First full 32-bit plastic M0+ microcontroller
ARM has developed the first full 32bit microcontroller built on a flexible plastic material using a 0.8 μm process from PragmatIC.
The PlasticARM microcontroller consists of 56,340 NMOS transistors and resistors and is built on a plastic substrate developed by UK foundry PragmatIC Semiconductor in Cambridge.
The microcontroller, detailed in the journal Nature after six years of development, includes a 32bit CPU, Nested Vector Interrupt Controller (NVIC) for handling interrupts from external devices, peripherals, memories and AHB-lite bus interface as well as a read only memory with 456 bytes that holds three test programs using the ARMv6-M instruction set and the standard ARM toolchain.
The whole system-on-chip runs at a clock rate of 29 kHz from a 3 V supply and consumes 21 mW, dominated by the static power, with the processor accounting for 45 percent, memories 33 percent and peripherals 22 percent.
The PlasticARM is 12 times larger than the previous development between ARM and PragmatIC on a dedicated machine learning core and marks a significant step for low cost flexible, plastic electronics for everyday objects to connect to the Internet of Things.
The SOC was implemented with PragmatIC’s 0.8-μm process using industry-standard chip implementation tools and four metal layers on a 200 mm polyimide wafer.
The resulting chip has an area of 59.2 mm2 (without pads), and contains 18,334 NAND-equivalent gates with 28 pins, which include clock, reset, GPIO, power and other debug pins. There are no dedicated electrostatic discharge mitigation techniques used in this design. Instead, all inputs contain 140 pF capacitors, whereas all outputs are driven by output drivers with active pull-up transistors.
A key challenge is the power consumption and heat dissipation in the plastic. ARM is developing lower-power cell libraries to support more complex plastic designs up to about 100,000 gates which will enable more peripherals around the controller core. Moving to more than 1,000,000 gates will probably require complementary metal–oxide–semiconductor (CMOS) technology, say the researchers.
Another challenge is to develop the programmable non-volatile memories for program storage.
via eenewsembedded.com
Ricoh Electronic Devices Company R1810 600nA IQ Boost DC/DC Converters
Ricoh Electronic Devices Company R1810 600nA IQ Boost DC/DC Converters are boost DC/DC converters featuring a typical start-up voltage of 0.35V. Ricoh R1810 is designed for electrical power storage devices, especially 1-cell photovoltaic (PV) energy harvesters. The R1810 can start up with 9µW, making it ideal for charging a 1-cell PV element. R1810 can be used in a system working under a low-illuminance environment.
  • Low quiescent current [600nA typical (IQ_VOUT)]
  • High efficiency (66% at IOUT = 5μA)
  • Startup with low input energy, 9μW (low illuminance)
  • Built-in maximum power point control function
Applications
  • Energy harvesting modules, especially 1-cell PV
  • Thermoelectric power generation
Specifications
  • 0.35V typical start-up voltage
  • 0.2V to 2.1V input voltage range
  • 2.3V to 4.5V output voltage range
  • ±5.0% output voltage accuracy
  • Input power good function
  • Output power good function
Application Schematic
more information: https://www.n-redc.co.jp/en/products/dc-dc-switching-regulator/spec/?product=r1810
Maxim Integrated 3A Automotive Hi-Speed USB Protectors
Maxim Integrated 3A Automotive Hi-Speed USB Protectors provide high-ESD and short-circuit protection for low-voltage internal USB data and USB power line. The protectors are ideal for use in automotive radio, navigation, connectivity, and USB hub applications. The devices support Hi-Speed USB (480Mbps) and full-speed USB (12Mbps) operation. The devices also include integrated circuitry to enable fast charging for consumer devices that adhere to either the Apple® method or the Hi-Speed USB host-charger port-detection protocol and support USB on-the-go (OTG).
