board connector (available in Intel® Atom® x6000E/RE SKUs only) for I/O expansions through a carrier board. With the carrier board, UP Squared 6000 will drive full potential of Intel® Programmable Service Engine by offering CAN Bus, QEP, additional dual GbE Ethernet ports, and RS-232 for industrial applications (the carrier board is available in SKUs with Intel Atom® x6425RE and Intel Atom® x6413E processors and is scheduled for official launch in Q2, 2022).
By integrating the carrier board, UP Squared 6000 can drive the potential of Intel® Programmable Service Engine (PSE) offering Out-of-Band (OOB) Management, allowing IT personnel to remotely manage manufacturing assets even when the operating system is unresponsive or the device is powered off.
With purpose-built housing, UP Squared 6000 can be expanded as UP Squared 6000 Edge featuring all I/O connectivity of the mainboard and IoT enhancements including Time-Sensitive Networking (TSN), Time-Coordinated Computing (TCC), in-band ECC, and onboard TPM 2.0. On the other hand, by integrating UP Squared 6000 mainboard and the additional carrier board, UP Squared 6000 can be offered as UP Squared 6000 Edge Computing kit to unlock Intel® Programmable Service Engine (PSE), and further accelerates computer vision and deep learning applications with its preloaded Intel® Distribution of OpenVINO™ toolkit.
For those interested in the trial version of the carrier board and Intel® Programmable Service Engine (PSE), the UP Squared 6000 Edge Computing Kit is scheduled to be launched in Q1, 2022 to meet the demands while the carrier board will be officially in the market by Q2.
more information: https://www.aaeon.com/en/ni/press-release-intel-atom-x6000e-maker-board-up-squared-6000
TOP PCB Companies
