This is easy to build and very useful project for hobbyists and students to learn and create OPAMP-based projects. The project accommodates a single OPAMP in the SOT23-5 package. The project provides the user with multiple choices and extensive flexibility for different applications circuits and configurations. It provides the user with many combinations for various circuit types including active filters, differential amplifiers, and external frequency compensation circuits etc. A few examples of application circuits are given below. LM321 op-amp is the right choice to use for this board or any SOT23-5 OPAMP with the same pin configuration as LM321 can be used. It supports dual supply or single supply, Jumper J1 is provided to use this board with a single supply, D1 power LED.
Universal OPAMP Board for SMD SOT23-5 Package – [Link]
This is Arduino compatible hardware that can control a single DC motor speed, direction, and brake using an RF remote control. The project is based on an ATMEGA328 microcontroller, H-Bridge DC motor driver chip LM18201, NRF24L01 RF module, 5V Regulator, 3.3V regulator and other components. This board can drive a DC Motor up to 24V DC with a load current up to 3A. Arduino pin configuration details are provided below, the user may write their own code and use this hardware. The ATMEGA328 is the heart of the project, the LMD18201 chip drives the motor, LM317-ADJ provides 5V to the microcontroller, LM1117 3.3V regulator power the 3.3V to NRF24L01.
DC Motor Speed, Direction and Brake Control with NRF24L01 RF Module – Arduino Compatible – [Link]
This is an Arduino compatible open-source hardware that includes 1 x joystick, NRF24L01 RF module, Atmega328D microcontroller, 3.3V regulator, power LED, function LED, and other required components. This board can be used for the development of various applications such as Gaming, Remote RC servo driver, RC Motor controller, Robotics, and many more.
Single Joystick Remote Control Transmitter using NRF24L01 – Arduino Compatible – [Link]
This is an Arduino compatible open-source hardware that includes 2 x Joysticks, NRF24L01 RF module, Atmega328 microcontroller, 3.3V regulator, power LED, function LED, Arduino programming connector, and other required components. This board can be used for the development of various applications such as Gaming, Remote RC servo driver, Robotics, and many more. Connector CN3 was provided to program the ATMEGA328 microcontroller using Arduino IDE.
Dual Joystick RF Remote Transmitter with NRF24L01 RF module – 2 Joystick Control – [Link]
This is an easy-to-build open-source Arduino compatible board that enables driving 8 RC servos over NRF24L01 RF Link. The project can be used as a standalone RC servo driver or 8 channel RF remote-controlled RC servo Receiver. An optional OLED display option can be used to develop RC signal monitor. The tiny module contains an ATmega328 microcontroller, connectors for 8 x Servo interface, DC supply connector, bulk electrolytic capacitor C5 on DC supply to provide jitter-free smooth movement of RC servos. Operating Supply 5V DC.
8 Channel RC Servo Driver Over RF Link using NRF24L01 RF Module – Arduino Compatible – [Link]
Monolithic Power Systems (MPS) MP3362 Boost LED Driver is a fixed-frequency converter for low-current and high-current boost applications. The driver features a low 0.2V feedback voltage for higher efficiency in white LED driver applications. The MP3362 regulates the output voltage up to 36V with an efficiency as high as 95%. Current mode regulation and external compensation components allow the MP3362 control loop to be optimized across a wide variety of input voltages.
The new chip-level DC/DC converter, B0505ST16-W5 from Mornsun is designed to meet automotive and medical application requirements. This fixed input 0.5W DC/DC converter is the SMD device with reinforced 5KVAC high isolation and trimable output voltages of 3.3V, 3.7V, 5V, 5.4V available in a miniature SOIC16 package, with control ON/OFF pin that has a wide operating temperature of -55c to +125c.
The high-isolation, high-pressure B0505ST16-W5 DC-DC converter meets the isolation protection requirements of 2 MOPP, with an isolation voltage of 5000VAC, a system operating voltage of 849VDC, an isolation capacitor of up to 3.5pF, and is designed to meet IEC/EN 60601 standards. At a high temperature of 125 degrees C, the device can be used with a 55% load and can be widely used in industries with high-temperature requirements, such as automotive electronics.
Key Features of B0505ST16-W5 DC/DC Converter
Strengthen insulation and isolate voltage 5000VAC
Electrical gap/climbing distance ≥8mm, 2 MOPP
Wide operating temperature range: -55 degrees C to 125 degrees C
The output voltage is adjustable
The built-in soft-start circuit prevents surge current and output overshoot
The B0505ST16-W5 is an ultra-small size chip-level power supply that weighs only 0.35g (typ.) and saves customer board space and can be used in a variety of applications.
Lantronix has recently launched a system-on-module and its integrated development board based on Qualcomm QRB5165 System-on-Chip running Ubuntu Linux OS. The Open-Q 5165RB system-on-module has been designed with a compact form factor of just 29×50 mm for edge robotics applications. Along with the public launch comes another hardware on the same Qualcomm system-on-chip, but a development board with all the header to explore the functionalities of the modules. System-on-modules are designed in such a way that they feature specialized processing cores for AI processing, image, and graphics processing.