  • 900MHz bandwidth USB 2.0 data switches
  • Industry-leading RDS(ON) minimizes voltage drop on a bus line to help meet USB voltage specifications at device connector
    • Current-limited 31mΩ (typ) BUS switch with high capacitive load capability
  • Robust overvoltage and ESD protection for the automotive environment saves on external protection components
    • Short-to-battery and short-to-GND protection on protected HVBUS output
    • Short-to-battery and short-to-HVBUS protection on protected HVD+ and HVD- outputs
    • Two 4.0Ω (typ) RON USB 2.0 data switches
    • Integrated overcurrent and short-circuit auto retry
    • High ESD protection (HVD+, HVD-, HVBUS)
      • ±15kV human body model
      • ±15kV IEC 61000-4-2 air gap
      • ±8kV IEC 61000-4-2 contact
    • 20ms fault-blanking timeout period
  • Automatic transitioning of charge modes through intelligent state machine for seamless device integration
    • Integrated Apple iPhone 1.0A dedicated charging mode
    • Integrated Apple iPad 2.1A dedicated charging mode
    • USB-IF BC1.2 charging downstream port (CDP) and dedicated charging port (DCP) modes
    • Chinese telecommunication industry-standard YD/T 1591-209
    • USB on-the-go (OTG) support
  • AEC-Q100 qualified
Block Diagram
more information: https://www.maximintegrated.com/en/products/interface/universal-serial-bus/MAX16972.html
Next-Generation Digital Flow Sensors for High Volume Applications
Sensirion has introduced three next-generation sensors – SFM3003, SFM3013, and SFM3119 as part of SFM3xxx platform. Available worldwide via Sensirion distributors, these new flow sensors are suitable for inspiratory applications at ambient pressure. All three flow sensors offer high accuracy, very low-pressure drop, and fast signal sampling. Moreover, these devices are fully calibrated and temperature-compensated and can accurately measure flow rates in both directions.
The SFM3003 flow sensor has an extended flow range between -150 and 300 slm. It is based on the technology used in the SFM3019 sensor and provides high volume of flow sensors for inspiratory flow measurements in medical ventilators. It comes with a wider flow range and improved specifications. The flow of air, oxygen and mixtures thereof at rates between -30 and 300 slm can be measured with high accuracy, reliability and long-term stability and no recalibration is required.  It has a very low pressure drop, ultra-fast response time and optimal signal-to-noise ratio. The SFM3013 flow sensor is a variant of the SFM3003. It is resistant to overpressure (up to 1 bar) and calibrated for heliox gas. This sensor is ideal for high volume and cost-efficient applications.
The SFM3119 flow sensor is a successor of SFM3100 flow sensor and a compact digital flow meter that comes with a digital I2C output and improved specifications. It is accurate and fast at measuring flows of air, oxygen and mixtures thereof between -10 and 240 slm. Its compact design enables it to be easily integrated into existing devices. The SFM3119 flow meter has a low pressure drop and is suitable for inspiratory flow sensing in applications such as ventilation and anesthesia, and for mixing oxygen and air to a very precise degree.
Upon order, the customers get comprehensive support and all important documents (data sheets, application notes, engineering guide, CAD files, etc.) to make the process of starting new projects easy and straightforward.
more information: https://www.sensirion.com/en/flow-sensors/sfm3xxx-sensor-platform/
IoThing Digital – Digital I/O module with two high-power relays and two isolated AC or DC input channels
IoThing Digital is a professional digital I/O module with two high-power Omron G5Q-14 relays and two digital input channels (based on Texas Instruments ISO1211). It allows digital input of both DC and AC signals, so you are not limited in your choice of input voltage level. You can choose the voltage range yourself, for example, 60 VDC or 220 VAC or any other, up to 300 V. The design of this board also integrates a DC-DC converter and a slot for mikroBUS modules.
IoThing Digital can be used as an add-on module for popular SoMs such as Raspberry Pi, Arduino, Adafruit, Particle, SparkFun, Teensy boards and others. We will also be providing PCBs based on LPC824, SAMD21 and STM32F411 microcontrollers as add-on options during this campaign. As a bonus, IoThing Digital measures 65 mmx 56 mm and corresponds to the popular format of the Raspberry Pi 3A+, which greatly simplifies its use with the Raspberry Pi.
Perfect for Professionals and Hobbyists
IoThing Digital is perfect for engineers who are designing distributed / decentralized control systems, developers of modern IoT and IIoT (in which our module can be used as a basis for building compact embedded systems), and even amateur designers who automate everything – from thermometers in windows, to heating systems, up to the implementation of smart homes and smart farms.
Features & Specifications
  • MCP23008 chip with I2C bus for relay control and digital signal input
  • Supports 100 kHz and 400 KHz on I2C bus
  • Selection of one of eight addresses on the I2C bus for the MCP23008 using jumpers on the bottom-side of the module, default address is 0100 010x
  • Grove connector for external module with I2C bus
  • Compatible with major well-known microcontrollers
  • 2 SPDT relays
  • Current consumption of each relay is less than 80 mA
  • Characteristics for resistive load: 3 A 30 VDC or 3 A 250 VAC
  • Dielectric strength: 4 kV VAC, for 1 minute between coil and contacts; 1 kV VAC, for 1 minute between contacts of the same polarity
  • Compliant to IEC 61131-2; Type 1, 2, 3 characteristics for 24 V insulated digital inputs
  • You can enter the values of two digital signals, from 9 V to 300 V, DC and AC
  • Accurate Current Limit for Low-Power Dissipation – 2.2 mA to 2.47 mA for Type 3
  • The maximum insulation voltage (up to 60 s) is 3600 VPK
  • Maximum working insulation voltage: AC – 400 VRMS, DC – 566 VDC
  • Reverse polarity protection
  • Modules you can install with the mikroBUS bus:
    • our modules (SoM Lite series and other modules),
    • Click® modules from MikroElekronika
  • Power supply: non-isolated, 9-36 VDC
  • Size: 65 x 56 mm. The format of the module corresponds to the popular format of the Raspberry Pi 3A+, which greatly simplifies its use with the Raspberry Pi.
Open Source Documentation
You can find documentation and board schematics in our datasheet.
Interested in This Project?
You can sign up to be notified when this campaign launches, and to get any other useful updates, right at the top of this page. We work hard to only send out useful information and you can unsubscribe at any time.
This module and our other products are described in more detail at www.makethingshappy.com
Sound to Colour Light Effects – Arduino Compatible
This is a fun-loving project based on the Arduino platform. The project creates color light effects with sound level sense by an onboard condenser microphone. The project consists 20 x WS2812B RGB LEDs, an Atmega328 micro-controller, condenser microphone along with pre-amplifier, RCA connector, and trimmer potentiometer to direct feed audio. The project can be used in fun parties, disco parties etc. Just power the board and RGB LEDs will create different colors as per sound level. Board has the option of direct audio input or sound sense by the microphone, users may change the Arduino example code as per requirement or write their own code.
Sound to Colour Light Effects – Arduino Compatible – [Link]
Universal Op-Amp Board for SMD SOIC-8 Package
This is an easy to build and very useful project for hobbyists and students to learn and create OPAMP-based projects. The project accommodates a single op-amp in a SOIC8 package. The project provides the user with multiple choices and extensive flexibility for different applications circuits and configurations. It provides the user with many combinations for various circuit types including active filters, differential amplifiers, external frequency compensation circuits etc. A few examples of application circuits are given below. LM358 op-amp is the right choice to use but any SOIC8 OPAMP with the same pin configuration can be used. It supports dual supply or single supply, Jumper J1 is provided to use this board with a single supply, D1 is the power LED.