As mentioned earlier, the SOM is built on the Qualcomm QRB5165 System-on-Chip that manufactures using 7nm technology, featuring Kryo 585 Octa-core CPU. The cores run on different clock frequencies: one Kryo Gold prime at 2.84 GHz, three Kryo Gold at 2.42 GHz, and four Kryo Silver at 1.81 GHz. With the powerful processor comes the Hexagon 698 DSP, Adreno 650 GPU, and several other processing units.
A deeper look at the Open-Q 5165RB system-on-module
SoC:
CPU: Kryo 585 Octa-core CPU
DSP: Hexagon 698 DSP with quad Hexagon Vector extensions
GPU: Adreno 650 GPU
Other processing units: Adreno 665 video processing unit, Adreno 995 display processing unit, NPU230 neural processing unit, and SPU240 secure processing unit
Memory: 8GB LPDDR5 @ 2750MHz
Wireless Connectivity: 802.11ax 2×2 MU-MIMO + Bluetooth 5.1, Bluetooth Milan ready
Video Interfaces: 2x 4-lane MIPI DSI D-PHY 1.2 and DisplayPort v1.4 on USB Type-C
Audio Interfaces: 3x 4-lane MIPI CSI camera ports + CCI I2C control
Power: Power management and battery charging solutions on SOM
OS support: Ubuntu Linux OS
“With Lantronix’s new Open-Q 5165RB SOM, developers gain the perfect computing core needed to accelerate leading-edge robotics application development while reducing time to market.”
says Jacques Issa, VP of Marketing at Lantronix.
The system-on-module is expected to be famous for a variety of applications even outside of edge robotics. The expanded support for TensorFlow Lite, Qualcomm Neural Processing SDK, Computer Vision SDK, and Neural Networks API gives us the sense of its power to aid deep learning and neural networks processing applications.
After a launch of the system-on-module, there is always a development kit available along with it. The Lantronix’s new Open-Q 865 SOM Development Kit comes to light to speed up product development and expose all available I/Os.
There are a lot of technical details available on the manufacturer’s page. The system-on-module is priced at $580, while the development kit (without the SOM) is available at $399. Visit the product page for more information.
Radio Module and Test Option for the Wirepas IoT Network Protocol
Würth Elektronik launches Thetis-I, a ready-to-use radio module for Wirepas mesh networks. Thetis-I is the perfect solution for IoT device manufacturers. Networks with technology from Wirepas, the Finnish software provider, are self-healing and freely scalable. Each device with a Thetis-I radio module can also act as a router which means no further infrastructure is required for mesh communication. Würth Elektronik offers developers the Thetis-I Evaluation Kit. It contains an evaluation board, a USB radio stick, and three sensor nodes. Thanks to the tailored Wirepas Commander software, this kit can be operated and configured directly via a PC.
Specifications
Wirepas routing mesh protocol, optimized for ultra-low energy consumption
Thetis-I is based on the Nordic nRF52840 chipset and the proven proprietary 2.4 GHz radio module. The radio module, optimized for Wirepas networks, is extremely energy-saving and offers the choice between low-energy and low-latency modes. The module, which measures just 8×12×2 mm, can be configured remotely using the freely available Wirepas Commander software. It supports authentication and encryption, stand-alone or host-controlled operation. A wide range of potential applications can be tested using the Evaluation Kit. Wirepas technology enables easy connection to well-known cloud platforms. The slim evaluation board allows a controller board to be connected for developing applications. A battery-powered sensor board equipped with the versatile WSEN-PADS pressure sensor and the WSEN-HIDS humidity sensor readily provides an application example for a mesh network.
Thetis-I and the Evaluation Kit are now available from stock without minimum order quantities. Individualized firmware versions can also be supplied on request.
Fibocom, a global leading provider of IoT (Internet of Things) wireless solutions and wireless communication modules, announces that its LTE Advanced Pro module NL952-NA has been successfully certified by T-Mobile. The module is now qualified to provide wireless connection services under T-Mobile’s network, which further expands the product’s application coverage over the US market.
Based on the Qualcomm Snapdragon X24 chipset, Fibocom’s NL952 is a high-performance LTE-A Pro Cat 20 module series designed to provide high-speed connectivity in applications such as CPE, gateway, TV, VR, drone, etc. Coming with the M.2 form-factor, the Fibocom NL952 module series supports LTE/LAA network bands in addition to UMTS/HSPA+ fallback, which offers maximum data rates of 2Gbps downlink and 150Mbps uplink. With an integrated GNSS receiver (GPS/GLONASS/BeiDou/Galileo), Fibocom’s NL952 module series supports Linux and Android operating systems as well as other functions including VoLTE, Audio, FOTA.
The module also supports various interfaces, including USB 3.0, PCIe 2.0, GPIO, UIM, I2C and MIPI, unleashing the potential of cellular technology to meet high-speed application demand. To date, the Fibocom NL952 module series has been globally certified by regional regulatory bodies and industry institutions, including IC/ FCC/ RoHs/ CE/ GCF/ RCM/PTCRB/ HF.
“We are very excited to announce the NL952-NA module has been certified by T-Mobile,” said Ron Friedman, VP of Americas Sales Dept., Fibocom. “Fibocom continues to enable seamlessly IoT experiences and help to accelerate digital transformation globally. The Fibocom LTE-A module NL952 is capable of offering customers with the best cost performance for a wide range of IoT scenarios.”