Universal Op-Amp Board for SMD SOIC-8 Package – [Link]
600W – 230VAC – High Voltage DC Motor Speed Controller – Heater Controller – Lamp/LED Dimmer
This is a very powerful DC Motor speed controller for DC motors up to 330V DC and current up to 2A. Basically, the project is a high voltage PWM source with adjustable frequency and adjustable PWM duty cycle range 0 to 99%.  The board has been designed considering many applications and the circuit can be used as a heater controller, DC Motor speed controller, LED dimmer, Lamp dimmer, and High voltage PWM driver. The circuit can handle load up to 600W (330V DC @ 2A). The operating input supply is 100V AC to 250V AC or 100V to 330V DC. It is important to provide the input supply as per the operating power supply of the load. Trimmer pot PR1 is provided to adjust the frequency, and P1 to adjust the PWM duty cycle.
600W – 230VAC – High Voltage DC Motor Speed Controller – Heater Controller – Lamp/LED Dimmer – [Link]
Universal Op-Amp Board for DIP-8 Package
This is an easy to build and very useful project for hobbyists and students to learn and create op-amp-based projects. The board accommodates a single op-amp in DIP-8 package. The project provides the user with multiple choices and extensive flexibility for different applications circuits and configurations. It provides the user with many combinations for various circuit types including active filters, differential amplifiers, and external frequency compensation circuits etc. A few examples of applications circuits are given below. LM358 op-amp is the right choice to use or any DIP-8 op-amp with the same pin configuration as LM358 can be used. It supports dual supply or single supply, Jumper J1 is provided to use this board with a single supply, D1 power LED.
Universal Op-Amp Board for DIP-8 Package – [Link]
Open Source Arduino-compatible Cellular IoT Hardware Development Platform
IoTa
POEM Technology is preparing to launch a crowdfunding campaign for IoTa, an Arduino-compatible development platform board that simplifies Internet of Things prototyping for developers. The board is designed for use with cellular and mobile connections for embedded applications. Despite its compact form factor, IoTa packs enough functionality and features a wide range of lightweight, powerful, remote applications. Thus, it is perfect for drone operation, Grid Monitoring, Sensor networks, cellular carrier scanner, etc.
IoTa makes development easier since it has a separate system processor and user processor. Hence, the dual-processor design eliminates the need for the developer to provide a processor to run user code. The Arduino IDE allows you to quickly deploy your IoT design by developing code on the user processor.
Technical Specifications of IoTa
The System microcontroller has a 32-bit ARM CortexM0+ processor with 256 kB Flash and 32 KB RAM that runs at 48 MHz. This microcontroller manages the u-blox modem as well as connections to Hologram’s cloud. The user microcontroller, on the other hand, has a 32-bit ARM Cortex-M4 that operates at 120MHz and has 1MB Flash and 256kB RAM. This microcontroller is only used to run user programs that are Arduino API compatible.
Furthermore, this open-source cellular development board facilitates connectivity by allowing embedded applications to connect to peripherals and sensors via an array of GPIO pins and serial interfaces. Additionally, IoTa is excellent for low-power applications since its battery management encompasses charging and fuel gauge functions.
Front and Back of IoTa
Talking more about the IoTa, the board features a u-blox SARA-R410 modem for rapid IoT development on CAT-M and NB-IoT networks worldwide. This is a cost-efficient solution offering multi-band data transmissions for Low Power Wide Area solutions in a compact form factor. The modem is ideal for mission-critical IoT solutions, as it includes a unique and immutable root-of-trust. They support IoT Security-as-a-Service and provide the foundation for a trusted set of advanced security functionalities.
IoTa also comes with a Hologram SIM card for seamless cloud service integration. Along with this, hologram also provides a free developer account to test your design and develop your portal. With the Hologram SIM card and a low-cost data plan, it’s certified on over 500 carriers in 170 countries.
For more information on the IoTa Internet of Things prototyping platform visit the Crowd Supply website. You can also sign up to be notified when the campaign launches.
TOP PCB Companies
